2 digiboxes - lnb - no signal on 1
Old 24-12-2003   #1
daveb
Posts: n/a
Question 2 digiboxes - lnb - no signal on 1
Hi
I am very new to this game , can anyone advise. I have a PACE digibox , a Amstrad digibox and a signal splitter and the appopriate cables. I can have either digibox live but if I have them together 1 gets signal , the other doesn't , just gets an error message "For Your Information" "No Satellite Signal received" .
What am I doing wrong , or what do I have to do to get signal. I was getting signal on both initially but then this issue started.
Many thanks
Dave
Old 24-12-2003   #2
Mod and septic resident
Channel Hopper's Avatar
Amstrad (early) receivers are notorious for forgetting the LNB voltage or tone settings if disconnected from the LNB, even if only momentarily. Im sure if you unplug and reconect it all comes back.
The Pace may or may not be in a similar position
Old 25-12-2003   #3
Moderator & General Globetrotter
zansi's Avatar
Originally Posted by daveb
Hi
Dave
A signal splitter? not possible for correct operation as a 13/18v and tone is sent out by the digibox to control the V/H polarity and band switching.
If one port of the splitter is "though power" it will control the LNB and provided that both receivers are on the same polarity signal should go to both.
The only satisfactory way to run 2+ boxes is with a twin or quad LNB.
zansi
zansi is offline   Reply With Quote
Old 26-12-2003   #4
Had the same problem Dave with two digiboxes. Drove me mad because I could get the signal on one then the other but not both and got all your error messages as swell. In the end it's not technically possible or advisable. It was solved by the use of the Quad LNB.
diarmuid is offline   Reply With Quote
digiboxes, lnb, signal
Similar Threads
Digital Terrestrial (Freeview) TV reception, Aerials! spiney Members' input on FAQ and How To's 0 09-06-2005 03:05 PM
New Viewing Cards and old DigiBoxes DJHinett Receiver software, international Section 1 06-01-2004 06:29 PM
Skystar 2 Signal 50%, quality 50% - but no real signal zoltiz Satellite PC Card Receivers & Internet by Satellite 4 21-12-2003 08:17 PM
sky sat signal weak sky do i bother? Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 2 07-10-2003 10:00 PM
skystar 2 signal split darknebulae Satellite PC Card Receivers & Internet by Satellite 3 01-09-2003 10:52 AM
