Freesat for two Flats
Thread Tools Display Modes
Old 12-05-2008   #1
My System: No satellite yet.
I live in a house split into two apartments, one downstairs with 3 TVs and an upstairs flat with 4 TVs. The ground floor apartment has a booster box under the stairs taking the TV signal to the wall sockets in the other rooms; the upstairs has a similar arrangement in the loft.
Our TV reception is terrible so I've been looking at BBC Freesat and Sky Freesat as a possible alternative (satellite reception is apparently good in our area.) I've never had satellite before, so I'm unclear on whether we'd need a seperate box for each TV or not. I'm vaguely aware that apartments often have shared satellite, but I don't know whether that would require additional equipment.
What would be the cheapest way to get all these TVs connected?
Dunsany is offline   Reply With Quote
Old 12-05-2008   #2
satelliteman's Avatar
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W
Welcome
The system you require is possible but not on a budget costing
You have two options:
1. One dish with an octo LNb (8 feeds) with cabling going to each point from the dish location. Freesat boxes in all TV socket rooms.
2. One dish with special LNb to a switch (cabling from dish to switch location). Freesat boxes in all TV socket rooms.
__________________
A Detailed DiSEqC Motor Installation Set Up Guide HERE
Motor Installation 'Quick' Reference Guide also HERE
Old 12-05-2008   #3
Robbo71's Avatar
My System: Technomate TM1000D Receiver. Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
An Octo LNB would be the cheapest option of the above two, as you wouldn't need to buy a switch. However you would be limited to 8 receivers.
If you wanted to add twin tuners for recording or any more receivers at a later date, there would be no room for expansion and you'd have to do down the quattro-LNB multiswitch route.
And yes, ideally one receiver is really needed per TV, anything else is a compromise.
Robbo
Robbo71 is offline   Reply With Quote
Old 12-05-2008   #4
rolfw's Avatar
Before going the expensive route of a satellite installation, have you had the aerial checked out by a professional aerial installer to see if reception can be improved?
PS. Satellite reception of FREESAT in the UK will not vary significantly from area to area like terrestrial TV reception where you are receiving relatively local transmissions, it is purely down to line of sight to the satellite.
__________________
Rolf
Donate
Old 14-05-2008   #5
Thanks for the advice, everyone.
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
