USALS and DiSEq on same cable connection? | |
| What me worry? Join Date: 08-01-2005 Location: Southern Ireland / SW France
My System: PACE 430 (Radio Reception only to feed a SKY Gnome), PACE 3100 (PVR 2.5), ROI SKY 6 mixes, Technomate TM-1500 CI+, TM-6900 HD, 100 cm Triax (Sky), 80 cm Nokia with Motec SG-2100. MacBook 2.4, MacBook Air 1.8, iMac G5 2.1. |
So I have spent most of the morning putting together a drawing of a proposed sat setup, so I don't hope my boss uses this forum as well as I can't see him sharing my enthusiasm for non work related stuff... Anyhow, I want to receive BBC HD as well as BBC3 and BBC4 (among others) that are not available on the Irish EPG. I have a quad LNB on my 1 meter dish pointing to 28.2E where one connection point is free. My Technomate 6900HD (where I want to receive the BBC HD signal) has one LNB input which I have connected to a USALS and was wondering if I could do the following (see my super drawing): Can I connect a DiSEq before the USALS and connect my spare fixed 28.2E LNB output (red line on drawing) as well as the motorised to the DiSEq switch so I can switch between the fixed and motorised and still use the USALS for dish movement or does the DiSEq stop the USALS signal from the Technomate to the Moteck 2100? Will there be any significant signal loos having both a USALS and DiSEq switch connected? Thanks, Fred
__________________ | ||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | Hi, I have a similarish setup with a fixed dish for 26E plus a motorised dish. I found it was necessary to connect the Diseqc switch AFTER the motor though:- I.E Receiver-->Motor--> DiSEqC switch-->> LNBs See picture below:- Nothing did anything when I connected the Diseqc1.0 switch first in the chain. Yes there will be a handful of dB extra loss, but as long as the cable isnt too long it will be OK. I have connected mine up without the motor and switch on a weak satellite and there was no difference in signal QUALITY at all, compared with them in. 10m cable= attenuation of 3 dB approx, so an extra component is aprox eqaul to an extra 10m of cable. Robbo
__________________ Last edited by Robbo; 21-05-2008 at 02:15 PM | ||
| The Following User Says Thank You to Robbo For This Useful Post: | Cupart (22-05-2008) |
My System: PACE 430 (Radio Reception only to feed a SKY Gnome), PACE 3100 (PVR 2.5), ROI SKY 6 mixes, Technomate TM-1500 CI+, TM-6900 HD, 100 cm Triax (Sky), 80 cm Nokia with Motec SG-2100. MacBook 2.4, MacBook Air 1.8, iMac G5 2.1. | Thanks man... I think I'll give it a go when I go to France next time. Do you have any recommendations on what DiSEqC switch to get? I could imagine there is quite some quality differences between the different makes. Cheers, F
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | Spaun is supposedly a good make, to be honest one of the installer members would be able to give a better idea on what is reliable, I just got the cheapest I could find (Eurostar-£4.99), seems to work OK so far.
