Setting Default Channel on a multiple Sky + Setup
Thread Tools Display Modes
Old 25-07-2008   #1
My System: SMATV using a combination of 11 Sky + and Freeview Boxes. Each box broadcasts a single channel which is then distrubuted to TVs on campus
We have 11 SK+ boxes each tuned to a single channel. The feeds from these boxes and some other Freeview boxes are then distributed arround the campus.
Each Sky+ box has been programmed to start-up on a particular channel. How can we change this 'default' channel?
Thanks in advance.
Regards
Ian
Harlaxton College
iwelsh is offline   Reply With Quote
Old 25-07-2008   #2
Information Exec
satelliteman's Avatar
Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N
Welcome,
You require to re-programme the SMC's ( satellite master Controllers ).
As it's a SMATV system, I recommend you get a professional in to do this. I've done plenty but it's too time consuming to explain. Also with Sky+ it would be a good idea to make sure the SMC's are Version 2.
.........assuming you have professional SMC's for your box resets. Won't reset the freeview receivers.
Satman
__________________
A Detailed DiSEqC Motor Installation Set Up Guide HERE
Motor Installation 'Quick' Reference Guide also HERE
Old 25-07-2008   #3
Thanks for the info.
Yes we have SMCs (not sure which version). I'll contact our supplier. I thought it might be something we could do via the Sky+ box.
Regards
Ian
Old 25-07-2008   #4
rolfw's Avatar
It is a fairly straightforward process to set the channels to an alternative, but is done on the SMC module.
__________________
Rolf
Donate
Old 25-07-2008   #5
Information Exec
Lets hope their not pin locked
__________________
Old 25-07-2008   #6
Information Exec
Attached file.
SM
__________________
Forum Jump
