Yes another Newbie Question! Multireciever setup with TV & FM Aerial
Thread Tools Display Modes
Old 29-07-2008   #1
My System: 1 Satellite dish, quad lnb, tv aerial & fm aerial
Question Yes another Newbie Question! Multireciever setup with TV & FM Aerial
Hi All,
So I've moved into a new house with a satellite dish hanging off the side of it and thought right lets get a good setup going here for tv around the house. There is also a small FM aerial on the chimney stack in the attic as well as a TV aerial on the outside of the house right beside the satellite dish. So here is what I have and what I want to setup:
So I have at the moment, 3 cables in the attic, one from satellite dish, one from TV aerial and one from FM aerial.
I have 4 rooms with tv & fm points in, one of which also has the satellite cable as well from the dish.
Here is what I want to setup:
All 4 rooms with satellite recievers, tv point from aerial and fm point from fm aerial. I want to run one good quality cable (WF100) to each of the 4 rooms to minimise and keep things tidy.
Am I right that its a quad LNB from the satellite dish that I need, so this will add 3 more cables to the existing 3 cables in the attic.
I know I need to use diplexers/triplexers because I want to run one cable behind each wall. The wall plate will then have 3 ports with a diplexer to re-split the signals - one satellite, one tv and one Fm.
What I'm unsure of is what to do with the 6 cables in the attic to get them to one cable run for each of the 4 rooms? 4 cables from the quad LNB on satellite dish, one from tv aerial and one from fm aerial. Do I need to combine the TV Aerial and FM Aerial into 1 cable first before using a kind of multiswitch?
Any pointers would be well recieved or if there is a better way of doing the whole thing I'm open to suggestions. I just want to get it as right as possible first time! Any suggestions on what the best make/model of equipment would be are also welcome.
There is thankfully 2 power sockets in the attic if that helps as well just beside the chimney stack.
Thanks all.
opalfruit is offline   Reply With Quote
Old 29-07-2008   #2
Information Exec
satelliteman's Avatar
Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N
Welcome,
Sounds like there was a 'loftbox' system set up previously.
You require:
1 > Quad LNb and separate sat/uhf/fm diplexers for each of the 4 points but this would not help you if you wanted Sl<y Plus / Sl<y Hd in the future as you would require more satellite IF feeds although this would work fine with four points only.
OR
2 > Systems LNb (quattro) into a 8 way Satellite Multi-switch. UHF, FM and four fixed feeds from the dish into the switch and then connect up your four feeds to the outlets. Change the outlet plates to Triplex Plates (Sat, TV/FM).
This would be a future proof system as you would have four free feeds from the switch which could be connected up later.
Satman
__________________
A Detailed DiSEqC Motor Installation Set Up Guide HERE
Motor Installation 'Quick' Reference Guide also HERE
Old 31-07-2008   #3
Hi Satman, many thanks for the info, think I'll go with the last suggestion as its alway good to have future needs in mind.
Old 31-07-2008   #4
Recommend an 8 way multiswitch and quattro lnb?
So now I know what way to setup the satellite, tv and fm around the house I am looking for recommendations for the equipment itself. Can anyone recommend a good quality multiswitch? My Dish is a mesh one with no make/manufacturer on it (was there when we moved into house) so is there anything I need to know about substituting the single lnb for a quattro?
I hear the Triax equipment is supposed to be reputable.
Thanks,
OF
Old 29-08-2008   #5
My System: Sky IRS & Hotbird
Opalfruit, it sounds like you have got a sl< y mini dish up, if you can get a quattro lnb to fit on there, then bob's your uncle, if not, then you'll need to buy a 60-80cm dish with quattro lnb.
then get a V5 x 8 multi switch and four triax triplexed face plates to finish the job off
NeroAer is offline   Reply With Quote
lnb, multiswitch, satellite
Forum Jump
