3 LNBs to 4 Receivers | |
| Member Join Date: 26-08-2008 Location: UK
My System: FTA | What is the easiest way for 4 receivers to receive 3 satellites? The only way I can see would be to buy 4 x 5 port DiSEqC switches, but this involves a lot of wiring. I've also searched and found multiswitches, but it's all very complicated and they all seem to do different things. For example, how would the Technisat Multiyenne be wired up? Do they simply creating a housing with a DiSEqC switch inside, or is it all circuitry? TIA | ||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | I think the easiest way to do it would be to use a multiswitch. For 3 satellites and 4 receivers you would need one with at least 13 inputs and 4 outputs ( not sure if someone makes that exact configuration). Each sat need 4 inputs from a quattro LNB, plus there is an extra input for a terestrial feed. I don't suppose it would be very cheap either. The cheapest way to do it, would be to buy FOUR 4-way Diseqc1.0 switches, and use 3 Quad LNBs. Yes there would be a lot of wiring. I would advise that you used the Compression or crimp-on F-connectors to make life a lot easier. Robbo
__________________ | ||
| The Following User Says Thank You to Robbo For This Useful Post: | Prodigy81 (28-08-2008) |
| Information Exec Join Date: 07-05-2007 Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | They do a sat switch that comes as 17 x 6 outputs I believe but at a cost of around £160 and quattro's to purchase also, it won't be cheap
__________________ - .....A Detailed DiSEqC Motor Installation Set Up Guide HERE Motor Installation 'Quick' Reference Guide also HERE Satellites UK site Advertisers - | ||
| The Following User Says Thank You to satelliteman For This Useful Post: | Prodigy81 (28-08-2008) |
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Three quad LNBs and four 4 way DiseqC switches would be the easiest and cheapest way, plus there is far less cable involved, as the DiseqC switches sit behind the dish.
__________________ | |||
| The Following User Says Thank You to rolfw For This Useful Post: | Prodigy81 (28-08-2008) |
| | #5 | ||
| Member Join Date: 08-01-2008 Location: Sweden
My System: WaveFrontier T-90 16LNB Cathing 18 birds 22w-33e Dreambox7020 HDD 5 Spaun 420 1 SPAUN 410 In the satworld since 1991 | EMP ProfiLine has a 13/4 Multiswitch . | ||
| The Following User Says Thank You to Hakon For This Useful Post: | Prodigy81 (28-08-2008) |
| | #6 | ||
My System: FTA | Although a multiswitch looks interesting, they're far too expensive for what they do (in my opinion). I think you've all answered my question that using multiple DiSEqC switches is the way forward (so thanks!) Silly question, but are there tool(s) which prepare the cable? I've always used a sharp knife. With CAT5/6 Ethernet cable there are crimping tools - does such a thing exist for satellite cable? | ||
| | #7 | ||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | You can get cable stripping tools, but I have never used one. As for connectors there are two main types (other than screw on) ; compression and crimp. I just got some waterproof compression connectors and a tool yesterday from screwfix, probably not the cheapest place for the tool, but I wanted it yesterday.
| | #8 | ||
| Member Join Date: 27-06-2008 Location: Germany
My System: Fib0st0p 60, 90, 120 & Motors, Triax Unique MF, DVB-S2 cards | Quads are more exponsive than Quattros but you need to buy a multiswitch instead of diseqc switches then. Overall, the quattro/multiswitch path is more robust & stable. | ||
