Newbie- Multiswitch help required please.
Old 06-09-2008   #1
My System: New build setup
Hi all.
First post so be gentle.
I am currently building a new house and am wanting to fit a multiswitch to allow satellite recievers in every room for sky and/ or freesat.
Also I want to combine the UHF and FM/ DAB into these rooms as well.
I am in two minds though to fit one quattro lnb or two.
What could I pick up on the second if it is in a fixed position, I would only be interested in football if this is possible.
I am also unsure as to the number of cables to take in to a room from the multiswitch, for example-
If I want skyHD in my living room plus freeview and radio would I still need two cables for the sky twin tuners, plus one for the freeview and one for the radio or do I piggyback the freeview and radio onto one of the cables and a triplexed wallplate?
Any diagrams available?
Thanks for reading and I hope the above makes sense.
kmm66d is offline   Reply With Quote
Old 06-09-2008   #2
Design Engineer/Installer
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions...
Sounds like your well up on multiplexing/ multiswitches/ mediaplates etc.. There is a very different system though.. the one cable option if it gets taken up in the future you wont need all that stuff, just a simpler system to add and split dtt & dab and far more basic rf distribution amp for sat.
pedro2000uk is offline   Reply With Quote
The Following User Says Thank You to pedro2000uk For This Useful Post:
kmm66d (07-09-2008)
Old 06-09-2008   #3
satelliteman's Avatar
Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus V2, Thomson DSI6210 Sky+160, Thomson DSI4214, Gibertini 104cm, Invacom SNH-031, 12inch 36v Actuator, Technomate Vbox-II, TF5000CI, TM-5200D, Sling Media, Rover ST-4, Rover SDM-1s, 42E to 30W, Tecatel 1.35m fixed on 28e
Welcome to satellites,
For one quattro, your need a 5 x (how ever many outlets you require) ie. 5 x 8 multiswitch.
For two satellite feeds, a 9 wire switch will be required.
Multiswitchs have satellite inputs, UHF, FM & Dab inputs. These get diplexed onto the one cable feed and a triplex outlet plate for example will be required the other end to seperate the signals.
A failry popular set up would be 28e & 19e OR 13e
SM
satelliteman.
Quick Reference Motor Installation Guide also > HERE
An Installers Choice
The Following User Says Thank You to satelliteman For This Useful Post:
kmm66d (07-09-2008)
Old 06-09-2008   #4
My System: skystar2, nokia9902, xcam, matrix, tpfld 3000cipp
Hi.I would sugest 5x how many tuners you will feed multiswitch.so you have sky 28e and dvb,t and dab,radio on one cable.And one separate quad,okto(how many rooms?) lnb on another cable for any dvb-s boxes in house.Skybox dont have diseq switch option for 9x or 17x multiswitches.If freeview you mean dvb-t box then one cable,if skyplus and dvb-t then two cables,if skyplus ,dvb-t and dvb-s box then three cables(two from multiswitch on diplexer and one straight from other dish).for free football on other satellites not much there try 42e for uefa games or 26e for jazzera sports 1,2 for european leagues(i dont know if 7w nilesat strong for uk).
andmac is offline   Reply With Quote
The Following User Says Thank You to andmac For This Useful Post:
kmm66d (07-09-2008)
Old 06-09-2008   #5
Robbo's Avatar
My System: TM6800HD, TM1000, TM5200, TM2200 motor, Triax TD110 dish + Fibo 90cm.
For twin satellite tuners (eg Sky+) take two feeds from the output of the multiswitch to each room. Just make sure you get a multiswitch with enough outputs for all the satellite tuners you intend to have.
Robbo is online now   Reply With Quote
The Following User Says Thank You to Robbo For This Useful Post:
kmm66d (07-09-2008)
Old 07-09-2008   #6
Thanks very much for all your quick replies.
Pretty much confirmed what I thought and answered what I wasn't too sure about.
One last question if I may be so cheeky.
Is one make of multiswitch regarded as better than another.
I am leaning towards a Triax at the moment.
Are the Triax good or is there better out there? Don't mind paying a bit more to get better quality and results.
Thanks.
Old 07-09-2008   #7
Triax are Ok
satelliteman.
multiswitch, newbie, required
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. Uptime monitoring by PageUtils.com
Content Relevant URLs by vBSEO 3.3.0
