Technical genius required for business idea
Thread Tools Display Modes
Old 17-09-2004   #1
I need to have a device that I can stick into any UK aerial socket and it can tell me whether I can get good reception for digital TV. More importantly, I need to be able to make it for less than £1.
Is there anyone in the world that has the correct technical knowledge to be able to do this?
My understanding (from an ignorant position) is that certain areas of the UK cannot get digital TV. That is fine. However, in areas where there is digital tv - I need to check whether my aerial is correctly aligned to get a signal.
Can you help?
Thanks,
Rob
rob_millar is offline   Reply With Quote
Old 17-09-2004   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
Originally Posted by rob_millar
Can you help?
Thanks,
Rob
Hi Rob
It's not just a question of technical knowledge, it's the economics of making a device that converts the aerial signals into something readable by, I presume, Joe Public.
Simple meters like those used for satellite alignment wouldn't be able to differentiate between analogue and digital terrestial transmissions.
Let's consider what's required.
A front end to receive all multiplexes in the bands IV and V.
An oscillator to sweep these bands or alternatively choose from a set of preprogrammed DTT frequencies.
Some form of display e.g. a CRT or LCD screen to show the multiplexes, to see if they are of sufficient amplitude ,or better still see if they are not too close to the frequencies of any analogue transmissions (i.e. out of area signals).
You'll need to add a few noughts onto that £1...
Llew is offline   Reply With Quote
Old 17-09-2004   #3
Mod and septic resident
Channel Hopper's Avatar
How about a freeview box ? The cheapest one is about £40, and if it doesnt work, take it back for a refund. A signal meter for nowt.
__________________
Old 17-09-2004   #4
rolfw's Avatar
It would appear perhaps that Rob is looking to manufacture and sell a DIY Terrestrial Digital testing kit. The £1 manufacturing cost may be just a tad optimistic.
__________________
Rolf
Donate
Old 18-09-2004   #5
How about a circuit like this, just a basic tuned signal test meter. You would need to calculate values for the inductor and trimmer capacitor pair to tune the antenna, and I have no idea really how you would manage to calibrate it, i find someone who's house is on the threshold of signal strength and tune it so the LED just comes on.
This is a modification of a simple circuit using my limited memory of A-Level electronics, but I think it is roughly right. If it worked then the unit cost would be reasonably cheap.
Damien
damhy is offline   Reply With Quote
Old 18-09-2004   #6
Hi rob, I know a device that i used to get the signal for my set up,it is called a swaw meter,it was used by c/b users years ago the price price then was about £3.50.
caretaker is offline   Reply With Quote
Old 18-09-2004   #7
Unless you know something I dont, a SWR is not going to help here, a SWR meter is to check the attenna matting to the wavelength of the transmitted signal. What Rob wants is to check the incoming signal.
Old 19-09-2004   #8
BGonaSTICK's Avatar
Whoa, that instantly took me back to the days of sticking 200w single-sideband through my Spitfire PZ1 directional horizontally-polarised half-wave array and leaving messages on my next door neighbours answering machine!
CQ, CQ.
__________________
Old 19-09-2004   #9
I never managed to cause that much distress, though I did cause loads and loads of TVI, which ultimately lead to several neighbours signing up with Telewest. Maybe I should recommend it to their marketing department! They could do with some new ideas.
Old 19-09-2004   #10
CQ, CQ.
our cooker would broadcast the spiel of the local taxi firm.
__________________
Forum Jump
Similar Threads
HDTV Primer spiney High Definition Receivers transmissions, satellite and Terrestrial 0 16-01-2006 12:42 PM
No idea what size dish do I need for getting Astra 2D in Sicily? ynot62 Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 4 07-12-2004 12:05 PM
Interesting Idea you want to get off your chest ? Channel Hopper Einstein's Alcove 0 31-10-2003 12:22 PM
