twin out LNB - 2 power supplies or one ?
Thread Tools Display Modes
Old 01-11-2004   #1
dmm
Question twin out LNB - 2 power supplies or one ?
hello,
i have a skystar 2 PCI card and a GBSAT receiver and one (twin output) LNB - OK its obvious that each of the LNB outputs will go to Skystar and GBSAT respectively - but the question is - must i disable one of the power supplies to the LNB - i.e for instance will the power supply coming from the GBSAT receiver be enough to power the LNB and enable it to supply a signal to the skystar PCI card also ?
thanks
dmm is offline   Reply With Quote
Old 01-11-2004   #2
Jaffer's Avatar
My System: Samsung A300W with component output Hotbird & Astra2
Yes, it will work fine.
__________________
Every little helps and a little help goes a long way!
Jaffer is offline   Reply With Quote
Old 01-11-2004   #3
BGonaSTICK's Avatar
Originally Posted by dmm
hello,
i have a skystar 2 PCI card and a GBSAT receiver and twin output LNB - OK its obvious that each of the LNB outputs will go to Skystar and GBSAT respectively - but the question is - must i disable one of the power supplies to the LNB - i.e for instance will the power supply coming from the GBSAT receiver be enough to power the LNB and enable it to supply a signal to the skystar PCI card also ?
thanks
Both receivers must supply one of the LNB's with power, just as if it were two seperate LNB's on two dishes.
__________________
Old 01-11-2004   #4
dmm
heh heh
thanks guys but i'm getting contrasting answers here - who can give me the definitive answer - one power supply or two
hope i havent started a war of opinions here .....and then again it might provide some entertainment !
Old 01-11-2004   #5
Jaffer's Avatar
BGonaStick is the expert.
__________________
Old 01-11-2004   #6
dmm
seems he is jaffer
but hey either way i just didnt want to blow anything up and thanks to you both .....
its working now both power sources enabled .....now where did i leave those keys
Old 01-11-2004   #7
Jaffer's Avatar
in root folder
__________________
Old 07-11-2004   #8
Hmm, now what seems to be the problem?
dishdoctor's Avatar
Originally Posted by Jaffer
in root folder
There must be two power supplies to the twin lnb........so that one reciever can "ask" for horizontal frequencies at one voltage.....and the other receiver can "ask" for vertical frequencies at a different voltage....otherwise how would the lnb know?.................................
dishdoctor is offline   Reply With Quote
Forum Jump
Similar Threads
digital 600 dead 065216463 Receiver software, international Section 5 25-04-2006 10:11 PM
Signals, noise, digital errors ... all that stuff. spiney Members' input on FAQ and How To's 0 02-04-2006 04:41 PM
Power increases on DTT net1 Terrestrial Television, Digital and Analogue 1 28-11-2003 10:48 PM
Small request - twin output LNB Channel Hopper B Sky B Digital and 28.2 East General 3 09-10-2003 04:41 PM
Power doubling on Mux A goes ahead net1 Terrestrial Television, Digital and Analogue 0 30-04-2003 07:32 PM
