Keeping Receiver on Standby or Off-Mains
Thread Tools Display Modes
Old 29-04-2005   #1
al_madhi's Avatar
Thumbs up Keeping Receiver on Standby or Off-Mains
Hi ppl , wondering if anybody can give me a technical advice , I switch the receiver off , Which is the safe way to keep the receiver on STANDBY all the time or to switch it off completely from the MAINS . But as far as I know when the receiver on STANDBY ( Red lamp is on ) when I touch the back of the receiver is very hot because the electric current still passes through the coil of the transformer and keep it hot and this will shorten the life of the power supply unit of the receiver . Note that as well when I switch it from the MAINS the date and the time of thr receiver is gone and I have to set the date and the time again . Any thought you would have be greatly appreciated .
__________________
AL-MADHI
al_madhi is offline   Reply With Quote
Old 30-04-2005   #2
My System: DSR 2030 Version: R3R 1.14
it's better to keep it on Standby... coz if it stay hot.. it's better than getting it
hot and cold.... this change's in Temputure harm the DSR....
keep it Standby... Keep it Hot...
Advice: you can install a Fan on the DSR
Note: to see how to install a Fan... Semd me a note... and i'll help you
Regards
Sniper^
Sniper^ is offline   Reply With Quote
Old 30-04-2005   #3
Dazed and Confused Mod
PaulR's Avatar
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100
Sniper^ is right that constant changes in temperature will do more harm than leaving the set in standby. Make sure that there is enough room for air to circulate around it and don't put any other sets on top without a breathing space in between.
If you are not watching every day then it's probably better to switch it off completely as the constant heat has a drying out effect on capacitors over time. It's a tricky judgement point to make and a fan certainly helps if it's left on all the time.
If you're talking about a $ly digibox then you need to keep it on all the time as it receives over-the-air upgrades for its software from time to time. Also the card needs to keep receiving "stay alive" signals, although up to a month shouldn't be a problem. Again a fan helps and there kits available for these.
PaulR is offline   Reply With Quote
Forum Jump
Similar Threads
2 dishes: Add 2nd receiver, UHF TV and FM Artist 2004 Multi-receiver/TV systems 8 11-03-2007 09:14 PM
Samsung dead. PLZ HELP!!! Zebo Receiver software, international Section 9 16-02-2006 12:05 AM
Matrix Reloaded How To by AHAC rolfw Matrix Reloaded, Revolutions and CAS interface 52 27-12-2005 12:02 PM
Lidl Satellite Receiver. spiney Digital systems 13 28-10-2005 01:15 PM
IFA 2003 Berlin exhibition report net1 Digital systems 0 01-10-2003 08:02 PM
