Two digiboxes with one single LNB or frequent removal of viewing card? | |
| Member Join Date: 18-12-2003
I currently have an Irish digibox with an Irish sky subscription. As I would like to watch ITV, CH4 and CH5 but have no way of ordering a UK Sky subscription, I thought about getting a FTV viewing card from England ( Ebay A: Use two cards with one box, i.e. remove the SKY card and replace it by the FTV card whenever I want to watch a program on ITV, CH4 or CH5. Is this possible in general? And would frequent removal and reinsertion of the cards (possibly a couple of times a week or even once a day) be harmful to the cards? Any experiences? B: Get a second (used) box and use the FTV card with this box. In that case I would need to hook up two digiboxes to one satellite cable that is fed by a single LNB. Is there a switch, splitter box or whatever device that can split up a digital satellite signal for two receivers? Thanks a million! Helmut | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | A or B will be fine, I'm sure that removing and replacing the smartcard isn't the best idea, but will probably be fine, for the second idea, you can get an A/B switch, or a twin or quad LNB.
__________________ | |||
| Regular Member Join Date: 02-12-2003
I'm in Dublin with two digiboxes and two cards one Sky - one Next Genaration for UTV, Channel 4 and 5 etc. Two digiboxes is the least trouble. Buy a refurbished Digibox for best value and avoid the nuisance of switching cards which is not a good idea. The only other minor problem is switching channels as the remote catches both boxes at the same time. There is a solution on another forum here on pasting a polarised strip on the remote LED but I found that closing off one box is almost as easy until you need to change channels again. For example my Sky box is almost permanently on the football news channel while I can hop around the other Programme Guide to my heart's content. If you want to have the two boxes transmitting to another TV watch out for the channel number clashing. My main Sony has the capability to hold two separate signals from both boxes without conflict but my small kitchen portable was mixing the two signals. The solution was to change the channel output number from 68 the default Sky number to another number in the range I think from 60 to 70. I have the two signals now without any problem and one is on the "Magic Eye" extension from the RF 2 outlet. Hope this helps. | ||
| | #5 | ||
| Regular Member Join Date: 04-02-2004 Location: London [South East]
My System: CPU Intel® Pentium® 4 640 Prescott (3.20 Ghz) Memory 1024 MB DDR RAM - (2x 512 MB - PC3200) Motherboard ECS 915P-M3 Hard Drive 300GB Maxtor DiamondMax SATA 6B300S0 Skystar 2 usb 1mtr steerable dish Technomate, Fortec, New Wave and Ka |
Unfortunately I have only just seen this thread, just did a long reply, but that nice aol service just fouled it all up, so I will keep it short. An ordinary splitter is no good, you need a Global Communications SPLIT4AF this allows you to connect up to 4 receivers from one dish, with 1 LNB and 1 cable without any loss of signal. I am using one the same way connected up to 4 different types of digital receivers with no problems whatsoever. Can post the address of the company if anyone would like it, providing the moderators of the board are in agreement | ||
| | #6 | |||
| Member Join Date: 02-09-2004
| hi wonder if you could help. ive 2digiboxes.2smartcards. but only one satelite dish. could you tell us how to connect so we can watch both tv's , novice to this . thankyou meme ,,,,,
| | #7 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Just put a quad LNB on the dish and run a cable to the second box, very easy to do.
| | #8 | ||
| Member Join Date: 23-05-2005
My System: 2 didgi boxes and one dish |
hi i found your forum on a copernic search ! i have purchashed a split4af but on testing it in the lounge with 2 boxes and tvs ,they still only want to show one at a time ,i read the info but dont want to connect the split4af to the rf /out in caes i blow it ,do you have an idiots diagram to help me ? | ||
| | #9 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Yes, it is only good for supplying one box at a time, as they only multiply the outlets from one feed. What you need is a twin or quad LNB.
| | #10 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | PS. Welcome to the forum.
Similar Threads | ||||
| Seca2 card for 140 euro is a fraud | net1 | Seca/Mediaguard system | 0 | 28-10-2003 06:23 PM |
| Which DVB card? | alnitak | Satellite PC Card Systems & Internet by Satellite | 4 | 26-08-2003 02:17 PM |
| Pentamedia card not initializing | s*t*a*r*m*a*n | Computer Discussion | 1 | 14-07-2003 05:07 AM |
| Viewing card copy ? | wurfel | Receiver software, international Section | 7 | 29-06-2003 02:51 PM |
| new card don't work | Robbiewright | Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 3 | 25-06-2003 09:05 PM |
