Reliance signal at MEASAT-3 Satellite | |
| Bandit Queen Join Date: 19-08-2004
My System: Satellite Blood | Reliance BIG TV DTH Signals being beamed KU BAND in India through MEASAT -3 satellites @91.5*E. Right now they are using 8 transponders for 37 channels, where SAHARA & few FTA channels are in air. Measat-3 @ 91.5° East Freq Pol SR FEC Mode 12523 V 27500 3/4 MEPG-4 12563 V 27500 3/4 MEPG-4 12603 V 27500 3/4 MEPG-4 12643 V 27500 3/4 MEPG-4 12683 V 27500 3/4 MEPG-4 12683 H 27500 3/4 MEPG-4 12723 H 27500 3/4 MEPG-4 12723 V 27500 3/4 MEPG-4 | ||
| The Following User Says Thank You to Vivek For This Useful Post: | ulhasg (01-09-2008) |
| Section Leader Join Date: 07-07-2006 Location: INDIA
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Is that True, I cant find Signal No were. web content. Bigtv website is under construction....... Even. Information are not available on anywhere.
__________________ | ||
| | #3 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Theres a press release hare: _http://reliancebluemagic.blogspot.com/ which says Antrix/ISRO has leased 8 tp's on Measat 3, and the satellite certainly has an Indian beam However the Blue Reliance service will use MPEG4 so normal receivers will be useless with the service - MPEG4 receivers will be needed. They will also use the ultra secure NDS Videoguard encryption.
__________________ | |||
My System: Satellite Blood | | ||
| | #5 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Thanks for the INFO Bro...! Ill let you know tomm. I have MPEG4 Capable System, I can handle it.
| | #6 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | If either of you has the capability to do screengrabs please put the info up on the New Channels section
| | #7 | ||||
| who am i ? whence am i ? Join Date: 02-06-2005 Location: illusion
My System: eternal bliss |
They will be using Nagra3 and not NDS Bharti will be using NDS (MPEG4 too)
__________________ ask yourself -- who am i ? | ||||
| | #8 | ||
| Crazy Techie Join Date: 28-04-2006 Location: Maharastra, Hindustan
My System: AMD PC, Skystar2 2.6D, Inverto 0.2dB Single Universal Ku-Band LNB, NUCLEUS 100cm Solid Dish | h**p://w**.bigtv.co.in/ TPs ==== 12523 V 27500 3/4 MEPG-4 12563 V 27500 3/4 MEPG-4 12603 V 27500 3/4 MEPG-4 12643 V 27500 3/4 MEPG-4 12683 V 27500 3/4 MEPG-4 12683 H 27500 3/4 MEPG-4 12723 H 27500 3/4 MEPG-4 12723 V 27500 3/4 MEPG-4 Last edited by member91040; 27-12-2007 at 08:11 AM | ||
| | #9 | |||
| Member Satellites.co.uk Join Date: 19-02-2007 Location: Kerala
My System: NSS 6 (Dish T.V - K.U Band), Insat 4B (DDDirect Plus, Sun Direct - K.U Band) ,Insat 2E (C Band) & Insat 4A ( C- Band) - PC AMD Athalon 64*2 , 120 GB HD, 1 GB Ram. OS XP & Obuntu. |
If the MPEG4 Receivers (Not by the Service Provider) available in the market. | |||
| | #10 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Yes i had seen the website its Under construction...! MPEG4 , Quality and More Channels.
| | #11 | |||
My System: AMD PC, Skystar2 2.6D, Inverto 0.2dB Single Universal Ku-Band LNB, NUCLEUS 100cm Solid Dish | Thanx | |||
| | #12 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | System should be capable to handle HD , We need High End, Soo I doo have, If you find any Signal Pls frw the pic.
| | #13 | ||
| Regular Member Join Date: 06-11-2007 Location: Gujarat
My System: 60cm, Ku LnbF, MPEG-2 STB (DiSEqC 1.2) | | ||
| | #14 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | S/W = software SS2 - SkyStar 2 (PCI satellite card for inside your computer) Heres a picture of one - current price in the UK is 40-50 UKP
| | #17 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | If folks want to discuss Indian suppliers of Skystar 2 cards please start a new thread - this one is getting well off topic.
| The Following User Says Thank You to Analoguesat For This Useful Post: | smartbuddy_82 (27-12-2007) |
| | #18 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Yes i got the Signal...! Quality if fine ...! Standard Defecation. Compare to Luxe TV HD.
| | #20 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Ths Good Khan, Tell me regarding Quality. I Found some thing difference between Luxe .
| | #21 | ||
My System: AMD PC, Skystar2 2.6D, Inverto 0.2dB Single Universal Ku-Band LNB, NUCLEUS 100cm Solid Dish | Hello Memberxxxx I'm confused now ![]() I'm not getting all the TPs but confused whether those are from Measat3/Big TV Are the test signals are also ENCRYPTED wirh SECAM ? I'm getting few channels with secam encrypted. Are those from Big Tv ? They should test signal for 2-3 months in FTA mode Thank you | ||
| | #22 | ||
| Section Leader Join Date: 10-05-2007 Location: north west india
My System: coship receiver 2000,Dreambox 500;2 ku3cband dishes of 2,4,6&8feet,amd 64 pc with 1GB ram usb tv tuner card | Pl.be specific bros,Is the signal receivable to oridnary sat receivers or no?Anybody receiving on ordinary receivers pl.reply. | ||
| | #23 | |||
| | #24 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Bro You cant receive the signal on Normal STB. I mention it before its MPEG4 Dear.
| | #25 | |||
| Member Join Date: 12-12-2007 Location: Doha-Qatar
My System: Dreambox 500S | Thanks. | |||
