My Self-Installed Fixed-Dish Multi-LNB System
Upload your photos here (Don't link to them with img code, upload them), doesn't matter how basic your setup, it's nice to see what everyone is working with. If you've seen an interesting setup, then post it here. All photos here are copyright and cannot be used without permission of the poster.
Old 29-01-2008   #26
rolfw's Avatar
Real name: Rolf
Ah yes, I've used them as well, I think they are the MTI basic LNBs, they are designed so that the cable leaves at an angle, but quite confusing when you first set one up.
Rolf
Old 30-01-2008   #27
satelliteman's Avatar
Real name: Paul
I can see where you are coming from now after looking at the images. Not seen those types around b4. Suppose it can look confusing .
Old 20-02-2008   #28
My System: Pace DS810XE Raven Gemini 70 dish Multi Bracket, 3 Inverto Silvertech 0.2 LNBs
Hi Garry, Ive got the same dish and thinking of same sat setup. Is that just a straight piece of angle bracket with a slot in one side holding the Lnbs? or is it curved to the radius of the dish (about 530mm Rad I think) Can I ask where you bought it? I bought 3 inverto sigle 0.2 lnbs but have no bracket yet for the other 2. Ive just got 1 set up pointing at 28.2 at the mo... Thanks
RobHoo is offline   Reply With Quote
Old 20-02-2008   #29
rolfw's Avatar
Real name: Rolf
That bracket is the raven East and West LNB bracket _http://www.sateuropa.co.uk/product_overview.asp?id=1694&catid=1&subcat=51
Rolf
Old 21-02-2008   #30
Thanks for that Ive ordered one.. How do I line up the other 2 LNBs that i will be putting on it? Is there a specific satellite that I have to focus the center lnb on? Im looking for mainly HD channels if any but was thinking Hotbird and Astra 1 as the other 2...
Old 03-03-2008   #31
Rd100
Posts: n/a
Nice and tidy well done,
Originally Posted by garym71 View Post
Here are a few pictures of my setup. It's not a motorised system so it's fairly basic compared to some of the other members systems but it was my first self-installed system so it was a good learning exercise The dish went up a couple of weeks ago and the whole setup was finally completed last weekend.
These are the specifications of my system:-
  • Raven Gemini 70cm Mesh Dish
  • Raven Multi-LNB Holder Offset Brackets (both East & West)
  • 2 x MTI Supreme 0.2db Single Output Universal LNB
  • 1 x MTI Supreme 0.2db Quad Output Universal LNB
  • Orbital SM1 U-Type Wall Bracket for Pole Mount Dish
  • Eurostar 4x1 DiSEqC Switch
  • Webro WF100 Cable
The elevation bracket on the back of the dish was originally galvanised silver in colour so I painted it dark grey to match the dish as I thought it looked much better I also modified the LNB arm by cutting a hole in the front of it so I could run the cables inside the hollow tube as opposed to them having to be taped along the outside which made the installation look much neater
The dish is centred with a single ouput LNB pointing at Astra 19.2E. The quad output LNB on the east offset bracket is pointing at Astra 28.2E, and the other single output LNB on the west offset bracket is pointing at Hotbird 13.0E.
I have both single LNBs and one of the outputs from the quad LNB going to a DiSEqC switch. The output of the switch currently goes to a Technomate TM-5400CI+ FTA Receiver. Two of the remaining outputs from the quad LNB (Astra 28.2E) go direct to a Sky+ box.
I'm getting pretty good signal level & quality results from all 3 satellites as can be seen in the attachments below.
Thanks to everyone on here who gave me help and advice when I needed it
Old 10-04-2008   #32
whatpassword's Avatar
Like yourself Gary I've just completed my little experiment. Using a ISS 60cm Dish, x4 Lemon .2db LNB, Technomate 4x1 DiSEqC Switch & x2 brackets I've managed to get 1w to 28e with 13e being the central focus.
I'm also using a Technomate 5400CI. Very pleased with results but admittedly not had any heavy rain yet. I currently have a minidish situated below the Lemon with Quad LNB awaiting the launch of Freesat. If the 28e holds up in the rain I may do away with the minidish and replace the single lemon lnb with a quad.
My Self-Installed Fixed-Dish Multi-LNB System-dscf1995-jpg   My Self-Installed Fixed-Dish Multi-LNB System-dscf1996-jpg
whatpassword is offline   Reply With Quote
Old 10-04-2008   #33
Real name: Paul
Looks a neat job. Like the spray paint colour
You might be able to pull in 5W but of course the dish maybe a little on the small side
Old 11-04-2008   #34
Thanks.
I considered 5w but would need a smaller LNB holder. I'm sure I could cut the holder down though. I'm not sure how the extra feed would work with only 4 inputs available on the receiver with DiSEqC1.0. I'm currently able to receive approx 250 channels both FTA & Subscription at 1w with an average strengh between 48% & 80% depending on which TP your viewing. One TP is breaking up quite badly which I suspect is due to the size of dish. I'm considering an 80cm dish now so as to strenghthen everything up and dispose of the minidish. The paint was spray on red primer from halfords. One large can was enough for both the 60cm and minidish plus the mounts with a bit left over for the odd scratch.
Old 12-04-2008   #35
neat job,you might like to have considered a small motorised setup,the plus side though you have access to channels straight away.
a lot of people find when the lnbs go up a motorised is the next step.
satellite eye is offline   Reply With Quote
Old 12-04-2008   #36
Amo Amas Amant Admin
Topper's Avatar
Not really sure what you are trying to say here?!/!5?!
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 12-04-2008   #37
I know what you mean. I've actually almost come full circle now. First ever installation was a motorised dish but after a year or two the motor became a bit noisy. As I was only really viewing 3 or 4 satellites I eventually purchased a TechniSat Multytenne instead. I'd fully reccomend the Multytenne to anyone in the south of England wanting a really easy setup. Only downside was connecting a S_y Digib_x did not work as no DiSEqC control is present. With the upcoming launch of the BBC Freesat service its rumoured the recievers will like S_y not have DiSEqc control. All this floating around in my head I decided to install one dish for foreign satellites and another just for the Freesat service. Now I've had a play with a 60cm dish setup I'm going to swap both dishes out for an 80cm and replace the single LNB pointed towards 28e with a Quad .2db LNB. This setup I'm hoping will serve my Technomate Receiver as well as a Dual tuner Freesat PCI card when / if they become available. Once I've sprayed the new dish I'm sure the neighbours although not said anything will be pleased with the less cluttered view. Once complete I may post a little history line of photos with final result I hope?
Old 4 Weeks Ago   #38
My System: Panasonic 37 freesat HD
Where did you get the Raven dish?
  • Webro WF100 Cable
Where did you buy the Raven dish as I want a similar setup?
FDIMU is offline   Reply With Quote
Old 4 Weeks Ago   #39
garym71's Avatar
My System: Pace TDS470N Sky+ Receiver, Technomate TM-5400CI+ FTA Receiver, Raven Gemini 70cm Mesh Dish with East & West offset LNB brackets, 2 x MTI 0.2db Universal LNBs, MTI 0.2db Universal Quad Output LNB, Eurostar 4x1 DiSEqC Switch, Webro WF100 Cable
I got the Raven Gemini dish from Falconsat but I recommend that you avoid them like the plague because although I did eventually get the goods I ordered, like a lot of other people it wasn't without problems (have a read of this thread). I suggest you either search Google for an alternative supplier or contact Raven direct and ask them to give you a list of UK suppliers.
One other thing to note is that I started having issues with the MTI Supreme LNBs (see this thread) so I have now replaced them all with the following Inverto Black LNBs...
  • 2 x Inverto Black Ultra 0.2db Single Output Universal LNB (model IDLB-SINL40-ULTRA-OPP)
  • 1 x Inverto Black Premium 0.2db Quad Output Universal LNB (model IDLB-QUDL40-PREMU-OPP)
The Inverto LNBs were about 3 times more expensive then the MTI ones but on the weaker signals they're already giving an additional 32% increase in quality than the MTI ones were from new (was 68%, now 90%) and so far I've had no loss of service at all since the Invertos have been on the dish which just goes to show that you do actually get what you pay for
Pictures of my satellite system setup are HERE
garym71 is offline   Reply With Quote
fixeddish, multilnb, selfinstalled
[IMG] code is Off
