Multifeed WFT-90 some modification done
Thread Tools Display Modes
Old 07-02-2008   #26
My System: None
You can make the same LNB rail as Hakan as he used the same LNB holders that are sold on Ebay in Germany.
Ebay 200195955969
Then you just buy the aluminium rail from any metal workshop.
Prodelin is offline   Reply With Quote
Old 10-02-2008   #27
My System: WaveFrontier T-90 16LNB Cathing 18 birds 22w-33e Dreambox7020 HDD 5 Spaun 420 1 SPAUN 410 In the satworld since 1991
And if you look closer you see........ahh not the same.
Hakon is offline   Reply With Quote
Old 10-02-2008   #28
My System: None
Well you have not made it yourself and yes it's the same, anyone can see that from the picture below, the rail you can buy from any workshop.
_http://www.satelliten-shop.com/catalog/product_info.php?products_id=87
multifeed-wft-90-some-modification-done-multified%25204%2520r-jpg
Old 11-02-2008   #29
I have never said that i have made the LNBholders for myself?? The item you had in your first post was not the same.
But i can tell, the idea and finding out how to use them at my T-90 is all mine.There has been many wishes for better LNBholders for the T-90 but yet i have not seen anyone who have solved the problem,untill i got this idea.
The reason that i have not posting were to buy is that my reseller had them out of stock for nearly 2 months,i bought the last one in the middle of dec.
Old 19-02-2008   #30
rolfw's Avatar
Have moved the dish setup questions and answers to the main dish setup forum Setting up my Wave Frontier T90
__________________
Rolf
Donate
Old 30-03-2008   #31
slcartaxo's Avatar
My System: fte 420 maximal;head 500; e agora s200 fte
Ebay 200195955969
hello all ,
is there a scetch os the lnb rail.. " holder" .. so i could try to make one also,,
what i want is 9,10,13,19, ans 22 East...
slcartaxo is offline   Reply With Quote
Old 31-03-2008   #32
My System: Dreambox 7025
Very nice work Hakon. I have also experiences of motor antennas. I had Stab HH120 bought 2006. It worked first winter 2006/2007 but not the current one 2007/2008. Also SM3D12 were frozen to its place below -20 degrees.
I'm living in northern part of Finland where -20 degrees outside temperature very often when you want to be inside and watch TV rather than climbing on your slippery roof turning manually your antenna.
Then I also bought T-90.
jim43 is offline   Reply With Quote
Old 31-03-2008   #33
Originally Posted by slcartaxo View Post
hello all ,
Hi
I didn't understand all part in your answer,my english is not alltime so good.
But if you want 9e and 10e you might do as i have done.In most case you can use just 1 LNB for satellites that has up to 1,5 degrees between them.
So for 9/10e its no problem with the same LNB,i also grab 4/5w with 1 LNB.
Cheers
Old 31-03-2008   #34
Hi
I have heard that there was a serie (for a few years ago) with motors from STAB that wasnt that good.
But today they are really good.
But i can tell, T-90 like it a lot
Old 31-03-2008   #35
My System: DM70000s /Hdd/USB Nokia9311/Sattracker2.0N Philips175d MII Fun5
Are those brackets the ones Vantage produced a couple of years ago, I saw a test of them in Tele-Satellite a couple years ago and they got great revues. They look identical as far as I can see.
baxter_norway is offline   Reply With Quote
Old 18-06-2008   #36
shaktoo's Avatar
My System: Wave T-90/Nanoxx9600/Technotrend TTs2 3200/HTPC
WOW what a setup.. actually this and satlex is my inspiration to order and install a wave T90..although i am really stuck about switches...i want to feed three receivers .. what will be the best possible way to feed 3 receivers from 12 satellites...if anyone can guide me reagrds this will be extremely thankful.. cheers, please see my thread Advice re Multi LNB setup
shaktoo is offline   Reply With Quote
Old 24-08-2008   #37
My System: Kabel BW
Excellent work Hakon
May i ask which frequencies do you get from 4W and 33E ? They look somehow difficult for Southern Sweden and your configuration.
__________________
I demand: Pay-TV subscriptions worldwide available - with any receiver - just like print magazines !
Free access for free citizens now !
deepbluesky is offline   Reply With Quote
Old 24-08-2008   #38
Yes these birds are really tuff ones for the T-90,but i have some transponders that i can grab.
At 33e i cant get signal without BER
But at 4w i have the strongest transponders without BER and this is with an Dreambox 7020 and they are not fameus for there tuners.
4w is a hell to callibrate as i shall have signal from 5w to with same LNB.
Cheers
multifeed-wft-90-some-modification-done-4w-jpg   multifeed-wft-90-some-modification-done-33e-jpg
Old 24-08-2008   #39
My System: Kabel BW
Thanks Hakon.
33E is a weird position. I've done some research for out of footprint behaviour so far in several boards. Very sharp edged beams, many low bandwidth narrow neighboured frequencies sharing the same transponder and often with high FEC values. This shows us that it's not a DTH satellite. Anyway, it's nice that there is some FTA stuff not regarding the quality at all of course. Do you only get 12647V or also the other Spot C frequencies 11027V/11053V/11139V/12522V/12739V ?
Some 4W and 5W frequencies are very close that's true. The problem in your location seems to be that 5W is compared to 4W (especially Amos 2 Europe Beam) extremely strong. Although the polarity is different the stronger frequencies seem to destroy the weaker ones. In Crete where the 4W Verticals are stronger than 5W Superbeam they have similar problems. So in your case i really wonder if you get all the Amos 2/3 Europe Beam frequencies.
__________________
Old 24-08-2008   #40
In 33e i can only get the 12651 (eg 12647)
Im so far out of the LNB-guide that i think its nice with with just this transp.
In the case of the 4w it depends what time at the day i try,and if its nice weather.
Ex Sportclub is no prolem with 24/7
But 1 Plus 1 just sometime i am
I use 4w to test different LNB-make at my T-90.
But i need to recallibrate as we have had storm (up to33m/sec)for a few weeks ago
I also have to replace some LNB like the Maximum V1 they are realy crap in quality.
I prefer to use the Smart Titanium 2nd Edition
Old 24-08-2008   #41
My System: Kabel BW
I see. Well the T90 is the cheapest way for getting most frequencies if the satellites are strong enough and not too far away one from the other. For your location quite a good choice. 33E is indeed at the edge but because of strong Spot C in your region (>50dbW if you are in the most southern corner of Sweden) i would have expected a better reception. 4W of course is another story because of the above.
__________________
Old 24-08-2008   #42
The 33e is far outside from the T-90 kapacity as it is callibrated today.
If i have another
Imaginary central satellite as i have today the result for the 33e would be mutch better ,i belive.But then i have to take away both 22w and 18w
The left pic is the west LNB and the right pic is the east LNB
multifeed-wft-90-some-modification-done-t90-jpg   multifeed-wft-90-some-modification-done-t-90-jpg
Old 24-08-2008   #43
My System: Kabel BW
Suppose you've chosen 5E as the center position, right ?
__________________
Old 24-08-2008   #44
No there are no sat in the middle 5e is at R 0,7 and 7e is at L -1,5.
I do the azimuth and elevation with the 5e at R0,7
Then the skew at 28,2 and 12,5w (far east and far west)
After that i check the elevation again.
I do the dish callibration with the original plastic LNB holders.
After that all the fun starts to put all LNB in place and finetune each LNB.
As i use the exellent PLi image in my DM 7020 i can use the PLi satfinder streamed to my laptop.
Its a hard work but someone has to do it
Old 24-08-2008   #45
My System: Kabel BW
So your virtual center position is about 5.5E. I know it takes time to finetune the T90.
__________________
Old 25-08-2008   #46
Yes thats correct.
Old 30-08-2008   #47
My System: Technomate 5400ci motorised system, Basic Sky Set Up, Cyrus HiFi, 3 drumkits, 1 wife.
great work there
mapex is offline   Reply With Quote
Old 01-09-2008   #48
My System: i have six antenna,one toroidal with 16 lnbs 3 satellite receivers
_http://i78.photobucket.com/albums/j108/amatorul/PIC_0046.jpg
_http://i78.photobucket.com/albums/j108/amatorul/toroidala.jpg
42E-39E-36E-31E-28E-26E-23E-19E{centre}-16E-13E-10/9E-7E-5E-1W-4/5W-7W
Here are two photos with my toroidal with 16 lnb.As you can see I chose between 42E and 7 W.My central position is on Astra 19.2E.As for satellites too close one another,i.e 26E ans 28E,and also 9E,7E and 5E,I altered lnb support ,cutting the edges I chose Alps,as you can see:
_http://i78.photobucket.com/albums/j108/amatorul/PIC_0023-1.jpg
I use 4x4/1 diseqc switches 1.0{Gold}and 1x4/1 diseqc 1.1 {EMP-Centauri}
For tests I also use 2x8/1 diseqc 2.1{EMP} and 1x2/1 diseqc 1.1{Strong},and work with Yumatu receiver.
Configuration in receiver for diseqc 4x4/1 is for every switch is on diseqc 1.0{commited} and 1x4/1 is for diseqc 1.1{uncommited}.It look like this:
Input diseqc 1.0 switch{4x4/1} Input diseqc 1.1 switch{1x4/1}
1.-A------------------------------1
2.-B------------------------------1
3.-C------------------------------1
4.-D------------------------------1
1.-A------------------------------2
2.-B------------------------------2
3.-C------------------------------2
4.-D------------------------------2
1.-A------------------------------3
2.-B------------------------------3
3.-C------------------------------3
4.-D------------------------------3
1.-A------------------------------4
2.-B------------------------------4
3.-C------------------------------4
4.-D------------------------------4
Pleas upload your photos, not link to them, as per the catagory description. Admin
satesco is offline   Reply With Quote
Old 21-09-2008   #49
If i have another Imaginary central satellite as i have today the result for the 33e would be mutch better ,i belive.But then i have to take away both 22w and 18w
Hi m8 Iv got a wave dish thay work good.With a monblock @ the ends of the bar you could add one more satellite @ each end.
satsid is offline   Reply With Quote
Old 13-10-2008   #50
LAURO2008's Avatar
My System: CTech 2100 Plus-Brown Penta 85 Fracarro-Inverto 0.2 db-Moteck SG-2100A-CAS 3 plus-Diablo Light 2.3
Exclamation 2 questions
Dear Hakon ,
you definitely inspired me....thank you .
I'm going to buy one but got 2 questions:
-I know the wave 90 does not have a diameter but what could it be according to you?
-Are U aware of diseqc Centauri 16 in 1 out ? What do you think about?
Thanks in advance
LAURO2008 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
[IMG] code is Off
Forum Jump
