Multifeed WFT-90 some modification done | |
| Member Join Date: 08-01-2008 Location: Sweden
My System: WaveFrontier T-90 16LNB Cathing 18 birds 22w-33e Dreambox7020 HDD 5 Spaun 420 1 SPAUN 410 In the satworld since 1991 |
Heres my baby,16LNB catching 18 birds.Located i south of Sweden 22w-18w-12,5w-8w-4/5w-1w-5e-7e-9/10e-13e-16e-19e-23,5e-28e-33e | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Very nice setup Hakon, welcome to the forum. ![]() What switching arrangements are you using?
__________________ | |||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Nice installation Hakon, must involve a great deal of switching circuitry! Llew | ||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m +Moteck motor.45E to 45W. 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | Yes, great setup Hakon, The switching does look interesting. You say in your profile that you have five Spuan 420 and one Spaun 410, I would have thought it would be the other way round. How's it all connected? Robbo | ||
| | #5 | ||
| Specialist Contributor Join Date: 23-07-2005 Location: S.Wales
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. 1m channelmaster elliptical 84-E dish,Dreambox 7025 200gb HD, Vbox-II. SS2 Card. 42" Plasma tv. | Very Nice! Imagine the fast channel zapping! | ||
| | #6 | ||
| Member Join Date: 09-07-2007 Location: Italy 39.24N - 9.18E
My System: Digiquest 6400 - Strong 6125 - Samsung DSR 9500ci 90 cm dualfeed 19°E + 13°E 110 cm dualfeed 1°W + 30°W | Very nice work. Hacon. Fantastic. ![]() Can i show this to my italian friends ? | ||
| | #7 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Just link to this thread tornadospada, it is publicly viewable.
| The Following User Says Thank You to rolfw For This Useful Post: | tornadospada (08-01-2008) |
| | #8 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Ooh very nice. I want one ![]() Although the switching involved makes me shudder - I had enough problems getting 8 lnb's working!
| | #10 | ||
| Regular Member Join Date: 01-01-2000 Location: Rainham, essex
My System: 90cm gregorian 5way zone2 | I just love these wavefrontier dish setups, nice one Hakon, Hakon any picture of the switch wiring conections? had this as my desktop pic for awhile once, 28e to 30w all twins! | ||
| | #11 | ||
My System: WaveFrontier T-90 16LNB Cathing 18 birds 22w-33e Dreambox7020 HDD 5 Spaun 420 1 SPAUN 410 In the satworld since 1991 | Hi there,here comes the switchdiagram.I made one in the beginning otherwise i will not know how to connect it all.And its correct its 5 SUR 420 ,as i have one 85cm dish at Hispasat 30w =17LNB.Now with all the Spaun 420 i can connect ewen more switches and LNB just to plug in,nearly no limits Sadly i had only 16 holder so futher i will try out with more LNB at my T-90. | ||
| | #12 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Very impressed Hakon, you have obviously modified the LNB holder rail, do you have any photos on how you did it and what holders you used?
| | #13 | |||
My System: WaveFrontier T-90 16LNB Cathing 18 birds 22w-33e Dreambox7020 HDD 5 Spaun 420 1 SPAUN 410 In the satworld since 1991 | Yes finally i solved the problem with the crappy plastic LNBholder.With my construction i can still use the original holder ,combined with the new rail. I also could get a longer LNBguide in an easy way when i used a tube. Now all LNB can be adjusted more exactly.They can all be adjusted in height,angle ,etc.And theres no problem anylonger with 5e-7e-9/10e,just two degrees makes no problem now. Some more pictures from the days im finding out "how to" | |||
| | #15 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Brilliant, I presume that the metal holders are standard, just the rail and rail mounts which were fabricated?
| | #16 | ||
| Regular Member Join Date: 15-01-2004 Location: Manchester UK
My System: 2.4mtr Channel Master Dish, Fracarro Penta 85cm Dish, 64cm Traix Dish with 4 multi LNB'S Sky HD, Dreambox 800, Dreambox 500, IPBOX 250, Sky HD and a mad wife ! | Great work Hakon ! To think here was me messing with just 6lnbs and a switch, makes me look even more daft now .What a way to make a first post. | ||
| | #17 | ||
My System: WaveFrontier T-90 16LNB Cathing 18 birds 22w-33e Dreambox7020 HDD 5 Spaun 420 1 SPAUN 410 In the satworld since 1991 | | ||
| | #18 | |||
Excellent, I understand. So that's a maximum of 64 then. Three is the maximum cascade level isn't it? | |||
| | #19 | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
That is a very elegant solution. Extremely well engineered. It is rugged weather proof and infinitely adjustable. Very well done.
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
| | #20 | ||
| The Consumate Dreamer Join Date: 01-01-2000 Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh | Very nice work. How does the dish compare to a motorised dish, is there a loss of signal strength?
__________________ I only believe stuff that comes straight from Mr. Horses mouthHelp build Satellites City! Help build the Satellites MiniCity - no downloads, no money involved, just a daily click onto the site. More details here: http://www.satellites.co.uk/satellite/717922-post1.html | ||
| | #21 | ||
| Member Join Date: 12-03-2007 Location: SW Ireland
My System: PACE PVR3 Sky+ 160GB, PACE DS440NB Sky Digibox, Comag SL65, Dell Dimension 8400 on XP connected to SkyDSL one-way sat broadband, Channel Master 80cms Dish aligned to Atlantic Bird 2 @ 8°West. | ![]() Excellent set-up! Makes me and my lidl dish feel so ashamed! ![]() How much did this all cost you? assuming you installed it yourself?.... Has visions of a maxed out credit card and a big delivery!! | ||
| | #22 | ||
My System: WaveFrontier T-90 16LNB Cathing 18 birds 22w-33e Dreambox7020 HDD 5 Spaun 420 1 SPAUN 410 In the satworld since 1991 | Excellent, I understand. So that's a maximum of 64 then. Three is the maximum cascade level isn't it? Im not shure of the maximum LNB as you can cascade the SUR 420 in Mode 1-2-3 and then an commited switch How does the dish compare to a motorised dish, is there a loss of signal strength? Im pretty shure that a 1m motorised dish is quite better,But i dont have the time to get coffe while the Spaun change satellite compared to the motorised dish.And i dont have problem with loss of signal just the weak satellite, 18w 22w and some transponders at 4w. How much did this all cost you? assuming you installed it yourself? Im not shure of the total cost.I have not done all at one time,had it for 3 years and the last upgrade this winter.I can only guess,650 EUR/506 GBP And yes its all done by myself. I offen get the questian why so many LNB and can you see something interesting at al these position?? And my answer is, I have done it because i can | ||
| | #23 | |||
![]() Regarding the motor being slow: I suppose they are slower than what you got, but it does not really take that long. Unless you switch from 30 west to 42 east all the time, it only takes a few seconds to switch from 19E to 1 west... Still, your setup looks great and I bet it is fun to flick channels
__________________ I only believe stuff that comes straight from Mr. Horses mouthHelp build Satellites City! Help build the Satellites MiniCity - no downloads, no money involved, just a daily click onto the site. More details here: http://www.satellites.co.uk/satellite/717922-post1.html | |||
| | #24 | ||
My System: WaveFrontier T-90 16LNB Cathing 18 birds 22w-33e Dreambox7020 HDD 5 Spaun 420 1 SPAUN 410 In the satworld since 1991 | Im have been thinking of getting a motorised dish as a complement.But im not shure yet.I had motorised before, 15-16 years ago .Not so fun to install ,maby better today with the ex Stab-Usuals.Today i like the fast zapping | ||
| | #25 | ||
| Super Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | Superb! Love the attention to detail. It looks extremely well put together. Where did you source the individual LNB holders?
