45e (if in sight & further) 42e 39e 36e 33e 28e 26e(1) 23.5e 19e 16e 13e 10e (9e) 7e 5e 1w 5w 7w 8w 12.5w 15w 18w 22w 27.5w 30w 43w 45w (and 58w if in sight)
You miss weak TP/ beams on some sats but not the whole sat... and the signals you do get are usually very strong just like
Sky... just set it up well and it'll do it.. they make an ideal dish to stick high up on a chimney on a motor just to get deep east/ west sats that a bigger dish can't see lower down.
Try the dish 'level' at 28.2e to max it out - unscrew some of the bolts and swing it round until its level while the motor is parked at 28.2e and hold it with a G clamp etc.. set the LNB to your zone. The scala rings in the LNBs are also offset for 28.2e as well as oval.
*only kidding about 7w.. te he
