Eurostar 1.3m on Diseq motor | |
| Member Join Date: 01-11-2007 Location: uk
My System: Dreambox 7000(Pli Image), Eurostar 1.3m dish with 0.2db LNB,OpenMedia 500 cs (dk Image),Skystar 2 DVB card+ProgDVB-S2EMUv1.28.1+VPlug |
This is my new setup, Its a Eurostar 1.3m dish on an SM3D12 Rotor, Linked into my Dreambox 7000 and loopthrough to Skystar 2 in PC. | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | looks good, are those dishes heavy as i've seen them on Ebay | ||
| | #3 | |||
Motor doesn't seem to struggle turning it, and yes they are about £80 on Ebay | |||
| | #4 | |||
| Specialist Contributor Join Date: 23-07-2005 Location: S.Wales
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. |
![]() Nice set up djsimo | |||
| | #5 | ||
| Regular Member Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband! | Hi I dont know this motor type,is this a diseqec motor,with size of a 24" superjack,and no normal diseqec? | ||
| | #6 | ||
| Information Exec Join Date: 07-05-2007 Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | It looks like a clone of a SAT CONTROL SAT TRACER 3 as seen here: _http://www.satsol.co.uk/ProductDetails.aspx?itemno=C14883 Nice set up
__________________ - .....A Detailed DiSEqC Motor Installation Set Up Guide HERE Motor Installation 'Quick' Reference Guide also HERE Satellites UK site Advertisers - | ||
| | #7 | ||
My System: Dreambox 7000(Pli Image), Eurostar 1.3m dish with 0.2db LNB,OpenMedia 500 cs (dk Image),Skystar 2 DVB card+ProgDVB-S2EMUv1.28.1+VPlug | Its a diseq usuals motor from s*doun now discontinued link below gives full spec but no longer available h**p://www.s*doun.com/Sat/Products/SATCONTROL/Satcontrol-HH-diseqc-usals-MOTOR-SM3D12.htm | ||
| | #8 | ||
| Guest
Posts: n/a
| these dishes are good the are oem dishes and are made by jonsa it is the same as the fortec star the real size of the dish is 1.2m but eurostar say 1.3m which is wrong as all 1.2m dishes are 1.3m high and 1.2m wide, The 1.5m version of this dish is also very good | ||
| | #9 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | rd100, do they have a polar mount for them as it would be better on one of them over diseqc motor | ||
| | #10 | ||
| Guest
Posts: n/a
| Yes you can get a polar mount for it all eurostar Scorpio and fortec star dishes are oem jonsa dishes you can also use them with the 1224 mount, both the 1.2m and 1.5m are very good the 1.2m is better than the 1.2m andrew some people sell them as 1.3m and 1.6m but they are not they are 1.2 and 1.5m dishes | ||
| | #11 | |||
| | #12 | |||
__________________ Roiders are like the sun, big, orange, and never stare directly at them | |||
| | #13 | |||
| Guest
Posts: n/a
| yes also sold as 1.6m dish but really a 1.5m as it is 1.5m wide x 1.6m high
| The Following User Says Thank You to For This Useful Post: | CROSSBONES (18-09-2008) |
| | #14 | ||
| Design Engineer/Installer Join Date: 08-08-2007 Location: Central UK near Jodrell
My System: 75e-75w C & KU, 36v diseqc Anlg to HD Channel Master C120 dishes, stbs, lnbs, motors, too much to list | £60 p&p oops... How thick is the steel? | ||
