new set up | |
| Part Timer Join Date: 05-10-2005 Location: that would be telling
My System: DreamBox 800HD DreamBox 7025 PVR160g HD,500s Dreambox ,Sly+ Full Package,SkyCard 2, And a Eagle 500 Clone DM500 TM755,TM9100 Linux Channel Master 1.2m,1224EL Supermount Orbit Tracking Motor With c120 Feed Horn Invacom Quad Lnb Cas3 SC Dragon Progr |
new set up two channel master dishes not finished yet.
__________________ If it is not broke fix it till it is | ||
| Roider Join Date: 23-07-2005 Location: S.Wales
My System: 1.2M & 90cm and 55cm Gregorian Dish`s, Dream box 7000,160Gb HD,7025 200gb HD, Vbox-II. SS2 Card. 42" Plasma tv. | how big is the little dish? Where did you get it? Nice mount, What happened to the white sculpure? ![]()
__________________ Roiders are like the sun, big, orange, and never stare directly at them | ||
My System: DreamBox 800HD DreamBox 7025 PVR160g HD,500s Dreambox ,Sly+ Full Package,SkyCard 2, And a Eagle 500 Clone DM500 TM755,TM9100 Linux Channel Master 1.2m,1224EL Supermount Orbit Tracking Motor With c120 Feed Horn Invacom Quad Lnb Cas3 SC Dragon Progr | got the little dish off flea bay about a year ago was a broadband sat so i changed the lnb cost me a tenner good buy think it is a meter by 85cm. my m8 made the mount from 75mm pole section and 3in angle iron it is solid as a rock reason for new mount moved house was happy with the old monster mount lol. the other mount is being moved to make way for a new shed god help them with that.
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: triax td88 motorised, Vantage x221tsci, tms-1500ci, skystar 2, diablo v2.3, zone 2 minidish - setanta | what satellite is the dish pointing to in the picture as it looks very low or had you not aligned it up | ||
| | #5 | ||
My System: DreamBox 800HD DreamBox 7025 PVR160g HD,500s Dreambox ,Sly+ Full Package,SkyCard 2, And a Eagle 500 Clone DM500 TM755,TM9100 Linux Channel Master 1.2m,1224EL Supermount Orbit Tracking Motor With c120 Feed Horn Invacom Quad Lnb Cas3 SC Dragon Progr | it was just rested on the mount not wired up yet run out of light all working great now the small one is for 28.2 the big one so far 30w 33e.
| | #6 | ||
My System: triax td88 motorised, Vantage x221tsci, tms-1500ci, skystar 2, diablo v2.3, zone 2 minidish - setanta | what motor is the dish on as it looks like you got the elevation actuator , something like the 1224 el motor ? that dish looks massive, i only have the 90cm size channel master and it still looks massive but the 1.2 is very large | ||
| | #7 | ||
My System: DreamBox 800HD DreamBox 7025 PVR160g HD,500s Dreambox ,Sly+ Full Package,SkyCard 2, And a Eagle 500 Clone DM500 TM755,TM9100 Linux Channel Master 1.2m,1224EL Supermount Orbit Tracking Motor With c120 Feed Horn Invacom Quad Lnb Cas3 SC Dragon Progr | yes m8 1224 motor with orbit tracking and had a bracket made did not like the way it came with the dish set up. makes life a lot easier with the orbit tracking too.
| | #8 | ||
My System: triax td88 motorised, Vantage x221tsci, tms-1500ci, skystar 2, diablo v2.3, zone 2 minidish - setanta | i just bought the standard 1224 as i thought the orbit tracking would be useless on my small 90cm antenna and plus it was cheap at 85 quid compared to what uk websites was selling it for how far east and west can you go, as i think you get limited with the orbit tracking motor to the west is it ? | ||
| | #9 | |||
| ASBO Club Member - Persona non grata Join Date: 10-09-2007 Location: Tunisia, Prince Of Persia
My System: None |
If you installed the motor correctly you should peak all satellites at max signal level. An elevation motor only comes usable when you have dish of 3 meter or above as the beamwidth is so narrow and the ground is moving a bit which makes it necessary | |||
| | #10 | |||
i have had a bracket made so it does not affect the move of the dish east or west plus you can extend the limits when you move the limits in the motor.
__________________ If it is not broke fix it till it is | |||
| | #11 | ||
My System: 1.2M & 90cm and 55cm Gregorian Dish`s, Dream box 7000,160Gb HD,7025 200gb HD, Vbox-II. SS2 Card. 42" Plasma tv. | Where did you get the adaptor for the C120 lnb for your 1m channelmaster dish matey? As im after one ![]() Channel master Vsat feed
