TRIAX TD88 vs FRACARRO PENTA 85 | |
| | #26 | |||
| Information Exec Join Date: 07-05-2007 Location: Midlands - UK and Lanzarote - Canary Islands
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N |
I used a 0.3dB Invacom Twin. SM
__________________ - .....A Detailed DiSEqC Motor Installation Set Up Guide HERE Motor Installation 'Quick' Reference Guide also HERE Satellites UK site Advertisers - | |||
| The Following User Says Thank You to satelliteman For This Useful Post: | satkitten (07-08-2008) |
| | #27 | ||
| Member Join Date: 16-03-2008 Location: North Cornwall, England
My System: Darkbox2007, Darkmotor, Fracarro 85cm, Progdvb for 4:2:2 60cm Sly, 80cm Sly, 60cm, 19E |
nope..not had time for a scan over there yet..with the weather and me gammy leg (aww poor me!) and now im back into shifts till next monday mornin.....then four days for for a play...ill report back...hope to fine tweak it all up......but me thinks she will get me to do the bathroom decorating done first .. oh well...ill get back next week...thanks guys.quick update 20:43BSt....just had a quick scan of that sat...most tps seem to be 40% with that particular TP only 27% with dropout...weather is pretty fine.....maybe when i fine tune i can get db or two more....is it worth watching..or is it just arabic channel? cul UPDATE 2 2049bst....MY POLE IS BENT !! JUST WENT TO FLEX DISH TO SEE IF ITS OUT OF ALIGNMENT...ON PULLING ME SUPPOSIDLY HORIZONTAL POLE BACK A TAD I GET 35% AND SOLID SIGNAL..OOH A FILM IS ON....MUST FINE TUNE AND ADJUST IF ITS BRIGHTER NEXT WEEK.....
__________________ Darkbox 2007, Dark Motor, Fracarro Penta 85cm dish, Strong SRTL916 0.2lnb ProgDVB using Motor and Dish (for 4:2:2 feeds) Last edited by satkitten; 07-08-2008 at 08:49 PM. Reason: my pole is bent!! | ||
| | #28 | ||
had a quick lood last night...the pole is hardly off centre at all ..i think i may have set the motor elevation slightly off....ill play later....ill delete all these posts later too...or if im not allowed perhaps satelliteman can do it..to tidy up this thread ...as my likkle messages are kinda takin over?....then ill post a new update when i finished realligning...tonite hopefully as its lovely out right now.. tks guys..mikey update 21:15.....moved motor elevation from 51n to 50.3 ish north....readjusted dish...seem to get better arc now...32% on mbc tps......final post.....cant delete if required
__________________ Darkbox 2007, Dark Motor, Fracarro Penta 85cm dish, Strong SRTL916 0.2lnb ProgDVB using Motor and Dish (for 4:2:2 feeds) Last edited by satkitten; 08-08-2008 at 09:17 PM. Reason: update | ||
| | #29 | ||
| Regular Member Join Date: 29-02-2004 Location: Tyne and Wear
My System: 85cm transparent dish 0.2db lnb titanium wf100 cable dreambox500s technomate 9100 linux Eaglebox UK nds card | going to buy a 85 cm brick colour Fracarro from eb@y
__________________ Nice but Dim | ||
| | #30 | ||
you wont regret it....mine is doing a wonderful job at holding pictures and sound during bad weather on 12.5w 10e and 7e feeds....
__________________ Darkbox 2007, Dark Motor, Fracarro Penta 85cm dish, Strong SRTL916 0.2lnb ProgDVB using Motor and Dish (for 4:2:2 feeds) | ||
| | #31 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Why not buy from one of our forum supporting advertisers, one of them is a Fracarro distributor.
__________________ | |||
| | #32 | |||
| Irregular Member Join Date: 07-05-2008 Location: Ireland 55 N, 8 W
My System: DM 600 PVR with HDD. Gemini 4.40, Moteck SG2100, Fracarro Penta 85 dish, + some puters | As a past customer, I would recommend them. | |||
| | #33 | ||
My System: 85cm transparent dish 0.2db lnb titanium wf100 cable dreambox500s technomate 9100 linux Eaglebox UK nds card | I will do fella's when I get paid on Monday
| | #34 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: triax td88 motorised, Vantage x221tsci, tms-1500ci, skystar 2, diablo v2.3, zone 2 minidish - setanta | i wish they would do a larger version of this dish, then i would get one why not an 105cm version ? | ||
| | #35 | ||||
__________________ | ||||
| | #36 | ||
My System: 85cm transparent dish 0.2db lnb titanium wf100 cable dreambox500s technomate 9100 linux Eaglebox UK nds card | on the subject of the Fracarro aluminium and the steel....i presume that the quality is the same.....just the actual weight?
| | #37 | ||
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | Also the aluminium version should last longer and not rust. I have only ever used the Penta steel dish and they weren't that heavy. I believe Rolf has used both versions
| | #38 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Yes, purely a weight issue if you take corrosion out of the frame.
| The Following User Says Thank You to rolfw For This Useful Post: | dasteelman (3 Weeks Ago) |
