Fracarro Penta 85cm Reception @ 55 North 8 West
Thread Tools Display Modes
Old 23-07-2008   #1
Irregular Member
compufunk's Avatar
My System: DM 600 PVR with HDD. Latest Gemini Image, Moteck SG2100, Fracarro Penta 85 dish, + some puters
For anyone who is interested, I have attached a spread sheet listing what I am pulling in with the Fracarro Penta 85cm @ 55 North 8 West (North Western Ireland). Motorized 30W to 57E.
The Kit: Fracarro Penta 85cm,Fracarro Single Universal LNB 0.5, Motek SG2100 all hooked up to a DM600 PVR, The only reason its up so high is to clear a few trees,
I am happy with reception and am pulling in some stuff that I thought would be borderline, even in the rain.
The whole (Dish / motor / lnb) kit was bought from highdefinitionuk, recommended
If anyone wants any detail on signal quality on any transponders within my arc I'll check them out for you.
C
fracarro-penta-85cm-reception-%40-55-north-8-west-img_0007-jpg
compufunk is offline   Reply With Quote
The Following User Says Thank You to compufunk For This Useful Post:
dasteelman (25-07-2008)
Old 23-07-2008   #2
rolfw's Avatar
Nice installation, they are a nice compact dish and certainly punch above their weight.
__________________
Rolf
Donate
Old 23-07-2008   #3
Information Exec
satelliteman's Avatar
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W
Looks a tidy installation - such a professional dish with a Moteck, they were made for each other
__________________
A Detailed DiSEqC Motor Installation Set Up Guide HERE
Motor Installation 'Quick' Reference Guide also HERE
Old 24-07-2008   #4
Irregular Member
compufunk's Avatar
Thanks guys, I had some fun putting it up,
I discovered that there was a wasps nest in the roof and all the traffic was buzzing past my face while installing, Had one go into my ear at one stage, not a nice experience when perched up on a ladder
Old 24-07-2008   #5
sg_
My System: 45w-45e 80cm DM500-S
Looking good. What sort of reception do you get on the Russian channels on 53e with your setup?
sg_ is offline   Reply With Quote
Old 24-07-2008   #6
Irregular Member
compufunk's Avatar
I'm only picking up a hand full of services there, I'll take a closer look this evening.
Old 24-07-2008   #7
wod
My System: triax td88 motorised, Vantage x221tsci, tms-1500ci, skystar 2, diablo v2.3, zone 2 minidish - setanta
looks good and neat
i shall have pics of my new system next week too, anyone else got some to put up ?
Old 24-07-2008   #8
Information Exec
Originally Posted by wod View Post
looks good and neat
You getting a PENTA ...........Wod? as you showed some interest to my signal Results
__________________
Old 25-07-2008   #9
Irregular Member
compufunk's Avatar
53ºE
I'm getting high signal strength (80+) and good quality at between 80% and 95% on the following TPs,
Sorry I didn't get around to noting which were at 80% and which at 95%,
11630 V
11616 V
11161 V
10974 H
Does anyone think I should be picking up more?
Old 25-07-2008   #10
My System: Passion HD Diablo CAM Sky Star 2 PCI Sky +
Have you tried getting signals from 21.6E with the Penta 85 ? I can get Radio Euronics (11617 V 27500) and CFI Peco Pro (11586 V 6511) on my battered old 90cm mesh dish here in Glasgow.
I hope to replace my dish soon and was considering the Penta 85 or Triax TD88. Any opinions on which is the better option or even suggest another good budget dish (90cm max), thanks.
Ratchet is offline   Reply With Quote
Old 25-07-2008   #11
Irregular Member
compufunk's Avatar
I'm not picking anything up from 21.6E, I'm not even sure that I scanned it, I'll have a look this evening.
The consensus seems to be that the Fracarro Penta 85 out performs the Triax TD88.
A few recent threads,
TRIAX TD88 vs FRACARRO PENTA 85
Fracarro Penta 85cm VS Triax 88cm
Ratchet (25-07-2008)
Old 25-07-2008   #12
The consensus seems to be that the Fracarro Penta out performs the Triax.
Thanks for the links, I'll check them out later. Would be really interested in any results you get from 21.6E as this is the weakest signal I currently get with my old dish.
Old 27-07-2008   #13
Irregular Member
compufunk's Avatar
Have you tried getting signals from 21.6E with the Penta 85 ? ..........
Sorry for the delay,
All I can get off 21.6ºE is "CFI Peco Pro" on 11586 V.
Thats not to say you wouldn't pick it up where you are. But, we are are in and around the same reception area for that beam according to lyngsat.
Old 27-07-2008   #14
Thanks, that's good to know. I only just get these channels with no margin for rain fade. Can I bother you to clarify something else for me, do you get the MBC channels off Badr 4 11919 H 27500 3/4 ? I don't see these in your list and wouldn't want to lose them if I went for the Penta.
I have a couple of questions about the dish itself....
1. I assume the unusual shape has an effect on efficiency, does it lose gain on a motorised system when it is at the extremes of the arc. My concern is that as the dish will be skewed off square will it lose any efficiency. After all it is that shape for a reason !
2. Is it worth getting the aluminium version over the steel one ?
Old 27-07-2008   #15
Information Exec
Point1 > You shouldn't lose much if installed correctly. Although the PENTA is a 85cm, if you measure the dish width way, it's 98cm wide.
Point2 > Aluminium would be light in weight and last longer (recommended I suppose)..... but the steel version is still only around 7Kg - 8Kg.
Check my test results on the penta - penta Vs Triax for example
THE PENTA WILL OUT PERFORM THE TRIAX BY A MILE ............
SM
__________________
Old 27-07-2008   #16
Thanks, didn't realise it was that wide.
Thought that might be the case, so no difference in performance then. My current dish is 15 years old and a bit rusty so might fork out a bit extra for the aluminium one.
SM
Already have, good work.
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
