My motorised setup | |
| Member Join Date: 04-01-2006 Location: Northern Ireland
My System: 45w-45e 80cm DM500-S | Its an 80 cm (unbranded) and I have reception from 45e to 45w. I think the garage is in the way for anything further than 45e .Twin output LNB, one goes through the motor to my reciever for control, and the other goes directly to my dvb-s2 pci card. Other than that, its nothing really too fancy. Some pics are below of the dish at 45 east and 45 west along with a few of the underside showing the wiring. Thanks | ||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | Nice pictures ![]() Just one thing though, I wondered why you have put the wall bracket on upside down? I think I would be a bit worried that should the nuts come a bit loose, someone is going to get donked on the head. Robbo
__________________ | ||
| Regular Member Join Date: 09-02-2008 Location: Newtownabbey, near Belfast, Northern Ireland
My System: Dreambox 800 Nabilo Blackhole v0.3/250 Gig/ Dreambox 500s-(clone) PLi Jade/ Relook 400s 160 Gig-/AbCom Enigma Foretec 90cm Dish with Nikkai Diseqc Motor- 2 sky+ receivers fixed 28.2 east. | This looks quite like mine and although i have put my bracket the way you suggest the recommended way to have it is the way he has fitted it, as any water runs out the bottom and does not pool in the bend of the bracket. | ||
| Information Exec Join Date: 07-05-2007 Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | The L type stand off is up side down although it doesn't really matter .............best hope your nuts don't become loose .......... ![]() Neat job, WD
__________________ - .....A Detailed DiSEqC Motor Installation Set Up Guide HERE Motor Installation 'Quick' Reference Guide also HERE Satellites UK site Advertisers - | ||
| | #5 | ||
My System: 45w-45e 80cm DM500-S | Thanks. Dont worry, they are on tight enough and it has been up for over 1 year already ![]() I really hope to upgrade it sometime sometime within the next 6 months to something better | ||
| | #6 | ||
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | Get yourself a couple of 12 inch TK brackets when you upgrade
