Problem with LNB polarity | |
| Member Join Date: 04-09-2008 Location: Laois , Ireland
My System: Skystar 2 , 90cm Dish Pace Digibox , Zone 2 Dish 42" LCD |
Heres a few pics of my humble set up. Im trying to pick up W3A 7e for broadsat sattorrent internet.I have an 80cm lidl dish hooked up to a Skystar2 pci card.The best signal that I can get is 63% quality and 8db SNR. I can only pick up this signal when the LNB's skew is at around 80 degrees (See pictures) Transponder settings are 11262Mhz Frequency : 1512mhz Symbol Rate : 27531kS/s FEC : 3/4 Polarity : Horizontal/Left (High) I was told that because the transponder is Horizontal that this is why my LNB has to be at such an extreme angle, Is this correct ? Also I get a lot of rain fade and signal drops to around 40% and SNR of 6 - 7dB and I start getting BER readings. Anyone any Ideas what can be done ? | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | No, your LNB should sit slightly off the vertical at about 7 o'clock as you look from behind the LNB towards the dish, what are your satellite and LNB settings for your Skystar card, have you set the LNB to Universal with voltage switching for polarity? Can you receiver the channels on 11283 V like M6 Suisse?
__________________ | |||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | There should be more basic settings like switching frequency, LNB type etc, but in any event, the LNB needs to be set as per my picture above.
| | #5 | ||
My System: Skystar 2 , 90cm Dish Pace Digibox , Zone 2 Dish 42" LCD | Yeah I realise the LNB should be the way you illustrate , but what i cant figure out is when it is vertical , there is no possible way that the skystar will pick up the transponder that I need.Here is a screencap from the Skystar2 control panel | ||
| | #6 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | There is another panel of settings, it'll show the type of LNB and switching settings. But you didn't answer my other question, can you get M6?
| | #7 | ||
My System: Skystar 2 , 90cm Dish Pace Digibox , Zone 2 Dish 42" LCD | OK I think I found it.The settings that are there are the ones recommended by Eutelsat though. How would I go about getting M6 ? Last edited by Johnmorrin; 05-09-2008 at 08:28 PM | ||
| | #8 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Have you installed the TV viewer? there should be another setting which decides the type of LNB.
| | #9 | ||
| Member Join Date: 07-11-2005 Location: Glasgow
My System: Passion HD Diablo CAM Sky+ HD Sky Star 2 PCI | To get a horizontal signal with your LNB in that position implies that your card isn't sending the required voltage to switch the polarity. Are you able to get any vertical transponders with the LNB in that position ? There is a strong vertical data transponder at 11351 with a SR of 8571. You may have to add it manually as it doesn't appear in Setup4PC by default. Whilst on the 11262 transponder, what happens if you change the polarity setting to vertical when in 'Edit Transponder' mode ? Note that you have to click on 'OK' for the change to take effect. If nothing happens (i.e. the signal remains) then the card is not putting out the correct voltage to the LNB. By the way, 63% signal quality with a Skystar 2 is actually quite good. The SS2 is notoriously mean with its signal readings. This would equate to 90% on my other sat boxes. Last edited by Ratchet; 05-09-2008 at 09:52 PM Reason: Clarity | ||
| The Following User Says Thank You to Ratchet For This Useful Post: | Johnmorrin (07-09-2008) |
| | #10 | ||
My System: Skystar 2 , 90cm Dish Pace Digibox , Zone 2 Dish 42" LCD | Ok I think ive found something.I got back out on the roof , in the pi$$ing rain no less and rotated the LNB back to where it should normally be.Went back inside and the satellite signal was gone , I then changed the polarity setting to vertical , and the sat locked on.Why would broadsat tell me to use the horizontal setting though ? | ||
| | #11 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Don't use dollar signs in your posts, as a new member the spam trap catches them and puts the post into a moderation queue. ![]() Sounds like your LNB commands are incorrect, or the LNB polarities are reversed. That's why I want to see the LNB setup menu, it should be 13v Vertical and 18v Horizontal.
| | #12 | ||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | It does not apear that they have given you the wrong details, lyngsat only lists a horizontal transponder at that frequency, and I can find no signal with vertical.
| The Following User Says Thank You to Robbo For This Useful Post: | Johnmorrin (07-09-2008) |
| | #13 | |||
| Information Exec Join Date: 07-05-2007 Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N |
The O/P skew setting it was on compared to the new setting (about 7 'O Clock) is about a 90 º turn which will give the opposite polarity
__________________ - .....A Detailed DiSEqC Motor Installation Set Up Guide HERE Motor Installation 'Quick' Reference Guide also HERE Satellites UK site Advertisers - | |||
| The Following User Says Thank You to satelliteman For This Useful Post: | Johnmorrin (07-09-2008) |
| | #14 | ||
My System: Skystar 2 , 90cm Dish Pace Digibox , Zone 2 Dish 42" LCD | OK i read all the manuals for my card , and there is no setting for LNB voltage or polarity.I did a bit of looking on the net and found this : The power converter on the Skystar2 card who converts the 12V PC voltage of the 13–19V power for the LNB is not overload protected and can easily be damaged by a shortcut in the coax cable or F connectors or a stalling or heavy turning DiSEqC motor. When the overload last long enough a coil in the power line becomes very hot and becomes defective. This coil has to prevent that the 22KHz tone for the low/high band switching in the LNB flows into the converter instead of controlling the LNB band switch. With a damaged coil the level of the 22KHz signal on the coax is depending on the decrease of the inductance of the coil, so sometimes one LNB will still switch while another one stays at the low band. Due to the overheating mostly some windings of the coil become shortcut so decreasing the inductance of the coil. The voltage on the line is still correct, the polarisation switching controlled by the 13–19V on the line will still work, but the low/high band switching will fail. So only low band transponders will be scanned. I wonder is this my problem ? | ||
| | #15 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Could be, but there will somewhere be an LNB setting in the software menu, there certainly was when I used a Skystar. If you are only using it for that one transponder, then just skew the LNB for the best reception, it could of course be the LNB which is faulty.
| | #16 | ||
My System: Skystar 2 , 90cm Dish Pace Digibox , Zone 2 Dish 42" LCD | Maybe it was older drivers that you were using ? Dont think its the power converter either , just pulled the skystar from the pc and mine is listed as revision 2.3 and i think its only the revision 2.6 card that has this problem.Yeah im only going to be using this dish , lnb and skystar for Sattorrent so once it picks up that transponder fairly well then ill be happy.Oh yeah , i already tried changing to a different lnb and its still the same.Tried the cable too | ||
| | #17 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | How do you tell it what LNB you are using?
| | #18 | ||
My System: Skystar 2 , 90cm Dish Pace Digibox , Zone 2 Dish 42" LCD | | ||
| | #19 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | You don't understand, there is more than one type of LNB, so there must be a panel in the software in which you define the LNB parameters.
| The Following User Says Thank You to rolfw For This Useful Post: | Johnmorrin (07-09-2008) |
| | #20 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Whilst awaiting a reply from the OP, regarding the difference in SS2 versions - Revision 2.3 has a fuse (F1) which revision 2.6 singularly lacks. I don't know the reason for this omission, and without it any short circuit in the LNB feed will usually fry the choke. This happened to me owing to a faulty A/B switch, and I had to rewind the choke. Pic 1 is the 2.3 board, with fuse F1. Pic 2 is my repaired 2.6 board ![]() Llew | ||
| | #21 | ||
My System: Skystar 2 , 90cm Dish Pace Digibox , Zone 2 Dish 42" LCD | Was the problem that you had similar to mine Llew ? Ive checked my card , and its revision 2.3 and looks the same as your first picture that has fuse F1. May check this fuse later with the multimeter. Last edited by Johnmorrin; 06-09-2008 at 02:51 PM | ||
| | #22 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | No, not the same problem. My choke didn't open circuit, just a dead short. This allowed H/V switching, but I lost the DiseqC signals, as the choke is there to buffer the DiseqC line from the voltage switching circuitry. You seem to be having a problem with the H/V switching if I read right, but as Rolf said, unless you can show us a panel that gives the LNB parameters, it's difficult to know what your problem is. What application are you using? The Setup4PC that comes with the Skystar? Better to use progDVB or another viewer that has an LNB options menu that will give us a clearer picture. Llew | ||
| | #24 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | That's fine, you're set up for W3A using a Universal LNB. It's back to making sure your dish is correctly aligned on the satellite and you are sending the correct voltages to your LNB. Use a short lead terminated with F plugs to check the voltages at the LNB terminal while switching to a V and H channel (don't short the lead out with your multimeter!) | ||
| The Following User Says Thank You to Llew For This Useful Post: | Johnmorrin (07-09-2008) |
| | #25 | ||
My System: Skystar 2 , 90cm Dish Pace Digibox , Zone 2 Dish 42" LCD | Ok I got the problem sorted.The problem was ME , I had it pointed at the wrong satellite .Guess its one of those newbie mistakes , ive only had the setup a week and still getting to grips with the technical side and all the lingo .Signal is still fairly low , but I think thats because of the crappy lidl dish , one of my mates is giving me a 90cm old sky analogue dish for free on wednesday.Maybe that will help a little with the rain fade and wind.Those lidl dishes are a little flimsy.Thanks to all those that helped me | ||
