This thread was started to show LNBs internals - If you have a dud etc.. why not pop it open and photo it's workings... !
If you do open a working one (not a really good one though....), it's up to you, it should go back OK (hmm), especially if it's an all screw type - reseal it with acrylic mastic (not water based) and do it in as warm/ dry an atmosphere as possible. The LOs might need tweaking though.
This first one is the older big case Grundig
Sky LNB .7db ..
PIC 1# = the two LOs on the right are fine adjusted with the two screws on the left in the lid.. to the left is the lid with heavy shielding compartments when in place.
PIC 2#= the two LOs - obvious which is which (smaller 10600/ larger 9750).
PIC 3# = the pcb....... anyone want to break it down...
top left hole is where VERTICAL comes into a chamber (formed in the lid) and looks like it’s picked up by the antenna on the board
HORIZONTAL comes in, in the bottom left corner (solder blob)... both look like they greet switches (13v/18v?) and then combine their route...
Roughly… filters next… then the 22kHz switch to the LO HIGH or LOW band drop to the IF more filters… amp…... more filters ……….and out … ( something like that …anyone…?)
The pcb looks as though it uses board strips to form part of the filters/mixer system.... anyone?
ed--- just noticed the rather brutal way it had to be opened - hacksaw/ chisel /screwdriver (bottom right PIC 1#)... not easy that one as it's glued in place with mastic ... most are screwed...
Grundigs are very good build quality compared to most today apart from perhaps Invacoms... and do very well still regradless of the 0.7db figure.
