Originally Posted by pipino original crappy triagles from the motor |
I think we are at cross purposes here. I mean the top bracket on the motor shaft (see photos). When the motor arrived it was all loose and that tapered pin doesn't seem to fit too well. I'll have to wait and see if it comes loose again.
Originally Posted by pipino used gibertini´s Plate instead..works much better and looks rock solid when fixed |
That is a brilliant idea. The 100mm pole is too big for the motor. I had to grind the inside of the mount to get it to fit. I use a 100mm wheel so it is a perfect match. But with the universal U-bolts that come with the motor it is still a pain to adjust. Looking at yours I think I'll probably make the switch.
As for tracking the arc I think I'm getting pretty close now. My South was a bit off the other day. My meter comes back on Wednesday so I'm going to have another go at it then. At the moment, with the Lacuna meter, I can hit more than 20 satellites between 42E and 45W. The choice of transponders in the meter doesn't seem to good for this location. It can't see Nilesat at all. My receiver hasn't arrived yet either; I'm using a Darkbox at the moment (which can see Nilesat). It's pretty cloudy today but I'm still getting some Astra 2D (Transponders 42, 44, 46, 48, 52, 54, 56).
