Originally Posted by Ratchet Are you watching the encrypted version of Five on 2A ? The reason I ask is that the FTA version is on the same 2D TP as BBC 2 England. Also, have you tried the regional versions of BBC 2 on 11803 H. These obviously have regional opt-outs but not always at the same time. You might be able to see most programs if you switch between them. |
The problem is, in Madrid with a CM 1.2, I will only get a lock on horizontal transponders 41, 43, 45 , 47 etc until about 10am after that I will not get a good signal on the TP horizontal.
I am watching ITV1 etc all on the Vertical TP's
This means as far as I can see, unless you get a CM 1.8 in Madrid you will need a viewing card to watch Five on a 1.2.
This also means a Humax Foxsat will be no good for watching five either unless it uses a Vertical TP, so a viewing card is the only way I can go at prestent.
