Bits and bobs + 50€ motor = budget feed hunter
Upload your photos here (Don't link to them with img code, upload them), doesn't matter how basic your setup, it's nice to see what everyone is working with. If you've seen an interesting setup, then post it here. All photos here are copyright and cannot be used without permission of the poster.
Old 05-04-2009   #1
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4
I put this together mainly from bits and bobs I had lying around.
Foto index.
  1. Redundant 80 cm dish (previously used for Astra 2 South).
  2. Famaval ground stand (40 cm). Titanium Smart LNB.
  3. Getting the pole straight.
  4. Pole with MOT-SAT 3 motor attached.
  5. Testing dish movement with SatCatcher Excel-TV.
  6. LNB attached. SatCatcher is brilliant; it has USALS built in.
  7. Dish face on, set to due South.
  8. Side view.
  9. Pointed at 45ºE.
  10. Pointed at 45ºW.
  11. Pointed at 45ºW again.
  12. Double picture for scale compared to the Gibertini 1.5m.
Bits and bobs + 50€ motor = budget feed hunter-2-jpg   Bits and bobs + 50€ motor = budget feed hunter-3-jpg   Bits and bobs + 50€ motor = budget feed hunter-4-jpg   Bits and bobs + 50€ motor = budget feed hunter-5-jpg   Bits and bobs + 50€ motor = budget feed hunter-6-jpg
Bits and bobs + 50€ motor = budget feed hunter-7-jpg   Bits and bobs + 50€ motor = budget feed hunter-8-jpg   Bits and bobs + 50€ motor = budget feed hunter-9-jpg   Bits and bobs + 50€ motor = budget feed hunter-10-jpg   Bits and bobs + 50€ motor = budget feed hunter-11-jpg
Bits and bobs + 50€ motor = budget feed hunter-12-jpg   Bits and bobs + 50€ motor = budget feed hunter-14-jpg
Huevos is offline   Reply With Quote
The Following 2 Users Say Thank You to Huevos For This Useful Post:
divibi (04-05-2009), kwp58 (12-04-2009)
Old 05-04-2009   #2
satelliteman's Avatar
Real name: Paul
That's a nice install you have there, great pictures
satelliteman.
An Installers Choice
Follow us on
Old 08-05-2009   #3
Updated the dish
The 70 x 80 cm offset dish was missing too many feeds so I updated the dish.
Bits and bobs + 50€ motor = budget feed hunter-fibo-90cm-parked-58west-front-view-jpg   Bits and bobs + 50€ motor = budget feed hunter-fibo-90cm-parked-58west-rear-view-jpg
Old 09-05-2009   #4
wod
wod's Avatar
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+
yes larger the dish, the better if your viewing feeds, dont you have the 1.5m dish anymore ?
Old 09-05-2009   #5
Yeah I do... but that's the main system which the missus is in charge of it 95% of the time. The 1.5 is connected to a Vantage x221 TSCI used for digital terrestrial, and Sky using the latest unofficial patch so the NDS card works. That system needs the 1.5 so it is possible to receive (at least some) channels from Astra 2D.
The system in the pictures above is paired to a Manhattan Plaza XT-M at the moment. I want to be able to watch 4:2:2 feeds and was considering a Skystar card but due to the lack of blind scan and proper motor control I've decided against that. So it looks like a Linux box now. I toyed with the idea of an Eagle Box but apparently the motor control of that is also dubious. I'm not going to buy a dreambox due to the overinflated prices so now I'm considering one of the Technomate Linux boxes, although I'm not sure which yet.
Old 13-05-2009   #6
My System: 1M Dish
I would like to ask you a few questions about your black dish.
What is the round plate for on the end of it and what does it do?
What does the strange LNB on the arm of the dish do?
What is the size of the dish?
Is the Tripod stand bolted into the ground?
cooltv is offline   Reply With Quote
Old 01-06-2009   #7
It's the secondary reflector. You can read about Gregorian optics on Wikipedia. _http://en.wikipedia.org/wiki/Gregorian_telescope
It's just a regular LNB (Invacom QDF-031) and does the same as the LNB on every other satellite dish (converts received signal to a lower frequency).
90cm
No, it's bolted to the roof. If it wasn't it would blow over.
50€, 50€, bits, bobs, budget, feed, hunter, motor
[IMG] code is Off
