Originally Posted by bostephen What do you think?
I still have a problem though; stated here
_http://www.satellites.co.uk/satellite/multi-receiver-tv-systems/153413-multiswitch-vs-diseqc-switch.html#post850642 |
Stephen-
Is that a dual C/KU LNBF? Did you make it?
If so, I have two different makes and neither work good on KU when C Band is peaked.
What is your experience?
Diseqc operates from a serial data sent from receiver, 22Khz operates from tone on or off from receiver. If the receiver is powered on while moving cables you will ZAP that Diseqc port, time to get a new one.
If your KU lnbf is a Universal it has a built in 22kz switch, if a standard 10750 no switch. Your receiver would be configured for Diseqc first then 22Khz on or off second.
Maybe this will help; _http://www.satelliteguys.us/fta-mpeg2-faqs/133444-diseqc-1-0-1-1-1-2-1-3-whats-all-mean.html
