My home istall at my flat
Upload your photos here (Don't link to them with img code, upload them), doesn't matter how basic your setup, it's nice to see what everyone is working with. If you've seen an interesting setup, then post it here. All photos here are copyright and cannot be used without permission of the poster.
Old 10-09-2009   #1
Real name: John
My System: DISH ONE:-Sky HD on a Zone 1 dish with Quad LNB using x2 Connections @ 28.2 Deg. DISH TWO:- is single Zone one with a single LNB @ 19.2 Deg coupled to a Comag Porty II reciever for FTA german TV.
This is my flat. It's a block of 4. I live on the top floor on the right hand flat.
The pictures:- Let me explain....
Sat5.jpg :- Well, the right hand dish used to have the quad LNB on it and the dish was poined to 28.2 Degrees. When I installed the 2nd dish which on the pic is the left hand one, I was unable to get the angle needed for 19.2 Degrees. So, I swapped cables and LNB over and re aligned the dishes.
Sat2.jpg:- I live in a rented flat. The right hand dish was already there. I am not allowd to make ANY external mods that might damage the property. This does include putting holes in the walls and bricks. So, I undid the two left hand bolts on the right hand dish bracket and slid the left hand bracket under it and put the two bolts back in..
Sat1.jpg:- Shows the end result of my work....!
My advice here,
I had to remove the old two coax cables which were thick and nasty. now, you will want to put your new ones in. If you can eget hold of the sky man ask for some twin coax, This stuff is great, its very much thinner then the coax and all I did was taped the twin stuff to the old thick stuff and pulled it through.
My home istall at my flat-sat5-jpg   My home istall at my flat-sat2-jpg   My home istall at my flat-sat1-jpg
jonnybobs is offline   Reply With Quote
Old 10-09-2009   #2
satelliteman's Avatar
Real name: Paul
Nice install. Interesting wall fixing though (sat2.jpeg)
satelliteman.
An Installers Choice
Follow us on
Old 10-09-2009   #3
Toute Ronde Bon Oeuf
Tivů's Avatar
Real name: Gordon
So this is the beast referred to in your 19.2E/PVR Thread, then.
Ingenious solution so far .................
Twin Tuner reciver on 1 LNB @ 19.2 Degrees
Tivů is online now   Reply With Quote
Old 10-09-2009   #4
Sky Remote Breaker...
2cvbloke's Avatar
My System: Mostly gathering dust cos there's no room for dishes here... :(
The Sleepy Hollow pollracle has spoken!
Can I suggest giving your lens a wipe?
Nice install, and I like the 2-in-1 approach to the overlapped brackets, saves bolts I guess...
I think your car looks funny too......
Proud owner of a satellites.co.uk cap & T-Shirt...
(though the latter no longer fits due to my ever expanding waistline!!!)
Resident KIRBY Vacuum nut...
2cvbloke is offline   Reply With Quote
Old 14-09-2009   #5
Real name: John
Lets hop it holds up in the wind!!!! -- I'm not borrowing the ladders again. It was a 5 hour mission the last time.
Got the letting agency over on Weds for out three month inspection, lets see if they notice!?!
Old 14-09-2009   #6
Real name: John
Yup! It seemed logical to try and reuse the old not used "new" sky dishes that they seem to give away when you aske them. So, my dish was brand new as was the cableing but the LNB would you believe, I found beside a skip about 2 years ago.
I was quite surprised that using a zone one dish that I got as good a signal as I did @ 19.2 - My strength and Quality measure at 78% on that dish.
The sat finder is almost at the end of teh scale. So, I was happy. Remembering that the "looser" dish of the two in my pic has become the "sky" dish and the more fixed dish is my "euro" dish!
Old 23-09-2009   #7
My System: Sky+HD Astra+Hotbird FTA on 60 cm dish
Not too sure about the two bolts holding the dishes in place. Might have been better just to drill fixing holes for the second dish as they can always be filled with a clear silicone sealant if the dish needs to be removed.
Just shows how useful the Sky minidish can be with other high power satellites,my first non Sky system used a Zone 2 minidish.
streetlighter is offline   Reply With Quote
Old 23-09-2009   #8
GreenmanBelg's Avatar
My System: 1 x CM 1.2m matching C120 feedhorn and Invacom 0.3db twin output LNB.50 degrees East to 42 degrees West.1 x CM 1.2m AZ/EL mount matching C120 feedhorn and twin output Invacom 0.3db Humax VACI 5300 Old Panasonic Digibox with IRL $ky sub. Coship FTA
Wink
Nice work but clear pics would be easier on the eye.Thanks.
Regards JD Belgium.
GreenmanBelg is offline   Reply With Quote
flat, home, istall
[IMG] code is Off
