My humble setup
Upload your photos here (Don't link to them with img code, upload them), doesn't matter how basic your setup, it's nice to see what everyone is working with. If you've seen an interesting setup, then post it here. All photos here are copyright and cannot be used without permission of the poster.
Old 11-09-2009   #1
My System: Penta 85cm, Quad LND, DM8000,Nabilosat Blackhole v11.
My humble setup
1st ever install of anything outside like a satellite dish, have never even put an aerial up. Here is my attempt at installing a Penta 85cm and a TM-2600 Motor.
My humble setup-img_1526-jpg   My humble setup-img_1532-jpg   My humble setup-img_1533-jpg
Oakey22 is offline   Reply With Quote
The Following 2 Users Say Thank You to Oakey22 For This Useful Post:
doktorofsat (12-09-2009), Tivů (11-09-2009)
Old 11-09-2009   #2
Toute Ronde Bon Oeuf
Tivů's Avatar
Real name: Gordon
Very good indeed - I've been following your Posts with interest and they are an inspiration to others who might be considering DiY
Tivů is online now   Reply With Quote
Old 11-09-2009   #3
satelliteman's Avatar
Real name: Paul
Nice install.
satelliteman.
An Installers Choice
Follow us on
Old 11-09-2009   #4
LAURO2008's Avatar
My System: * Clarke Tech 5000 HD Combo Plus * Gibertini 104 cm * Invacom TNH-031 0.3dB * Diablo Light 2.3 + CAS 3 plus * motor GT SAT - DM15AT * 53°E - 58°W in USALS * Full HD LG Scarlet 42lg7000 * Western Digital HD TV Player *
Congratulations...it is simply great!
for a better
LAURO2008 is offline   Reply With Quote
Old 11-09-2009   #5
kenny1234's Avatar
My System: Motorised ASC 1.2m,1224 Supermount with C120 Invacom Quad LNB with Matched Feedhorn.
Good job!
What arc do you receive?
kenny1234 is offline   Reply With Quote
Old 11-09-2009   #6
Tivů's Avatar
Real name: Gordon
Originally Posted by kenny1234 View Post
Good job!
Probably the Clarke Belt .............
Old 12-09-2009   #7
Thanks for all the comments about the install, i can receive from 45W to 45E, well that is what the automatic scan picked up, i have channels on, 45w,43w,30w,27.5w,22w,18w,15w,12.5w,8w,5w,4w,0.8w, 3.1e,4.8e,7e,9e,10e,13e,16e,19.2e,23.5e,28.2e,31e, 33e,36e,39e,40e,42e and 45e
Old 12-09-2009   #8
Tivů's Avatar
Real name: Gordon
Excellent - subject to line of sight you might try 58W sometime: There are occasionally Sports Feeds on there.
Old 12-09-2009   #9
trying 58w now but i think the tree 3 doors down is in the way
Old 12-09-2009   #10
did not find any on that satellite
Old 12-09-2009   #11
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
You'll get the BT Towers on 11477H if you can see 58W - they are a permanent fixture on the satellite.
Llew is offline   Reply With Quote
Old 23-09-2009   #12
My System: Sky+HD Astra+Hotbird FTA on 60 cm dish
Thats a nice neat job you have done there, the cabling is excellent. And i like the odd shaped dish makes it less noticable than a round dish.
streetlighter is offline   Reply With Quote
Old 6 Days Ago   #13
Just a little update, i have been getting around 85% on the BBC channels on 28.4E, i got up the ladders again and rotated the lnb a little bit (skew?) i am now getting 97% on this sat and all the rest are increased aswell. So i am very happy with it now
Old 6 Days Ago   #14
Tivů's Avatar
Real name: Gordon
28E Birds have an element of pre-skew, uniquely.
I think this was done in order to facilitate design of the Sky type LNBs, which have only a limited skew adjustment.
So on a motorised dish it could be detrimental to adjust the LNB to optimise 28E as it throws out the skew on every other Satellite.
Generally, it's best to leave it at zero skew (Top Dead Centre for your South Satellite) and accept the slightly imperfect results on 28E: After all, 28E is string enough to cope!
But this is a hobby and the theory is just there to be ignored
Old 6 Days Ago   #15
i have noticed increases on all satellites, i actually re-aligned the skew on 1W but it happened to increase the signal on 28E aswell.
Old 6 Days Ago   #16
Tivů's Avatar
Real name: Gordon
Yes, I saw that in your earlier Post that you'd got across the board improvement, but I thought you'd done it at 28E - my apologies.
The only reason why all Satellites would be better now, purely as the result of tweaking Skew, is that it actually wasn't zero Skew at motor zero before.
But well done on gaining all round improvement
Maybe you could have another look-see at BT5 on 58W now .........
The slight skew error you had might have been the reason you couldn't get 58W earlier - It gets pretty darned critical at the very ends of the arc!
Go on - you know you want to
Old 6 Days Ago   #17
i do not have 58w in my satellites file no more, i will have to find a way of doing it.
Old 6 Days Ago   #18
i have now added 58W to my satellites.xml and done a scan, however it did not find any, i think it maybe due to me living in a valley and i am at the bottom of it or maybe the tree's that way on.
Old 6 Days Ago   #19
Tivů's Avatar
Real name: Gordon
Ok, thanks for trying
humble, setup
[IMG] code is Off
