Pictures of Members' Systems
Thread Tools Display Modes
Old 24-06-2006   #326
vmark's Avatar
My System: Nss6 (65cm) Optus B3,C1,B1,Pas8,Pas2,I701 (85cm) All Offset. Experimenting on 1.2mtr C-band.
With reference to the above mentioned link...
I was going to mount my dishes upside down for the same reason, to keep grubby little fingers away from the LNB's.
Also to stop yours-truly from knocking his melon off when mowing the grass!!
We only have one satellite that this would really be needed, NSS6 at 95 degrees West of Australia, but even that is only if the horizon became a big issue.
A few shots to salivate over? Enjoy, Mark.
****Sorry was meant to be posted in Members Set-Ups section****
pictures-members-systems-mv-image0001a-jpg-300x240-jpg   pictures-members-systems-mv-i701-c1-p8-2-small-jpg2 small.jpg
ID:	7099   pictures-members-systems-mv-nss-6-tv-ants-front-small-jpg TV Ants front small.jpg
ID:	7100   pictures-members-systems-mv-pas8-pas2-lnb-notes-small-jpg Pas2 LNB Notes Small.jpg
ID:	7101   pictures-members-systems-mv-pas2-8-array-small-jpg8 Array small.jpg
vmark is offline   Reply With Quote
Old 01-07-2006   #327
mike1's Avatar
My System: Sky Digital , Dreambox 500s, 60cm Dish (13e/19e)
here is my sky zone 2 dish pointed at hotbird located on the ground! I found the dish with very few fittings and screws but still managed to get it working. Im just using stones and a plant pot behind the dish to stop it from going out of alignment!!!
sorry if its a little too basic for this type of thread
pictures-members-systems-image_00025-jpg   pictures-members-systems-image_00027-jpg   pictures-members-systems-untitled1-jpg   pictures-members-systems-untitled2-jpg
mike1 is offline   Reply With Quote
Old 01-07-2006   #328
rolfw's Avatar
Nothing is too basic mike1, this is exactly what this section is about. We thrive on ingenuity and invention.
__________________
Rolf
Donate
Old 01-07-2006   #329
T_G
The Consumate Dreamer
T_G's Avatar
Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything.
Muhuhuhahahahahaaaaarrrgggh
Hi Mike
If it works, it works! I wish I had this signal strenth!
__________________
I only believe stuff that comes straight from Mr. Horses mouth
T_G is offline   Reply With Quote
Old 01-07-2006   #330
Post Meister
BarMoo's Avatar
My System: 2xPace 430N, 1xNokia MM9800, 1xNokia 80cm Sat Dish, 1xGibertini 120cm, Big Fat Furry Puss
I set up my SKY minidsih yesterday for Astra - (todays footie).
Got 70% signal (on the roof) and about 50% after 30m of feed cable. Signal Strength (on the roof) two blocks into Nokia Yellow - that's about 50%.
Footie went downhill though
__________________
Have Fun, Moo.
BarMoo is offline   Reply With Quote
Old 02-07-2006   #331
International Administrator
rato's Avatar
My System: DM800; Nokia 9800s; Nokia 9902S w/T-Rex 3.66 w/ Inverto IDLP-40TL + Technisat 33 dish; Pace DS430N + Humax HDCI-2000 w/ Gibertini OP 1.25m dish w/Inverto 0.3dB. & Invacom 0.2dB. w/ Spaun SAR 411; CAS 3;FUN7; SkyStar2; AltDVB;
Talking Finders keepers!
Hi mike1! Hey, it looks great! And if you made it work, your a happy camper!
__________________
rato is offline   Reply With Quote
Old 16-07-2006   #332
My System: Fortecstar 5100
45cm Dish on HH100 mount, perfect reception on almost all the satellites.
pictures-members-systems-sat1-jpg   pictures-members-systems-sat-jpg
anoor is offline   Reply With Quote
Old 16-07-2006   #333
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
Sounds pretty good for a 45cm. anoor.
What sats are you getting with your installation?
__________________
Llew is offline   Reply With Quote
Old 16-07-2006   #334
wod
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish
lol mini dishes look so funny on motors. surprised you can get a good reception, thought a zone 2 dish might have been better to use
Old 16-07-2006   #335
Ding Dang Doo
gameboy's Avatar
My System: DreamBox 7000s - Nokia Freeview - Several GameBoys - DS Lite - ZX81 - SNES - N64 - Sega Saturn Dreamcast - PlayStation - Gamecube - PSP - iPod - iPhone - XBox - PS3 - Wii - No Life!
Were you getting problems with water in the LNB?
Is that what the plastic bag is for?
__________________
Only he who does nothing, does nothing wrong.
gameboy is offline   Reply With Quote
Old 16-07-2006   #336
rolfw's Avatar
Looks like an old Sky Cambridge LNB without the plastic case.
Here's my first effort with a zone 2 dish a few years back, using the SM2UNI motor.pictures-members-systems-digisnap_0072trim-jpg
__________________
Rolf
Donate
Old 21-07-2006   #337
Yes, I removed the orginal plastic casing which is collecting water on the feed horn Mouth and blocking weaker signals, and also there is a tree in the path of Hotbird which is just about visible. I am pushing the dish up the pole when ever the signal weakens!!!
Old 26-07-2006   #338
Biggles does Greece's Avatar
My System: 1.7m Astra & 1m Hotbird dishes feeding Humax and Pace boxes
Lotsa Telly, A/C & Hot Water
Thought I'd show my two dishes not so much for their sake but for the view! If I spend only half an hour a day up here it does wonders for the tan.
The big 'un is not as big as I'd like, only 1.7m and no good for 2D. The other is a 1.2m looking at 19.2 and carefully seated to avoid damaging the recently laid insulation. I told 'em to leave the mounting holes open (next to the 1.7m) but my Greek was obviously not up to it.
The view out to sea is of Artemida Bay. We are just to the right of Athens' (new) airport.
We had a large fire behind us yesterday and I got very burnt (sun) hosing down everything the hose could reach. Next time an asbestos cap, I think.
It has been nice to see all the 2.4m dishes on this board, as one day......
pictures-members-systems-1-2m-19-2-jpg   pictures-members-systems-1-7m-vravona-hill-jpg   pictures-members-systems-solar-panels-1-2m-jpg   pictures-members-systems-scorched-earth-jpg   pictures-members-systems-looking-toward-marcopolo-town-jpg
Biggles does Greece is offline   Reply With Quote
Old 26-07-2006   #339
Llew's Avatar
Now that's what I call a view (2nd. pic)
Nice setup Biggles. Could do with that aircon over here...
__________________
Old 26-07-2006   #340
rolfw's Avatar
Nice pics and great view.
__________________
Rolf
Donate
Old 26-07-2006   #341
I'm gonna be in East Anglia tomorrow so I'll bring one with me! As the pikkies are there, I'd better caption 'em. The 2nd has the view of Vravrona which is a big hill hiding the port of Porto Rafti, the 4th shows part of the scorched earth that was an olive grove two days ago and the last one is (obviously) south, looking towards the town of Marcopolo. One & three are of the solar panels and 1.2m. I know the make of neither dish and would appreciate any help. The 1.2 was bought here in Greece and the 1.7 I bought 2nd hand of a guy who brought it in from Italy. Gilbertini perhaps?
Old 26-07-2006   #342
wod
the 1.2metre looks deffo like a gibertini cause of the lnb arm and no idea of the 1.7m dish
Old 26-07-2006   #343
Post Meister
BarMoo's Avatar
And just when I thought you had a couple of plasma TV's up there - one for each dish, LOL.
Joking.
__________________
Have Fun, Moo.
Old 02-10-2006   #344
My System: Thomson Sky+ PVR3, Pace 2200 Sky box, Zone 1 Triax minidish with Thomson Quad LNB, 1m Gibertini and Technomate TM-1500CI+ Super (Patched) 1metre Gibertini at Astra 1 19.2°e
here we go, my gibbi finally installed!
ID:	8598   pictures-members-systems-pict0542-large-jpg.JPG
ID:	8599   pictures-members-systems-pict0543-large-jpg.JPG
ID:	8600   pictures-members-systems-pict0544-large-jpg.JPG
martz is offline   Reply With Quote
Old 02-10-2006   #345
Ding Dang Doo
gameboy's Avatar
Above the conservatory - just like mine.
Sleepless nights during storms then.
__________________
Old 02-10-2006   #346
rolfw's Avatar
Looks good martz, apart from the T&Ks being the wrong way around, T should be at the top, having said that, I normally use two K brackets and a T for that sized dish.
__________________
Rolf
Donate
Old 02-10-2006   #347
wod
nice one martz
the back plate on the dish looks massive
how far above the gutter have you got the dish ?
also what fixings did you use ?
Old 02-10-2006   #348
Ding Dang Doo
gameboy's Avatar
LOL - That could make you even more nervous!
__________________
Old 02-10-2006   #349
oh, i didn't realise, is it a problem? yeah it is huge, the bottom of the dish starts just under the gutter and the rest is about 90cm above, i just used m6x50 coach screws with some washers, its more stable than it looks!
Old 02-10-2006   #350
rolfw's Avatar
It should be strong enough, but I always like to over compensate. If you do eventually add a motor, then put another K bracket in the middle.
__________________
Rolf
Donate
