Pictures of Members' Systems
Upload your photos here (Don't link to them with img code, upload them), doesn't matter how basic your setup, it's nice to see what everyone is working with. If you've seen an interesting setup, then post it here. All photos here are copyright and cannot be used without permission of the poster.
Old 02-10-2006   #351
My System: Thomson Sky+ PVR3, Pace 2200 Sky box, Zone 1 Triax minidish with Thomson Quad LNB, 1m Gibertini and Technomate TM-1500CI+ Super (Patched) 1metre Gibertini at Astra 1 19.2°e
will do
martz is offline   Reply With Quote
Old 02-10-2006   #352
wod
wod's Avatar
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+
Originally Posted by rolfw View Post
It should be strong enough, but I always like to over compensate. If you do eventually add a motor, then put another K bracket in the middle.
rolfw so you need two k brackets thought one set was enough ?
now i've got a decent sds hammer drill i'm gonna use sleeve anchors on mine
how much pole can you have above the guttering ?
Old 02-10-2006   #353
rolfw's Avatar
Real name: Rolf
I nearly always use 2 K brackets and 1 T bracket for a motor mount, just gives a little more stability. I use the Fischer 10/35mm sleeve anchors, inexpensive but effective on anything up to 1m and the 12 or 14mm anchors for anything larger..
PS. Depending on the size of the dish, you probably want to allow for only as much mast above the brackets, as is between them. Smaller dishes perhaps 1/3 below, 2/3 above.
Rolf
Old 04-10-2006   #354
Ey up, Sither!
femto's Avatar
My System: Echostar AD3000-IP, Manhattan Plaza ST100, Gibertini 1m Dish, Inverto Silver Tech 0.2, Polar Mount, 12 Inch Actuator, Dragon CAM
I'm just about to put a 1m Gibbi up with a polar mount and 12 inch jack.
At the moment I've got a K bracket and a T bracket already bolted to the wall with M10 rawlbolts. My idea was to use the pole that I used for my ham radio antennae (vertical white-stick and 3 element horizontal beam for 50MHz, sitting on a hefty Yaesu rotator).
I can vouch for the strength of the mountings as they've gone through the last two winters and not budged at all, though I know that a dish has far more sail area than even that ham radio beam did.
The K bracket is on the top, about two thirds of the way up the wall, about 12 feet up and the T bracket is about 6 feet off the ground.
The pole, which is a thick-walled 2 inch steel pole, reaches about 3 feet over the gutter (north-facing wall) when standing on the ground. This will mean that the brackets don't have to support the weight of the pole or the dish - just the forces applied by wind.
If I add another K bracket nearer the top, would this be the best thing to do?
Thanks!
Edt: Here are some pictures of what I am using now and the beginnings of my upgrade...
Picture 1: My ex-Sky Analogue dish, pointing at Hotbird 13E on my super-hi-tech patio mount.
Picture 2: The easterly view.
Picture 3: Some lovely trees which may hinder my 36E reception - we'll see though...
Picture 4: The view towards the Astra 1 area.
The rest of the horizon is about as clear. My only obstacles seem to be those two trees but the evergreen ones are a good 40 metres away and the bigger ones about twice as far.
I've also included some pics of my brackets. Any comments as to their suitability will be useful, bearing in mind what I mention above about the pole standing on the ground...
Thanks!
Pictures of Members' Systems-60cm-hotbird-jpg   Pictures of Members' Systems-east-view-jpg   Pictures of Members' Systems-28-45-e-jpg   Pictures of Members' Systems-19e-ish-jpg   Pictures of Members' Systems-brackets1-jpg
Pictures of Members' Systems-brackets2-jpg   Pictures of Members' Systems-brackets3-jpg
femto is offline   Reply With Quote
Old 04-10-2006   #355
rolfw's Avatar
Real name: Rolf
I would be more inclined to put the T above and the extra K below, but perhaps not quite as low as the one you have at the moment.
PS. Looks like nice countryside around your way.
Rolf
Old 04-10-2006   #356
Ey up, Sither!
femto's Avatar
Yes the countryside isn't too shoddy. I live just south of the Yorkshire Dales and the Easterly view shows Baildon Moor, next to Ilkley Moor,
What I'm going to do is put the pole up first, then add the extra bracket as then I won't need to measure anything. When these brackets went up originally, I used a plumb line to ensure one was directly above the other.
It doesn't matter that the T bracket is that low really, as the pole goes all the way to the ground! If the pole stopped at the T bracket, I imagine I'd have several huge chunks missing from my head!
EDIT: Right. I've put the pole up to show you all. Is it too tall? If so, I can cut some off the bottom and slide it down through the clamps.
I'm going to mount the dish in this way:
1. Polar mount on pole
2. Push up above gutter line
3. Dish face on polarmount
4. Jack on polarmount
5. Line up to the arc.
Is that the easiest way - other than watching someone else do it?!
Pictures of Members' Systems-dscf0116-jpg   Pictures of Members' Systems-dscf0117-jpg   Pictures of Members' Systems-dscf0118-jpg   Pictures of Members' Systems-dscf0119-jpg
Old 04-10-2006   #357
holy (rude word!) cow, that pole is huge!!! beware, the higher you have to take the gibbi, the harder it is, i only took mine about 8 - 10 foot up and man was it difficult, even with help from my dad!
Old 05-10-2006   #358
Ey up, Sither!
femto's Avatar
Yeah it's a beast. 21 feet long, that pole.
Heh, when I had my ham radio aerials on it, I had a rotator on the top which took it up a foot and then another 4 foot 6 inch pole in the top of the rotator with the aerials on it. Nearly 27 feet and then the vertical aerial, which was on top of that, was 7 feet long. 34 feet tall. Well, I did work South Africa, South America and Japan with it...
Trouble was, I was also in rather good contact with the house alarm, 6 doors down the street!
Yes, having thought about it, I'll shorten it so that it's just long enough to get the Gibbi above the gutter line. I don't think the roof will get in the way of any satellites as they're pretty high in the sky towards the south I think.
Old 22-10-2006   #359
Post Meister
BarMoo's Avatar
My System: 2xPace 430N, 1xNokia MM9800, 1xNokia 80cm Sat Dish, 1xGibertini 120cm, Big Fat Furry Puss
It took a while to get my orientation of the house (sic) - but then I thought " why not mount everything at the back of the house?" (where the current minidish is). Surely, you wouldn't have to go so high-up and would have a better sweep of the sky (or does that house behind the garage spoil things?).
And, the obvious, you wouldn't attract undue attention from ze neighbours with that side of house affair.
BTW, that is one long poll!
Just my penneth.
Have Fun, Moo.
BarMoo is offline   Reply With Quote
Old 23-10-2006   #360
Ey up, Sither!
femto's Avatar
Well, good idea but three things are:
1. The roof is higher at the back
2. I want to be able to get the atlantic sats, i.e. Telstar 12 at 15W and Hispasat at 30W.
3. I already had brackets on the side of the house. If I drill any more holes in the house, it'll be like living in a piece of Swiss cheese!
I'll perhaps be moving house in a year or so and I'll look for something that has a south-facing back garden so I can ground mount the dish.
Old 23-10-2006   #361
Post Meister
BarMoo's Avatar
I am sure you said a 1m Gibertini ??
Me reckons the big boys here are going to fall upon you like a ton 'u bricks.
And you want receive how far west.... with an east? facing aspect. [read: imagining from the current dish position] Cue: Mother sized pole.
When do you move again? (joke) LOL.
Have Fun, Moo.
Old 01-11-2006   #362
Site administrator
Analoguesat's Avatar
Heres some pics from our member digi24 who is based just outside Athens
He says:
On the right
a have a 1.35X1.25 Gibertini using a humax 0.3db lnb
pointing to 28.2/28.5 (unable to receive 2D and the
fixed beam of Eurobird). The dish on the left is a
triax 1.1m using 3 lnbs of Alps (o.3db) for 13,16 and
19.2. The Alps lnbs are famous when you want receive
satellites that are very close to each other (as in my
case) bcs these lnbs are very thin !
Pictures of Members' Systems-dig1-jpg   Pictures of Members' Systems-digi2-jpg
Analogue forever!
Old 01-11-2006   #363
Rd100
Posts: n/a
Televes uk stock those alps lnbs under there own brand of televe s,
It is cold here i wish i was in athens now
Nice setup btw,
He says:
On the right
Old 01-11-2006   #364
wod
wod's Avatar
think those f connectors need some waterproof tape around them if it ever rains in greece
Old 01-11-2006   #365
We Are The Supreme Beings
satscaner's Avatar
My System: 1.2M prime focus with SA58 H-H receiver-New Wave 9000 BP MK II
My motorised setup
My dish a 1.2m prime focus antena with a Invacom 0.3db C120 lnb, the motor is a sa58 H-H which is a little to small for the size of the dish. Its seen a couple of winters now but it keeps on going with the odd tweak here n there
The dish was given to me by my uncle, it came off of a roof top in Ibiza.
Pictures of Members' Systems-dish1-jpg
and on the other end of it I have a Newwave 9000 BP MKII receiver my positioner is a SuperTrack DP-6600.
I also have a fixed dish pointing at 28.2 east. I got the 80cm dish with an lnb from the local dump for £5 bargan I think. This dish has got an old Amstrad DRX200 digibox conected to it.
This was also my first dish, originally I had it connected to an analoge box, I used to move the dish between 19,13 & 5 east
satscaner is offline   Reply With Quote
Old 01-11-2006   #366
Site administrator
Yes they do - I pointed it out when digi24 emailed them to me - hes going to deal with it
Analogue forever!
Old 03-11-2006   #367
Rd100
Posts: n/a
Nice setup,
Old 07-11-2006   #368
shane77's Avatar
My System: sky + TM 1500CI 31.5W - 39E
my system
TM1500ci+, 1M Dish, 39E-31.5W
Pictures of Members' Systems-mysat-jpg   Pictures of Members' Systems-mysat1-jpg
shane77 is offline   Reply With Quote
Old 10-11-2006   #369
Looks good martz, apart from the T&Ks being the wrong way around, T should be at the top, having said that, I normally use two K brackets and a T for that sized dish.
sorry to drag up an old topic, but practically everywhere i see has it how i have mine, is everybody getting dodgy installs or what???
Old 18-11-2006   #370
phazblade's Avatar
My System: Dreambox 800 HD with External Esata Drive 1TB. 100CM Motorised Dish, Nabillo Blackhole 1.0
I had to have a go at installing my own dish when I heard about the goodies on Art Sports.
I got the dish and LNBs for £1.71 off of Ebay, though I did have to go and pick it up.
The LNBs point at Astra 1 and Hotbird and combine with a diseqc switch. I get just over 1400 channels when I scan both Satellites
Big bolts, big tube, it aint gonna move, to date I have a whole week without going up the ladder to have a jiggle, I think we are sorted for the time being
Pictures of Members' Systems-dcp01418-jpg   Pictures of Members' Systems-dcp01421-jpg
phazblade is offline   Reply With Quote
Old 18-11-2006   #371
wod
wod's Avatar
nice shall get some pics of mine as finally got it setup today
Old 18-11-2006   #372
Sky Remote Breaker...
2cvbloke's Avatar
My System: Mostly gathering dust cos there's no room for dishes here... :(
The Sleepy Hollow pollracle has spoken!
I can beat that!!! Same dish aswell, one LNB though, it was free!!!!
From a skip of course, and in perfect working order after a clean and a minor reshaping round the edges, just need a house I can attatch it to without having to beg my landlord....
I think your car looks funny too......
Proud owner of a satellites.co.uk cap & T-Shirt...
(though the latter no longer fits due to my ever expanding waistline!!!)
Resident KIRBY Vacuum nut...
2cvbloke is offline   Reply With Quote
Old 19-11-2006   #373
wod
wod's Avatar
my system triax 88cm dish, edision 0.2 lnb, moteck sg-2100a diseqc motor, webro wf100 cable and techomate tm-1500ci reciever
so it ok for first timer ?
Pictures of Members' Systems-img_0166-jpg   Pictures of Members' Systems-img_01671-jpg   Pictures of Members' Systems-img_01681-jpg
Old 20-11-2006   #374
Ey up, Sither!
femto's Avatar
Looks pretty good to me, although I'd be tempted to tape your co-ax cable to the mount and cleat it to the wall but maybe you took the photo after tightening the last nut and did the taping afterwards??
Looks fine to me.
Old 20-11-2006   #375
wod
wod's Avatar
yes i just need to clip the cable to the wall and maybe get a new mount as the dish is at 28 east in that pic
members, pictures, systems
[IMG] code is Off
Similar Threads
HDTV Primer spiney High Definition Receivers transmissions, satellite and Terrestrial 0 16-01-2006 12:42 PM
Members with AOL E-mail addresses-URGENT rolfw The Meeting Place 2 05-01-2005 02:40 AM
Members with AOL E-mail addresses-URGENT rolfw Announcements and News 27 12-07-2004 05:06 AM
How many forum members does it take to change a lightbulb? PoloMint The Meeting Place 3 15-01-2004 04:19 PM
A Message to all New Members and Visitors waverider The Meeting Place 0 01-12-2003 04:53 PM
