Pictures of Members' Systems
Thread Tools Display Modes
Old 19-08-2007   #476
My System: 1 metre Channel Master with matched feedhorn + Inverto 0.3dB lnb. 1224 H to H motor ground mounted. Technomate 5400CI+ USB and v-box
Originally Posted by frankg4553 View Post
Just a few pics of my new dish...all is working perfectly...great reception...didn't think it would be such good picture quality
Thanks for all the help!
Frank
Done....1 metre Channel Master + matched feedhorn and inverto 0.3dB, 1224 h to H motor, Technomate 1500CI TMS, V-box
Frank
ID:	12302   pictures-members-systems-satellite-dish-003-638-x-850-jpg.jpg
ID:	12303   pictures-members-systems-satellite-dish-005-638-x-850-jpg.jpg
ID:	12304   pictures-members-systems-satellite-dish-006-638-x-850-jpg.jpg
ID:	12305   pictures-members-systems-satellite-dish-007-638-x-850-jpg.jpg
ID:	12307   pictures-members-systems-satellite-dish-010-850-x-638-jpg.jpg
frankg4553 is offline   Reply With Quote
Old 19-08-2007   #477
CROSSBONES's Avatar
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card.
Nicely tucked away at the side of the garden
Nice install
CROSSBONES is offline   Reply With Quote
Old 19-08-2007   #478
Nice install
Yes, very pleased with the result..all my own work...all learned off the forums...knew nothing beforehand ...and I still can't get over the quality of the pictures on all sats!!
Frank
Old 19-08-2007   #479
rolfw's Avatar
Yes, cracking installation Frank.
__________________
Rolf
Donate
Old 19-08-2007   #480
wod
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish
very nice frank well done
so do you get 42e-45w ?
Old 19-08-2007   #481
Hi wod...no, furthest east is 33 and west is 8...the tree blocks anything further west at the moment. Having said that, the only one i would be intersted in further west is Hispasat but I can get all the Spanish channels I want from 19.2E
Actually I find that 28.2/28.5E, 19.2E and Hotbird are the only ones I tend to use regurlarly...the rest get very little use!...so I'm very pleased with the set-up
Any movement on setting your CM up yet?
I'm also toying with the idea of getting a vantage receiver.
Frank
Old 19-08-2007   #482
staffspeted's Avatar
My System: Channel Master 1.2 driven by Supermount SMR 1224 mount. V-Box 11 Triple Dragon Linux Receiver. Vantage VT-X221TSCI Blindscan Receiver. Diablo Wireless cam and base. 42" Panasonic Plasma Lots of boys toys!
Am running the 1.2 version of your system Frank with a TD (sigh!!) and a top spec Vantage (Big smile!!) Can whole heartedly recommend these Vantage receivers. The blind scan is second to none!
staffspeted is offline   Reply With Quote
Old 19-08-2007   #483
I can get the vantage for £119 at the moment...too good to pass up!
Old 19-08-2007   #484
wod
is that the freeview built in version ?
Old 19-08-2007   #485
Yes it is wod. That means I could get rid of the Freeview box....fewer boxes, less cable.
£119.95 to be exact!
Old 20-08-2007   #486
My System: Channel Master 1.2m and 1.8m, Vantage VT-X221TS CI and 8000s, Technomate V-Box II, 18" Superjack actuator
I've just finished setting up my dish this weekend. I am quite disappointed by my Vantage, the picture quality is quite poor. I get faint zig-zags moving across the screen. It looks really bad compared to my Sky box. It even happens on the menu pages. I've tried playing around with the media settings but its still the same. Not sure if its faulty or normal as I don't have another non sky digital receiver.
michael01707 is offline   Reply With Quote
Old 20-08-2007   #487
I can't see that being normal as reports on the vantage are very good and I'm sure that would have been picked up. Are you sure all your connections are good and have you used good quality cable?
I may be corrected here, but I'd say the picture quality depends more on the quality/size of the dish and then the lnb and cable more than the reciever, although the receiver is of course important.
I'm sure some more experienced members will be able to point you in the right direction.
Mind you, looking at your set-up it all seems good stuff
Frank
Old 20-08-2007   #488
Frank
I'm pretty sure that it is not the equipment or the setup as the quality is poor on the menus. I've tried using other scart cables. I'll see what happens when I use the scart cable from my sky box on the vantage because the quality on that is fine.
Old 21-08-2007   #489
wod
could be a faulty receiver, has the receiver been tried on another tv to see if the problem persists ?
also could be a faulty scart cable or interference from a scart switching box if one is used
Old 13-10-2007   #490
My System: ClarkeTech 2100Plus USB + Triax 88DL+Moteck (Palm) 2100A motor, Home-Theatre AV System, LCD-TV, PC, HTC TyTN
go and get ClarkeTech receivers...they are smoothie
bjluv is offline   Reply With Quote
Old 25-10-2007   #491
wod
changed my dish setup around a couple of weeks back and now get 42east to 58west
much better since it been raised 2 feet higher
pictures-members-systems-001-jpg
Old 25-10-2007   #492
Amo Amas Amant Admin
Topper's Avatar
Well
That is an improvement, hope the neighbours don't object or does it just look worse than it is?
__________________
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 25-10-2007   #493
wod
its been up for 2 weeks and nothing said about it so all good. the channel master dish i have would have got something said i think as its massive just too large for use on the wall
Old 25-10-2007   #494
Decided against the CM then wod?
Old 25-10-2007   #495
wod
well yes for the time being
Old 04-11-2007   #496
Site administrator
Analoguesat's Avatar
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S
Heres my Orbital 1m dish pointing at 16E with 2 additional lnb's (23E in the middle and 28E from the yellow cap) Note the yellow cap lnb is held in place with garden wire as the top of the clamp was missing out of my junk box.
I was hoping to get 26E on the yellow cap, but couldnt find it - maybe that lnb is just too far off beam.
pictures-members-systems-orbital1-jpg   pictures-members-systems-orbital2-jpg
__________________
Analogue forever!
RIP BBC2 analogue on all Scottish Borders transmitters, switched off 0031GMT November 6th 2008
Final analogue switch off from all Scottish Borders transmitters - BBC1 ITV C4 & C5 - 0010GMT November 20th 2008.
Old 04-11-2007   #497
Site administrator
And heres a lash up with a second lnb on my 13E dish to give me Eurobird 9 at 9E The upward facing zip ties are an attempt to stop the birds perching on the lnb.....
The left hand lnb case isnt cracked - the air up here is so clean theres lichen growing on the case!
Edit - I can also get a couple of the stronger Eutel W1 tps on the lashup lnb, so when Ive got a nice day over the Christmas holiday I will take it all apart again and try to optimise it further.
pictures-members-systems-9e-lnb-jpg
__________________
Analogue forever!
The Following User Says Thank You to Analoguesat For This Useful Post:
leighpreece (11-11-2007)
Old 06-11-2007   #498
Vintage Sat enthusiast!
My System: 90cm Dish. Dual Lemon LNB for 13E/19E. Twin Output Lemon LNB for 28.8E. Samsung 9500 with 'alternative' firmware. Couple of DigiBoxes. Amateur Radio station. Going Bald with a patient wife!
Looks good Ross no matter how you fixed it - as long as it works!
I remember replacing a friends single output LNB for a dual one and lost one of the nuts and bolts and put a cable tie in place to just secure it - then forgot about it.
Still in place now - even after he sold the house!
Leigh....
leighpreece is offline   Reply With Quote
Old 12-11-2007   #499
Well - after it has taken me ages to get my backside into gear, here are two images of my outside setup here in Stoke on Trent;
First one is 'almost' finished job - before I realised I'd left a clump of coax fastened to the wall mount (Sky installer's excess!).
OH - NOTE THE GRAY RAWLPLUGS THAT HELD THE SKY DISH IN PLACE! ALSO NOTE THE ABSENCE OF ONE (JUST UNDER THE BOTTOM OF THE DISH) WHERE THE INSTALLER TOTALLY SCREWED UP AND JUST BODGED THE PLUG INTO THE WALL, PROBABLY HOPING I WOULDN'T SEE HIS BAD WORKMANSHIP AND THE HOLE HE HAD MADE FOR ME!
(I actually mounted my dish using some of the original Orange rawlplugs that held the late 1990s Sky dish and added some of my own holes and plug/bolts - if it looks like I haven't used enough - trust me - I have as I can hang on the wall mount!)
pictures-members-systems-11112007315-jpg
Second one is view from above with my own added extension to get the 28.8E LNB far enough across the holder to see the satellite on the dish itself.
(The rubbish in my yard is my recycling - whereas the rubbish in my neighbours yard is just that - rubbish and a right mess - note the utensil used to catch rice they wash down their sink!)
pictures-members-systems-11112007316-jpg
Not too sure if the LNBs are the wrong way around and need swapping and I need to reposition the dish (missing some channels from 19.2E) - but I get good signals on both 19.2E and 13E plus huge signals from 28.8E so not tempted to touch at the moment!
The twin-LNB feeds my Samsung 9500 in my office and the dual-output single-LNB feeds a Thompson Sky box in the lounge and a Grundig in my office.
LNBs are 'Lemon' ones and work okay for me and the dish is a 90cm - all from fleabay!
Someone has offered me a 120cm dish and analogue receiver this evening - old and motorised - just wondering how far I can push the wife before she offers to hit me over the head with it!
Leigh.....
Last edited by leighpreece; 13-11-2007 at 12:10 AM Reason: 'cause I needed to, ok?
Old 13-11-2007   #500
Site administrator
Very nice Leigh - well done
__________________
Analogue forever!
