Pictures of Members' Systems | |
| | #151 | |||
| The Consumate Dreamer Join Date: 01-01-2000 Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh |
Man that is so romantic.....
__________________ I only believe stuff that comes straight from Mr. Horses mouth | |||
| | #152 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Hi RomanDavid. The Metrix is limited to an upper frequency of 1750 MHz. Do you use a downconvertor to read above this frequency? Llew | ||
| | #153 | |||
| Regular Member Join Date: 07-03-2005
My System: RX prime focus antennas IRTE 310 cm,MABO 180 cm,KOVOSAT 140 cm,WAWE FRONTIER T 90,OFFSET 125 cm.DVB Echostar AD 3600 IP VIA,NOKIA 9600,Dreambox DM 7000.TV/SAT/FM Measurement receiver ITT METRIX for spectral analization VF signals.QPSK Constellation D |
Hi Llew!!! yes,SAT/TV/FM measurements receiver ITT Metrix have tunning nr. 1 frequnce from 940 to 1780 MHz.If i use universal LNB /for example Invacom SNF 031/ LOF 9,7 Ghz 10,6 GHz,iam use external 22 kHz swith/12V/,by the way frequence extender for higher frequence too!!! I have too QPSK Constelation diagram locator and BER,S/N..... definitor and this equipment is great for profesional eweryday use. I am interesting about High Frequence engineering | |||
| | #154 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Welcome to the forum BTW. Yes, that's what I use to extend the frequency range. Just have to convert the analyser readings to obtain the true frequency. Wiil get a digital SA one day... Llew | ||
| | #155 | |||
Did you get in your location sattelite name NILESAT 7° West, and what transponders.Probably only "V" vertical polarity with minimum size of receive dish????? Thank you to your reply | |||
| | #156 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Hi No problems with Nilesat vertical channels with SMW 1.2 dish/Invacom (over 50 most of the day on certain TP's) in eastern UK. Nothing on Horizontal (weaker TP's I beleive) Llew | ||
| | #157 | ||
| ASBO Club Member - Persona non grata Join Date: 30-07-2003 Location: Stockholm, Sweden
| IRTE 2.4 meter dish and Sky Mini dish installed in U.K http://www.tel-satexp.cz/img_foto/ml_4_50_01v.jpg http://www.tel-satexp.cz/img_foto/ml_4_50_02v.jpg | ||
| | #158 | |||
| Specialist Contributor Join Date: 28-05-2003 Location: Florence Italy
| | #160 | |||
Can you please help me with record on VHS or DVD this program on BBC 2 next day /thursday 10.3. 2004/ at 8:00 pm Crufts 2005. I can receive in my location only VERTICAL polarization on ASTRA 2D 28,2°E and BBC 2 use in transmit HORIZONTAL polarization. This program need to tape my friend who /if you answer on this request/ connect to you on this board. Thank you very much for your answear. Roman Dávid | |||
| | #161 | |||
| Do you have any pictures of your IRTE 3.1 meter dish you could show us? Would be nice to see it closeup and from behind...
| | #162 | |||
Unfortunately I only record to hard disk, and haven't a DVD burner. As Crufts is of international interest, It might be possible to find a feed somewhere on the day. Alternatively, you could try posting a request in the 'Chitchat and Meeting Place' section of this forum. Sorry I can't be of more help. Llew | |||
| | #163 | |||
Not worry about it Llew,it is only a dogs. Have a nice day . | |||
| | #164 | ||
| I have tried to find a picture of my old 3 meter dish i had 15 years ago which was made by Winegard in USA, i have found a picture now..... I had a Seavey feed and the dish had a f/d of 0.285, extremely deep, it was a very good performer and was made in 8 segments, this was the Rolls-Royce of perforated dishes with Ku-band mesh. http://pal.pp.se/%7Ekalle/pinnacle_3meter.jpg | ||
| | #165 | ||
| Regular Member Join Date: 18-11-2004 Location: Belfast, Northern Ireland
My System: Dreambox 7020, CM 1.2 with invacom quad c120 & channelmaster feedhorn. |
I find these work fine for me. 1.2 channel master moved via Manhattan st 550. | ||
| | #167 | ||
| Regular Member Join Date: 18-11-2003
Sorry about the large picture sizes, I'm still getting the hang of the camera. Pic 3 is a special type of new dish to help the aliens know what I am thinking about- thus far no complaints from them so it must be working.
__________________ Now I'm hiding in Honduras I'm a desperate man Send lawyers, guns and money The s*** has hit the fan Warren Zevon Last edited by EDW; 20-03-2005 at 03:03 AM | ||
| | #168 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | I prefer your picturesque fourth photo. None of them big ugly satellite dish thingys in the way. Llew | ||
| | #169 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | I have to say that seeing views like the one in the fourth photo is one of the things I love about working on roof tops.
__________________ | |||
| | #170 | |||
| Ding Dang Doo Join Date: 31-01-2004 Location: Scotland
My System: DreamBox 7000s - Nokia Freeview - Several GameBoys - DS Lite - ZX81 - SNES - N64 - Sega Saturn Dreamcast - PlayStation - Gamecube - PSP - iPod - iPhone - XBox - PS3 - Wii - No Life! |
| | #171 | ||
| Member Join Date: 20-02-2005
| Hello all, I'm just getting started with my satellite setup. It began with a 2nd hand sky digibox & dish, but now i've got a 2nd digibox and a sat card for the PC on the way. Today I swapped my LNB for a quad and strapped the old LNB to the arm pointed at 19.2. Under the 28" Bush TV I have this selection of toys: Playstation2 xBox Sony Amp/Receiver Sony Minidisc Pace Digibox Panasonic E55 DVDR Cyberhome DVD NTL STB Around the back is my wireless router feeding the Laptop, 2 PC's and both consoles, Oh and the 12 mains plugs !! | ||
| | #172 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | I like it Scotty, shows a bit of ingenuity there.
| | #173 | |||
| More dishes than Sense. Join Date: 30-09-2004 Location: Close to Southampton
My System: 7 dishes. 9 LNBs. And a whole load of receivers + One broken TV. |
-cts | |||
| | #174 | |||
It sure is, I don't need it as i'm actually in Bournemouth, but we're hoping to move to France soon so it'll come in handy there. | |||
| | #175 | ||
| Guest
Posts: n/a
| Finally, now that my daughters gave me a digital camera for my birthday and I have managed to learn to drive it (hopefully). !m Gibertini dish, Moteck SG-2100 motor, arc from 53* east (until trees grow foliage) to 58* west. Nothing special, but it works for me. H-B | ||
