My home made C/master mount | |
| Specialist Contributor Join Date: 23-07-2005 Location: S.Wales
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. |
Here it is my home made Channel master polar mount, for my 1.8m Dish. It was made by my bro in law ![]() Cant wait for dry and calm wheather, so I can install the dish. But it will probably be in the newyear now. ![]() Ill put some pics on when its up | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Nice job, will be nice to see it mounted.
__________________ | |||
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | yes cant wait. A nice lick of hammerite should finish it off nicely | ||
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! | I guess marriage does have some uses.... Looks very good though...
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() | ||
| | #5 | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
Looks good CROSSBONES, make sure you spray inside the tube mount as well
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
| | #6 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | excellent looking mount there , i thought you was going to end up buying that motor which fits andrews dishes | ||
| | #7 | ||
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | the jaeger 1224? not a good idea to mount the heavy channel master dish on. | ||
| | #9 | ||
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | probably work out too pricy to galv it m8. What bearings do you recomend Likvid? | ||
| | #10 | ||
| ASBO Club Member - Persona non grata Join Date: 30-07-2003 Location: Stockholm, Sweden
| | #11 | ||
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | do you have a direct link for the type i need? I have been looking at other mounts and they dont seem to have bearings on the axles! | ||
| | #12 | ||
My Polar mount has oilite bushes and they have not worn out in 22years but you do have to oil them of course
| | #14 | |||
If you feel like that why bother visiting forums like this. You dont have to give your advise. I do appreciate your excellent knowledge, as im sure other members do to. thanks topper ill check them out | |||
| | #15 | ||
| Guest
Posts: n/a
| Nice mount have you got it on the dish yet Could you not powder coat the mount as that is all that is on the standard andrews one, If not hammerite it a few coats would do the trick, If you used bearings on the mount would you needed the mount to get remade???, | ||
| | #16 | ||
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | The dish isnt on yet m8, not had alot of time, and weather is shit. there is a company that galvenise`s metal, as we make car door strikers and send them off, local too. maybe I could slip it in and get my company to pay! lol Dont think im going to use bearings, my bro in law said as long as its greased wel should be ok. But he did have land rover bearings on there, but removed them for some reason. | ||
| | #17 | |||
| Guest
Posts: n/a
| Yes you could put grease on it just grease it up once a year,
| | #18 | ||
| Part Timer Join Date: 06-10-2005 Location: that would be telling
My System: DreamBox 800HD DreamBox 7025 PVR160g HD,500s Dreambox ,Sly+ Full Package,SkyCard 2, And a Eagle 500 Clone DM500 TM755,TM9100 Linux Channel Master 1.2m,1224EL Supermount Orbit Tracking Motor With c120 Feed Horn Invacom Quad Lnb Cas3 SC Dragon Progr | that looks better than the one's you would buy very very good job that m8.
__________________ If it is not broke fix it till it is | ||
| | #19 | |||
Fair play to him, didnt cost me a penny either, exept the beer im going o buy him. | |||
| | #20 | ||
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | I mounted the dish just to see what it looks like! lol Im going to get it galvanized soon, then get it installed.
__________________ Roiders are like the sun, big, orange, and never stare directly at them | ||
| | #21 | ||
| Member Join Date: 28-01-2006 Location: South Africa
My System: C and Ku |
I assume this dish is up.Crossbones as a matter of interest did you use bearings.Also built a polar mount using brass bushes and wonder if nylon bushes will do the job as well. | ||
| | #22 | ||
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | No mate, not installed yet, not had time. No bearings, im just going to grease it | ||
| | #23 | ||
| Design Engineer/Installer Join Date: 08-08-2007 Location: Central UK near Jodrell
My System: 75e-75w C & KU, 36v diseqc Anlg to HD Channel Master C120 dishes, stbs, lnbs, motors, too much to list | Crossbones... I noticed this the other day and since we also design/ build steelwork and 2 years have passed.... I was wondering how the polar mount has performed without bearings or bushes and what steel was used at the axes points.. mild steel / medium carbon steel and was threaded bar used. It looked a very good job. | ||
| | #24 | ||
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | Hi pedro, Well to be honest, I only had it installed for about three months. The mount was shaky, used to move in the wind. But I've been told that genuine C/master mounts do the same?? The actuator I had was not powerful enough, it used to struggle to pull the very heavy dish up from 30w. It was made from mild steel. The axis was held together with a nut n bolt. it moved very well though!
| | #25 | ||
My System: 75e-75w C & KU, 36v diseqc Anlg to HD Channel Master C120 dishes, stbs, lnbs, motors, too much to list | so what happened to it? | ||
