Some pics of a Andrew 2.4m Gregorian antenna
Upload your photos here (Don't link to them with img code, upload them), doesn't matter how basic your setup, it's nice to see what everyone is working with. If you've seen an interesting setup, then post it here. All photos here are copyright and cannot be used without permission of the poster.
Old 08-04-2007   #1
Some closeup pictures, the master of them all.
Some pics of a Andrew 2.4m Gregorian antenna-h24-roma-1-jpg   Some pics of a Andrew 2.4m Gregorian antenna-h24-roma-3-jpg   Some pics of a Andrew 2.4m Gregorian antenna-h24-roma-4-jpg   Some pics of a Andrew 2.4m Gregorian antenna-h24-roma-5-jpg   Some pics of a Andrew 2.4m Gregorian antenna-telespazio-hun1-jpg
Likvid is offline   Reply With Quote
Old 08-04-2007   #2
Rd100
Posts: n/a
I can get these dishes cheap i have used these for vsat loads of times and also a few transmitter sites use both the 1.8m and 2.4m versions they are good dishes the only down side if you are in to multisat there is no polar mount option.
Old 09-04-2007   #3
That is easy to fix as you can make a frame and bolt a EGIS motor to it.
I have some pictures somewhere of this setup, will try find it.
Old 09-04-2007   #4
Here are the pictures with EGIS motor and 120cm Andrew and 180cm Andrew to the right.
The motor will handle the weight of the 240cm as well but i haven't found a picture yet.
The company also sells pre-made metal frames for these dishes or you can make one easy yourself asking some welder doing the frame.
Some pics of a Andrew 2.4m Gregorian antenna-phot_130-jpg   Some pics of a Andrew 2.4m Gregorian antenna-phot_180-jpg
Old 09-04-2007   #5
More pics during assembling.
Some pics of a Andrew 2.4m Gregorian antenna-240_1-jpg   Some pics of a Andrew 2.4m Gregorian antenna-240_2-jpg   Some pics of a Andrew 2.4m Gregorian antenna-240_3-jpg
Old 09-04-2007   #6
wod
wod's Avatar
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+
very nice, likvid you installed these then ?
wouldn't the jager 1224 motor be strong enough for these ?
Old 09-04-2007   #7
CROSSBONES's Avatar
My System: 1.2M, & 55cm Gregorian Dish`s, 1.8m Precision dish Jaeger 1224 H-H motor.Dreambox 800, Vbox-II. SS2 Card.
It does say on the jaeger site that the 1224 is suitable fo a 1.8m dish. The channel master 1.8 is a heavy bitch. I would not mount it.
The 1224 could probably handle a precision 1.8m dish ok.
EGIS motor is ok if you have a big wallet!
CROSSBONES is offline   Reply With Quote
Old 09-04-2007   #8
No i have never installed a Andrews 2.4m.
No you can not use the 1224 motor with a 1.8m or 2.4m Andrews, the casting would crack.
However a German firm is selling modified 1224 motors where the casing doesn't crack.
Old 09-04-2007   #9
Here is the modded 1224
Some pics of a Andrew 2.4m Gregorian antenna-kompl_gr-jpg
24m, andrew, antenna, gregorian, pics
[IMG] code is Off
