Using the Premiere card work outside of Germany?Discussion on the Premiere Germany satellite TV subscription packages. | |
| Member Join Date: 14-07-2008 Location: UAE, Dubai
My System: I have Hotbird, Arabsat and Nilesat |
what about watching those german channels outside of germany? does the premiere card work there? | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | The premiere card will work anywhere inside the coverage area with an appropriate receiver. The UAE is probably too far east to get coverage though. | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Yes if you can a) receive the satellite (have a big enough dish) and b) get hold of a card. | ||
| The Following User Says Thank You to rolfw For This Useful Post: | sashi002 (12-10-2009) |
| lifes not a practice run Join Date: 27-09-2006 Location: torfaen south wales
My System: Technomate diseq 1500ci+ and Humax Foxsat HD Acer Aspire 5315 | | ||
| | #5 | |||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
| I believe that many of the Sky Germany channels can be received with a relatively not so big dish (1.2-1.6m) in the UAE. Check the channels under the Wide beam from 1M. Why don't you point your dish (whatever size it is) to Astra 19.2E and see which channels you can see after scanning? You can then worry about how to get a subscription card. _http://www.lyngsat.com/astra1m.html _http://www.lyngsat.com/packages/skydeutschland.html Report back if you can, as this can help others living in the ME. | |||
| | #6 | ||
| The Consumate Dreamer Join Date: 01-01-2000 Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
Blog Entries: 5 My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh | Why would you want to get the sky Germany? If you are after German programs, then there are a dungload of FTA channels available. Their movie channels are showing the same movies as all the other major packages, the porn is the same (well all porn is the same anyway so the only thing they got is the German football... | ||
| | #7 | ||
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | Hello! where are you located? when you are from dubai,like i read in your profile,then i dont think that is posible to reive the sky germany channels? the signal is stronger,since the change of the satellite,in greece and other areas,but not in dubai! | ||
| | #8 | |||
| Take a look at the Wide beam footprint from Lyngsat. It should be possible to receive some channels, even in the UAE. _http://www.lyngsat-maps.com/maps/astra1m_wide.html | |||
| | #9 | ||
| Specialist Contributor Join Date: 09-09-2008 Location: Republic of Georgia
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | Wide beam channels are OK in dubai - discussed and confirmed already many many times in relevant 1M topic... | ||
| | #10 | ||
My System: I have Hotbird, Arabsat and Nilesat | | ||
| | #11 | |||
| | #12 | |||
| | #13 | ||
| Member Join Date: 12-06-2009 Location: Dubai - UAE
My System: Dm8000 | once and for all: ASTRA 19,2e 1M-WIDEBEAM DOES WORK IN DUBAI with 100cm offset dish and up! not a problem!!!! even a stronger signal than 13e Hotbird!!!! and for all other germanspeakers: 09e --- KABELKIOSK will give you full german tv with 165-185 PFA dish----- and yes - you will be able to find ORIGINAL SMARTCARDS for that in Dubai...... greetings from the sunny side of dubai!!! | ||
| card, germany, premiere, work |
