problem with USB hard drive
Section for discussion of the Qbox Linux based range of receivers
Old 27-07-2009   #1
T_G
The Consumate Dreamer
T_G's Avatar
Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything.
Muhuhuhahahahahaaaaarrrgggh
I got my USB hard drive connected, buzt when I shut down the qbox completely, and then reboot, I get a pink display and it is stuck. When I remove the Hard drive, the box will boot.
This problem does not occur when I do a restart using the remote.
Does anyone have an idea what this could be?
Cheers
T_G
I only believe stuff that comes straight from Mr. Horses mouth!
T_G is offline   Reply With Quote
Old 27-07-2009   #2
Archived Member
Cheers
Hello T_G,
Did you connect it out of the box, or you formatted it first?
Check the format type that the Qbox usually requires. You probably can format it using one of the menus when it is connected and the receiver is operational.
HB13DISH is offline   Reply With Quote
Old 27-07-2009   #3
T_G
T_G's Avatar
it is formatted in fat32, that's ok. I did manage to get information from another forum, they are saying it is a software problem Duolabs are aware of and going to fix it with one of the coming updates.
T_G
drive, hard, problem, usb
[IMG] code is Off
