Vantage combo receiverInformation exchange on receiver software, including updates, problems and fine tuning. | |
| Regular Member Join Date: 26-12-2004 Location: Wirral
My System: 1 metre Channel Master with matched feedhorn + Inverto 0.3dB lnb. 1224 H to H motor ground mounted. Technomate 5400CI+ USB and v-box |
Is it as easy to open up D+, Premier etc on the Vantage as it is on the Technomate 1500? D+ changes keys 2 or 3 times a day...are they immediately available for the vantage as they are for the 1500TM? Thanks Frank | ||
| Specialist Contributor Join Date: 23-07-2005 Location: S.Wales
My System: 1.2M, & 55cm Gregorian Dish`s, 1.8m Precision dish Jaeger 1224 H-H motor.Dreambox 800, Vbox-II. SS2 Card. | Yes the support is very good on the vantage. Showtime was out on the vantage before the 1500 | ||
My System: 1 metre Channel Master with matched feedhorn + Inverto 0.3dB lnb. 1224 H to H motor ground mounted. Technomate 5400CI+ USB and v-box | | ||
| combo, receiver, vantage |
