Technomate Reciever RESET to factory settings by it self??Information exchange on receiver software, including updates, problems and fine tuning. | |
| Member Join Date: 17-07-2007 Location: UK LONDON
My System: technomate, pace 2 dishes , 1motor 1 normal | hi all, I have a big problem, I have technomate 5500 D Super (I know it isn't that good :P) yesterday morning I woke up and opened my TV and saw that there was no channel list and none of the settings I have made were there... what can I do? -- i think the software is gone ?? (maybe) can anyone help.. ![]() Thanks. | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Hi, Try here:- _http://www.technomate.com/software_updates.php?model=TM-5500D+SUPER Loader, software and channel lists are all there. And once you get it working again, I suggest you upload back to your PC ( the channel list) , so you've got a backup next time. | ||
| The Following User Says Thank You to Robbo For This Useful Post: | user1001 (01-09-2007) |
My System: technomate, pace 2 dishes , 1motor 1 normal | Thank you very much, although I am going to ask you another quetion. how do I transfer the files to the reciever???? I mean what sort of cable do you use to connect pc and reciever etc.. Thank you... | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Hi, it is normally a null-modem cable (RS232) 1-1 2-3 3-2 5-5 on DB9 to DB9 Thats what my manual says, although I bought mine, couldn't be ar$ed making one up. Check out the manual or the PDF on their web if its there, I imagine it would be the same. Just load it with the loader program from TM | ||
| | #6 | ||
| Donate to this board Join Date: 05-09-2006 Location: So called capital of Suffolk, UK.
My System: Smart lnb, 1m Gibby dish, Stab motor, TM5200D receiver, 57east to 61west. DTT from Sudbury. Virgin Media broadband. | @ tele The TM1000 blind search is veeeery slooooooow. You could die waiting for it to happen. You should go for the TM1500 or a Vantage or a C-Tech receiver The TM1000 I have on my bench, I set to blind scan 42east overnight. I turned the box off the next morning as it had only scanned 10%. Other than that it is a nice fast response receiver easy to use and quiet sensitive. Parky | ||
| Last edited by Park Royal; 02-09-2007 at 06:24 PM. Reason: went to prepare my evening meal | |||
| | #7 | ||
| Member Join Date: 24-06-2007 Location: england
My System: satellite reciever key | hi all, I have a big problem, I have technomate tm 1500 ci i cant loade softcam from loader to reciever please i need help because wen i try to send softcam -key to reciever dosn't working the loader writ no conection and the loder writ com1 and com2 and reject please sameone tell me how to reset reciever i do manuel reset factory but the same problem please help me thank you | ||
| | #8 | |||
@bisikri2003, I don't know what loader you're using, but on the Darkman one, you click on "Auto detect" and it will find the correct com port for you, assuming that you have the cable wired up right as my previous post, or a full null-modem. I think the TM loader does the same, but I have not got a copy of that to check. @ tele If you feel confident about doing so, you could try downloading the latest software for your model from technomate and see if it cures the problem. But if you have the slooooow blind scan model, then it may just be being slow like PR says. | |||
| factory, reciever, reset, settings, technomate |
