how to enter keys to nokia 9800 plz help!Information exchange on receiver software, including updates, problems and fine tuning. | |
| Member Join Date: 08-09-2007 Location: alex
My System: very gooooooooooooood |
i got nokia 9800 (yes i was stupid) i need to find how (hardware and software ) to decode multivision and absat or any other available packages what kind of files do i need bin hex etc and what kind of software server i need? and does RS232 do the job?? | ||
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | hi! a h ave also,the old mm 9800,this reveiver,is very slow in zapping,even,when the channel list is full,but the pircture quality is superb,and real sharp much bettern,then todays reveivers,open box etc on the 9800,they never comes,out any emu soft,you can,only use,any cam,like trex dragon,diablo,or what ever! on tps,depent,on the cam,it could be happens,that you have,problems,switching,on viacces channels,the 9800 first,always check,the internal card slot! | ||
| 9800, enter, keys, nokia, plz |
