Warning!!! Coship 2300 patchInformation exchange on receiver software, including updates, problems and fine tuning. | |
| | #227 | ||
| Regular Member Join Date: 27-07-2004
| @jzurd0 : tnx mate , ... so now ,we seem to be organized http://www.satellites.co.uk/php-bin/...171#post137171 | ||
| | #228 | ||
| Regular Member Join Date: 28-08-2004
| Hello, i have a DSR 5002 with SW: S02B-2.98R-B39.01 and Morocco-Earth-Patch. Other patches don't work, Err 5. With the Morocco "ORF" have many drop outs. What can i do, waiting for a new version of Morocco? Bye Jo | ||
| | #229 | ||
| Member Join Date: 21-07-2004
| hello everybody, did someone could send with success channel list to the axil ad600 with the firm srt3680_dsr5002_5003.zip i can download it to the pc with upgrade software, but when i want to take it in the receiver, it says ok ,but nothing has change. perhaps did i do it after a re_initialisation ? if someone know ? thxs | ||
| | #230 | ||
| Member Join Date: 22-02-2004
Hi everybody here is new coship strong 3680 S*ca2 firmware work 100% File Removed Don't post files with keys in on the forum, please read the rules. Post a link to the file. Admin | ||
| | #233 | ||
| you can find new firmware here www.depo.shows.it receiver software, coship | ||
| | #234 | |||
| Member Join Date: 06-05-2004
| What is the name of this S*ca2 firmware? thanks.
| | #236 | ||
| hello jzurd0 i give you a scoop for you my friend. an hidden hardware test menu exist in the srt3680_dsr5002_5003 firm to enter in it follow : when switch on the receiver with back switch, press at the same time the front "Ch+" button, a menu will appear to test lnb,video,22khz... funny...and totally new | ||
| | #237 | |||
| Member Join Date: 25-08-2004
| | #238 | |||
donīt worry about the message , that everything will get lost ; just reset and enjoy (donīt forget to reactivate the emu) cheers dishead | |||
| | #240 | ||
| Regular Member Join Date: 05-07-2004
| Users with bootloader 3X.01 try this link (NO Seka2) Last Strong patch: http://dvb-upload.com/index.php?acti...load&pid=16355 The same as srt3680_dsr5002_5003.zip but this time for different bootloader. | ||
| | #241 | ||
| TO error404: As far as i know the file you link above is no Str3680 patch,when the other user (muaath) said : ""Hi everybody here is new coship strong 3680 S*ca2 firmware work 100%"" we all thought he was talking about a new bin. Do you know if there is any new SEKA2 bin for bootloader 38.02 or 39.02? Are you the same username from dvb-upload? If so,do you know how to convert a bin to work with different bootloaders...? Thanks. | ||
| | #242 | |||
well done m8 works ok with B34 !!!!(only with skyscraper upload-tool) should work with B39 as well orf still with dropouts but polsat 100% au !! there`s some S*ca 2 on "intuxication" which seems to work with B.39 (though they say it`s for B.34 ) ... on B.34 it hangs ; on B.39 it works(with the new upload-tool provided in the file) but black and white screen , (maybe something wrong with RGB-settings) ...anyway , youīve got to enter the key-menu with green button and then enter the keys with remote ctl. (problem to get E and F in) ... i finally managed with one of the multipurpose controls to get E and F , transferred latest titanium keys for sky italy ..but still dark , no idea if the emu has to be activated or i just got wrong keys cheers dishead | |||
| | #243 | |||
please read: http://www.al7bar.ca/forums/showthre...ed=1#post72807 Yes, I'm also on dvb-board!!! Kind regards | |||
| | #244 | ||
| @error 404: Which EMU-File (SRT 3680 or DSR 5002FTA) is the best to see the Austrian TV "ORF" 100% without drop outs? Please help me! Thanks Jo My DSR5002 is now after patch an SRT 3680: SW: S02B-2.98R-B39.01 HW: STS-MB.02A-SZL0 | ||
| | #245 | ||
| Error 404 it seems we think at the same time ,i discovered that (byte removal method) this morning comparing two bins with an hex editor,searching for keys addresses in firmwares,itīs very useful.Do you know where are the memory adds where keys are stored in a firmware,it depends on the firmware?. Thank you very much. | ||
| | #246 | |||
http://dvb-upload.com/index.php?acti...load&pid=16522 you must load a the new TP list to box and make new scan. Best regards | |||
| | #247 | |||
the keys are stored at address 0x10000 or 0x1002A (with header). I use KeyUpgradeTool, see here: http://dvb-upload.com/index.php?acti...load&pid=16522 Kind regards | |||
| | #248 | ||
| Member Join Date: 16-02-2004
I m using coship 2300b with boot loader BL21. now i wanna to load software of DSR5002-5003, or software of technosat 1100 which shows boot loader B34, and B39. what can i do . pls give me the suggestion. i jtag it for this. or any other method. | ||
| | #249 | ||
| @error404: Thank you for the file and the instructions, but it doesn't work, ORF also have drop outs all few minutes. Another idea? Thanks, bye Jo I have download into the receiver the software (bin-file) and TP-list from your new "ORF-file" at dvb-upload. | ||
| 2300, coship, patch, warning |
Similar Threads | ||||
| coship 2300 : new patch seca2 fixed | 59krimo | Receiver software, international Section | 6 | 21-04-2008 12:09 AM |
| ne patch | megabit800 | Receiver software, international Section | 2 | 13-12-2006 08:54 PM |
| where can i find sofftwere edit for Coship 2300 | ufo77 | Receiver software, international Section | 1 | 06-09-2005 08:27 PM |
| Coship 5300 patch ??? | Nagraeblanco | Receiver software, international Section | 10 | 30-12-2004 08:53 PM |
| WARNING!!! Novarg is spreading fast | net1 | Computer Discussion | 8 | 30-01-2004 07:04 PM |
