Warning!!! Coship 2300 patch
Information exchange on receiver software, including updates, problems and fine tuning.
Closed Thread
Old 04-09-2004   #251
Hello Poilus, that firm is the more stable i know;one has been released for the Tboston ,for seka2, but itīs VERY buggy, in the Axil you have to switch off the receiver a lot of times as it freezes and each time you switch off you lost ALL data (keys,channels...).
That firmware is the best ,srt3680_dsr5002_5003,until now,better than factory one!.
If we could find anyone with an Tboston 4500 jtagged i could make something with that seka2 firm to be more stable in the Axil...
Cheers.
Note: The Seka2 firm is ONLY for seka2,not for any other system.
jzurd0 is offline
Old 05-09-2004   #252
ok, thank you for your information.
I waits like everyone for the continuation of the évenements.
after a flash of a boston (B21) & an B38 axil, with their respective firm's : it's the same result on screen,...strong technologies at boot, same test menu...
do you think that it's only the boot part which change, do you have information on the structure of the file.
so i think that with an hex editor as Winhex, it could be possible to adaptate his own firm.
what do you tkink about that?
cheers
poilus is offline
Old 05-09-2004   #253
ORF trouble
Originally Posted by dohc
@error404: Thank you for the file and the instructions, but it doesn't work, ORF also have drop outs all few minutes. Another idea?
Thanks,
bye
Jo
I have download into the receiver the software (bin-file) and TP-list from your new "ORF-file" at dvb-upload.
Hi dohc,
If you don't have in the satelite list TP at Astra1 and you have chosen ASTRA2, there can be problems because ASTRA2 has a weak TP.
I've seen that some MB in PSR5002 show, that write to STB TPliste
is "Good" but this won't be changed.
I've written with hexeditor the new TPlist in emusoft.
Load it and check it out!
http://upload.e-tv.pl/upload.php?file_id=7871
Best regards
error404 is offline
Old 05-09-2004   #254
Hi error 404,
i have download your new file at "dvb-upload.com", beause at "upload.e-tv.pl" i can't open the zip.-file.
It doesn't work again but a little bit better than before with the last file.
Take yourself a look for 10 minutes at ORF 1 or ORF 2, than you can see the problem.
I hope that you can help me again! It would be enough when only "ORF" 100% works.
Or can you do something with the EMU-file "Morocco-Earth.bin"?
http://dvb-upload.com/index.php?acti...load&pid=14513
This file have the same problems with "ORF".
Thank you very much!!!
Greets
Jo
What i have done:
Download the bin-file "without header" with uptool.exe
Keys download with upgrade3.2.exe
6969, 6969 entered
Start search on ASTRA 1
If i make "factory default" now i have a HOTBIRD TP-list in the receiver with 780 programs.
With the last file there was ASTRA1 with all programs load.
dohc is offline
Old 06-09-2004   #255
Has anybody some exp. with the DSR 5003 FTA ? to upgrade/patch the firmware ?
hapen is offline
Old 06-09-2004   #256
Hi error 404,
Greets
Jo
What i have done:
6969, 6969 entered
Hi dohc,
I've tested ORF the whole sunday, and it works on my receiver. Where are you from? It easier for me to write in german or polish. Write me to not.found@gmx.net. I'll test the Morocco emu.
Regards
error404 is offline
Old 08-09-2004   #257
Seka 1/2, Nagra, Irdeto, Conax...
http://www.filescenter.com/descargas...00_b34_1.6.zip
Change * to "e"
jzurd0 is offline
Old 08-09-2004   #258
Nobody for the DSR5003
legrandchauve is offline
Old 10-09-2004   #259
For DSR5003 there is a patch from Strong SRT3680.
You can programm it via RS232 using :
1.DSR5002-uptoolB34-fix.zip - up tool file working with DSR5003 also.
2.COSHIP_DSR5002_B29_NagraAU.zip - use only S02B-2.98R-B39.01_21.08.04.bin
Tested 100%
After programming press 6969 x2 to activate Emu, press 8282 for edit keys.
pawelkos is offline
Old 12-09-2004   #260
New Seka2 firmware,not tested.
In sergiosat forum and:
http://www.satupload.org/upload/inde...TR3680_331.zip
jzurd0 is offline
Old 12-09-2004   #261
hi jzurd0,
i've try use the 331 firm you say, but not good for my axil AD-600, i've a B38 boot
it will be perhaps for the next firm... :-)
cheers.
poilus is offline
Old 12-09-2004   #262
Str 3680
patch for str 3680 sec*2?
wwwvex is offline
Old 12-09-2004   #263
Coship 5300A
I have put the sw of strong 3680 in the coship 5300 a.It is ok!Is there file-emu sec 2? Thank you.
wwwvex is offline
Old 12-09-2004   #264
can someone tell me if i can found a seca2 firmware for the coship 2300A BOOTLOADER 21 because the filecenter 1.6 doesn't work
it begins to upload but stop at bloc 97 on 515
does someone know if it's possible to upgrade bootloader 21 to ..34..39...
thanks for your help
oxoid is offline
Old 12-09-2004   #265
I need SOMEONE WITH A TBOSTON 4500 with a WORKING JTAG.
Please let emails,or message me.
Itīs VERY important for the AXIL users,(Seka2 related).
P.D: Itīs near, Poilus...
jzurd0 is offline
Old 13-09-2004   #266
srt3680.331
this file name srt3680-331 look like jtag file bcz it have 2048 bytes while those file which r upload through loader have 2049 bytes. so i hope it works with my coship 2300b when i flash with jtag program
any sucess i hope share here .
kpakistan is offline
Old 16-09-2004   #267
Originally Posted by error404
Hi dohc,
Regards
Hi error404,
do you received my e-mails?
Greets
Jo
dohc is offline
Old 17-09-2004   #268
poilus is offline
Old 21-09-2004   #269
Hello, Im new in this forum.
Today I got a new digital fta receiver called dsr5300.
It looks like the 2300. Is it possible to patch this receiver?
mfg fegro
fegro is offline
Old 21-09-2004   #270
Hello,
im searching for a patch coship_DSR5002_B29_NagraAU.zip
S02B-2.98R-B39.01_21.08.04.bin.
Thanks for reply
fegro
fegro is offline
Old 23-09-2004   #271
Hello,
Nagra AU doesn't work since today.
I'm looking for new firmware.
Best regards
r0mek
r0mek is offline
Old 24-09-2004   #272
Hello masters.
Has bought new Coship and at once a problem. I can insert software fon Pack Boston-Coship. My receiver
S02A-2.99R-B39.01
STS-MB.02A-SZLo.
Loading passes normally, but after start only the white screen and no channels and I can not cause the menu.
With Marocco patch I have gut screen, but sound is only noise.
Have you idee? Can be eat updated version Morocco-Earth software?
wanders is offline
Old 24-09-2004   #273
I have the same problem with a S02A-2.98R-B39.02
freshpike is offline
Old 24-09-2004   #274
For DSR5003
"ancien et nouveau coship plus stable que moroco.zip"
http://groups.yahoo.com/group/Nondidju/
Old 24-09-2004   #275
legrandchauve vbmenu_register("postmenu_142207", true); hello
how can i have software :-) for dsr5003
please help me
peles is offline
Closed Thread
2300, coship, patch, warning
[IMG] code is Off
Similar Threads
coship 2300 : new patch seca2 fixed 59krimo Receiver software, international Section 6 21-04-2008 12:09 AM
ne patch megabit800 Receiver software, international Section 2 13-12-2006 08:54 PM
where can i find sofftwere edit for Coship 2300 ufo77 Receiver software, international Section 1 06-09-2005 08:27 PM
Coship 5300 patch ??? Nagraeblanco Receiver software, international Section 10 30-12-2004 08:53 PM
WARNING!!! Novarg is spreading fast net1 Computer Discussion 8 30-01-2004 07:04 PM
