Warning!!! Coship 2300 patch
Closed Thread
Old 12-04-2004   #26
Originally Posted by rolfw
No, don't PM it, put the link on the thread, then at least everyone can benefit.
20 or so requests for a file by PM and the resulting 20 "Sent it mate" posts, with their answerring "Cheers M8" posts does not make helpful nor interesting reading.
Somehow I thought any links would not show up on threads, would be deleted as in some other forum's. If it is ok here then we have all ways open.
Just put it here guys when/if u find it.
GeorgiePie is offline
Old 15-04-2004   #27
@legrandchauve
can you send this famous patch for my coship 2300A
I'm french to
goldsifun@caramail.com
Pleaseeeeeeeeeeeeeeeeee
goldsifun is offline
Old 15-04-2004   #28
Unhappy
golsifun
I have not
I search this
legrandchauve is offline
Old 19-04-2004   #29
One week and no news?
Do you sleep?
Old 19-04-2004   #30
A bit enthusiastic
My System: Giberini 100,Cut Interstar GI-201,CD-80 feedhorn,Humax 8100 PVR,Coship 2300a,18 meters of Antec Superflex 1.6/7.3
No sleeping here Legrandchauve,but unfortunately no news about this firmware.
I would like people to post if they have some info about changing the keys in the "digitalsat-tv" firmware(maybe not possible),I haven't made any improvements but I really have tried!
steffan_st is offline
Old 21-04-2004   #31
I've got the french firmware srt3680 and it works very well.
Do you know how I can extract it from the memory?
olivier1963 is offline
Old 21-04-2004   #32
A bit enthusiastic
Would be very nice of you to share Olivier!I think it's very difficult to copy the firmware from the receiver,it will probably be like trying to copy a installed software from Windows.But let's work on it together!I'll be back about this.....
Old 21-04-2004   #33
A bit enthusiastic
Olivier,what kind of upload tool do you use when you update your settings/
channel lists?Do you use the Coship up tool?For me the button "get data from stb" doesn't work.
Old 22-04-2004   #34
coship
slt mais ont arrive po a faire rentrere les keys apres cette fenetre
A A A A A A A A
A A A A A A A A
JE SAIS QU ONT PEUT SE DEPLACER PAR LE N3 mais la !!! vous penser pas que il faut un tuto pour ca parceque la je suis sur que y ont a bk qui n'arrive po
merci st sorry je ne speack pas l'englais
rios is offline
Old 22-04-2004   #35
A bit enthusiastic
A A A A A A A A
A A A A A A A A
PLEASE POST IN ENGLISH SO ALL OF US CAN READ!!!!!!!!
Old 22-04-2004   #36
A bit enthusiastic
Hi!
I've been trying to find a solution for making a dump/copy of the rom in my Coship because if I could,olivier1963 could make a copy of his rom for us to use.Had an idea to use Windows Hyper Terminal to connect to the receiver and have tried it too,unfortunately I had no succes with this mainly because I don't know in what "language" I'm supposed to communicate with the receiver.
Anyone else with ideas about this?!?
Cheers
Old 22-04-2004   #37
some info
steffan_sa try al7bar.ca site, they have a st3680 file and info how to dump a firmware.
I don't know is the "right" one but....
ersd is offline
Old 22-04-2004   #38
telepat1's Avatar
Hello
i downloaded it.this the original 3680 firmware.;not patched apparently....
telepat1 is offline
Old 22-04-2004   #39
A bit enthusiastic
I have read and downloaded too,and if any of you would want it,I will post it here tomorrow.
Old 22-04-2004   #40
telepat1's Avatar
No news about patch to apply on.....
telepat1 is offline
Old 23-04-2004   #41
hi steffan
here is some readings for you
i hope it will help :
http://www.edaboard.com/viewtopic.php?t=45291
unfortunately i have no jtag so i can't help you
oxoid is offline
Old 23-04-2004   #42
A bit enthusiastic
Thank you very much oxoid!you are a helpful man.
Cheers
Old 24-04-2004   #43
help
anyone have a solution some idiot gave me a bad flash, it isnt responding to the com utility, i think it was for a logix FTA receiver
thanks
Tommyz1052 is offline
Old 24-04-2004   #44
A bit enthusiastic
thanks
Yes your right about the Logix receiver,but if you have the "upgrade software" running while you switch on the main switch on the back side of the receiver,it will possible to overwrite the patch,you may have to try a couple of times though.
Old 24-04-2004   #45
A bit enthusiastic
Questions to the guys who has the French-sold receiver with the good-working patch:
Does it disable any buttons on the remotecontrol?(like text-freeze-positioner or uhf buttons)How may keys for scrambled channels can you store in the receiver?
How do you change your keys?Please provide as accurate information about this as you can!
Thank You!
Old 25-04-2004   #46
no buttons seems to be disabled
it seems to be no limitations in nb of keys ????
to change key, type 8282 then you have the screen with keys
you choose encryption type with color keys
red=seca green=irdeto yellow=via blue=nagra
to add a key you click on "1"
to delete "2"
to modify you go to the key you want to change with the directional arrow than you clic on "OK".
you have new little window with 3 cases :
1° for provider code (0003 for C+France, 07C00 for TPS, 1702 for ORF for ex)
2° for key index (0C, 0D....)
3° for key (in this format "1A DF E2 A8 45 98 3E 68")
to do that you have in this window nb from 0 to 9 and letter from A to F
oxoid is offline
Old 25-04-2004   #47
A bit enthusiastic
to delete "2"
Thank you very much oxoid,your the greatest!
I wanted to know the features of this firmware since I put so much effort in finding it.Your information will probably help me if I try editing the 2300 firmware in hex.Thanks again!
Old 25-04-2004   #48
Coship 2300a
Hi. I need a patch of Coship 2300a . Any one who have please send it to me or assist me how i can got it. My e-mail is festop_2000@yahoo.com.
Thanx.
festok is offline
Old 25-04-2004   #49
i like this place
A A A A A A A A
A A A A A A A A
well this TRANSLATION of the above isn't perfect, maybe that's an understatement
I KNOW QU HAVE can ITSELF DEPLACER BY THE N3 but the!!! to think you not that it is necessary a tuto for ca parceque it I am on that there have has bk that does not arrive po
thank-you st sorry I not speack l'englais[/QUOTE]
hi, thanks everyone for all the info.
i thought this link http://www.freetranslation.com/ might be usefull,either reading or translating in other languages. so at least if someone can't post in english they can use this free translator. naturally it's not perfect, i picked one at the top of the search with the most languages. it translates sites also. based on how this translation comes thru,i'd post the original language after the translation if need be.
Salut, tout le monde remercie pour toute l'information.
J'ai pensé ce lien pourrait être usefull, ou lisant ou traduisant dans les autres langues. si au moins si quelqu'un ne peut pas poster dans l'anglais ils peuvent utiliser ce traducteur libre. Ce n'est pas parfait naturellement, je celui ai choisi en haut de la recherche avec le plus de langues. il traduit des sites aussi. Basé sur comment cette traduction vient à moi, je posterais la langue originale après la traduction au besoin.
have a good one
tiger1 is offline
Old 26-04-2004   #50
A bit enthusiastic
oxoid!
Would you please translate the previous post to understandable English when you have time!
Thank you
Closed Thread
2300, coship, patch, warning
[IMG] code is Off
Similar Threads
coship 2300 : new patch seca2 fixed 59krimo Receiver software, international Section 6 21-04-2008 12:09 AM
ne patch megabit800 Receiver software, international Section 2 13-12-2006 08:54 PM
where can i find sofftwere edit for Coship 2300 ufo77 Receiver software, international Section 1 06-09-2005 08:27 PM
Coship 5300 patch ??? Nagraeblanco Receiver software, international Section 10 30-12-2004 08:53 PM
WARNING!!! Novarg is spreading fast net1 Computer Discussion 8 30-01-2004 07:04 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. Uptime monitoring by PageUtils.com
