Warning!!! Coship 2300 patch | |
| | #102 | ||
| Regular Member Join Date: 04-04-2004
| I think this Spain link is important! http://foros.zackyfiles.com/showthre...5&pagenumber=9 | ||
| | #107 | ||
| Regular Member Join Date: 17-04-2004 Location: Greece
| to users that want to contact with me: thanos1960@yahoo.gr | ||
| | #108 | |||
| | #109 | ||
| Member Join Date: 01-04-2004 Location: Belgium
My System: satsly.be | I have the patch for the coship CDVB2300A, works fine on most packages, not conax nor s2 .. I also have an S2 firmware but it's not that stable. If anyone needs it, leave a msg and I ll put them on UMP upload. The one one german upload called "Coship_2300_emu.zip" is not working very good. The one that works fine is "srt3680 tps-ok.rar" and the "RC_20.zip" does weird things, (found on turkish forum), and "CDVB2300-seka2.zip" does S2. (well it used too, since hash tables changed.) and haven't found a new one/update yet. Cheers Satsly | ||
| | #111 | ||
| Member Join Date: 27-04-2004
Hu guys, Since one week, all TPS Movies channel aren't decode anymore without any reasons. Is anybody knows something about this and is there a new patch to corrected this problem ? See ya | ||
| | #113 | ||
| Regular Member Join Date: 24-05-2004
Steffan, I have a coship 2300b and want to open the scrambled channels on telestar 5 in the United States. Is the strong patch you talked about do that? Please help me in any way if you can. | ||
| | #114 | |||
| A bit enthusiastic Join Date: 11-02-2004 Location: Sweden
My System: Giberini 100,Cut Interstar GI-201,CD-80 feedhorn,Humax 8100 PVR,Coship 2300a,18 meters of Antec Superflex 1.6/7.3 ![]() |
Cheers | |||
| | #115 | ||
| Member Join Date: 17-05-2004
| for coship 2300b use this bin (Coship2300B_05_15_04)then initially you will see many lines, in case that the lines traverse in vertical form and the image is black and white you will begin for intuition, but you will be able to change norm of the Sistem Setting with the button of the side will press 2 times go down to Sistem Setting then you press OK, then you press 5 times down and immediately press the side key to put your norm PAL-M, NTSC-M or PAL-G I have a coship 2300b, and I had the same problem. Whit this bin you can wach TV for 2 o 3 hours if the picture an sound is gone turn OF the reciver for 30 seconds and press ON with back swich, then you can wach TV for Other 2 or 3 hours. For now is the only bin working with coship 2300b, I cheked all websites and I can't find good bins. | ||
| | #117 | ||
| Member Join Date: 16-04-2004
| hi on www.gsm-net.fr.st there's a specific forum opened for coship and boston and an upload... to be seen... ciao | ||
| | #118 | |||
| Member Join Date: 26-05-2004
| | #119 | ||
Stock is liquided in Brico depot. I have one of this receiver (Charleville Méziére) the latest; à Metz (nada,rien,vide) I have patched this and work good with the same soft. The remote control is not the same ( it's possible to enter F and E (key) with P+ and P-) for the slovacq patch (seca2). I look site for buy, but no chance. It is the spain clone of the Coship 2003A, sure!!!! | ||
| | #121 | ||
Hi Guys, Can you explain this : I've got 8 keys for SRG Swiss like : *********************************************** Keys removed by Admin, please read and absorb the rules. *********************************************** But i can't decode the TSR channels and i don't know why !!! Another problem with TPS Movies Channel. Sometimes they are decode, sometime they don't ; and i've got the lastest keys !!! See ya Pif | ||
| | #125 | ||
What are the best adresses to buy coship in France ? I found two internet links for the 2300A, but it is more than 100€ ? by the way the pictures of those two 2300a are not identical, how many version of coship 2300a do exist ?PS : sorry for people who send me private message I can not read them (less than 5 posts) | ||
| 2300, coship, patch, warning |
Similar Threads | ||||
| coship 2300 : new patch seca2 fixed | 59krimo | Receiver software, international Section | 6 | 21-04-2008 12:09 AM |
| ne patch | megabit800 | Receiver software, international Section | 2 | 13-12-2006 08:54 PM |
| where can i find sofftwere edit for Coship 2300 | ufo77 | Receiver software, international Section | 1 | 06-09-2005 08:27 PM |
| Coship 5300 patch ??? | Nagraeblanco | Receiver software, international Section | 10 | 30-12-2004 08:53 PM |
| WARNING!!! Novarg is spreading fast | net1 | Computer Discussion | 8 | 30-01-2004 07:04 PM |
