Warning!!! Coship 2300 patch
Information exchange on receiver software, including updates, problems and fine tuning.
Closed Thread
Old 11-06-2004   #126
coship 2300b
Help,,
I need the emu file for the 2300b
colbit is offline
Old 13-06-2004   #127
most of usa/canada would do anything for 5300b patch\
mginmn is offline
Old 06-07-2004   #128
ı search coship 5300 patch and password
geyikos is offline
Old 06-07-2004   #129
telepat1's Avatar
New firmware for coship and boston to test on 2300a.....
www.gsm-net.net
telepat1 is offline
Old 06-07-2004   #130
there is new firmware for coship 2300a autoupdate
polsat "topsat b10 with scart" download it from www.smadisat.com
muaath is offline
Old 06-07-2004   #131
this firmware work very good without error to edit codes press menu then enter 7755
muaath is offline
Old 07-07-2004   #132
Is default in pal ? Does it require to crosspatch the rca cables to get video? My TV is NTSC type. Your response is appreciated.
jeepney is offline
Old 07-07-2004   #133
you can try it if it doesnt work try topsat b21 file
muaath is offline
Old 07-07-2004   #134
telepat1's Avatar
Topsat b10
Hello muuath
Could u tell diffrences between differnt software b10, 21,34....
thanks
telepat1 is offline
Old 07-07-2004   #135
You couldn't post it? It's not there now.
GeorgiePie is offline
Old 07-07-2004   #136
Look:
http://www.smadisat.com/software.htm
Anyone with an Axil - AD600?,it seems to be a Coship 2300A clone.
jzurd0 is offline
Old 09-07-2004   #137
A bit enthusiastic
My System: Giberini 100,Cut Interstar GI-201,CD-80 feedhorn,Humax 8100 PVR,Coship 2300a,18 meters of Antec Superflex 1.6/7.3
Hi!
Anyone who can report the difference between the old patch (18 januari) and the new ones?
Cheers
steffan_st is offline
Old 09-07-2004   #138
Help:coship 2300fta=metronic Accessbox?
FW(Emu) for Coship 2300 is good for Metronic AccessBox?
gigi69View Public ProfileSend a private message to gigi69Find all posts by gigi69Add gigi69 to Your Buddy List
#2
http://www.satellites.co.uk/php-bin/...n/post_old.gif 2 Hours Ago
gigi69
http://www.satellites.co.uk/php-bin/...con/online.gif Online Now
vbmenu_register("postmenu_128985", true);
Junior Member
Chip Coship and Metronic
Coship STi5518
Metronic STi5518
gigi69 is offline
Old 09-07-2004   #139
Dys
Lightbulb Coship 2300
Try finding the info on http://forums.al7bar.tk they have a ton of info and a huge following....
With the info here and on al7bar.tk I think you guys will be more than happy.
Dys is offline
Old 12-07-2004   #140
for the new version of coship :
Software : S02B-2.96R-B34.01
Hardware :STS-MB.02A-SZLo
Flash by RS-232 is not possible (error 5) and Jtag connector is not present in Mainbord.
Please help me !
VVADE is offline
Old 12-07-2004   #141
Wie
before you flash new firmware, why not try to press
Menu - 7799, if receiver have an emulator, you can see CAS menu..
wie
Wie is offline
Old 14-07-2004   #142
As i said in Axil AD-600 post, flash upgrade via RS-232 in the new units is possible but the romsize is different.
Read that post and wait for the new working roms to come...
Cheers
jzurd0 is offline
Old 23-07-2004   #143
where i can find emi firmware for this device ?
thanks !
VVADE is offline
Old 23-07-2004   #144
Thumbs up
for vvade
I have a koscom DSR 5200 whith the same soft 2.96 and i have flasched whith this
http://elite.to/more4U fille 15.07.04 (S.W.8000 5000 Loader.zip)
menu...7799
all OK
legrandchauve is offline
Old 24-07-2004   #145
thank you very much.
merci du fond du coeur !
VVADE is offline
Old 25-07-2004   #146
http://www.satellites.co.uk/php-bin/...n/post_old.gif 1 Day Ago
legrandchauve
Mein Freund, Danke. Es war richtige Losung. Hab alles getestet - OK !!!
wanders is offline
Old 27-07-2004   #147
A bit enthusiastic
Are we discussing Coship 2300 in this thread or what?!?
Old 27-07-2004   #148
Steffan St,
I think they are saying that the S.W.8000 5000 Loader.zip, will work on the Coship. I just had this file sent to me but I have not tried it.I have a 5300B,
but I have not found any files that work without later getting the err.0.
gjones is offline
Old 27-07-2004   #149
I have the following receiver:
CDVBCoship2300a
SW S02-2.90R-B21
HW STS-MB.02A-SZLo
I just made the null modem cable 2-3 3-2 5-5, but I canīt find the way to comunicate with the receiver. I also realize that thereīs no jtag pins inside, just solder side.
any help???
Gigadreamer is offline
Old 27-07-2004   #150
My 2300a works with a straight serial. Manual says I need a n-modem, it took me a while
to make one (no proper tools), then tried a straight and no problem. Looks like they don't know what they are making.
Closed Thread
2300, coship, patch, warning
[IMG] code is Off
Similar Threads
coship 2300 : new patch seca2 fixed 59krimo Receiver software, international Section 6 21-04-2008 12:09 AM
ne patch megabit800 Receiver software, international Section 2 13-12-2006 08:54 PM
where can i find sofftwere edit for Coship 2300 ufo77 Receiver software, international Section 1 06-09-2005 08:27 PM
Coship 5300 patch ??? Nagraeblanco Receiver software, international Section 10 30-12-2004 08:53 PM
WARNING!!! Novarg is spreading fast net1 Computer Discussion 8 30-01-2004 07:04 PM
