Warning!!! Coship 2300 patch | |
| A bit enthusiastic Join Date: 11-02-2004 Location: Sweden
My System: Giberini 100,Cut Interstar GI-201,CD-80 feedhorn,Humax 8100 PVR,Coship 2300a,18 meters of Antec Superflex 1.6/7.3 ![]() |
Hello! I want to warn all Coship 2300 owners for a patch I downloaded at Slovak Download Center.I used the upload tool from Coship and everything was O.K. When the software was installed I noticed that the Diseqc 1.2 was disabled,also the text function.This the cracker had disabled because he wanted to have more space for keyfiles I guess.Now I can't write over the patch because the computer gets no contact with the reciever anymore.(the patch wasn't "write protected") So I guess I have to stay with this patch or throw away the reciever. There is also a good working patch on another website but you can't change any keys with that one. Cheers | ||
| Regular Member Join Date: 04-04-2004
| I have read your message to late!!!!!!!!! Have your a solution for resolved this problem. Can your another site for dl update whith key edit? | ||
My System: Giberini 100,Cut Interstar GI-201,CD-80 feedhorn,Humax 8100 PVR,Coship 2300a,18 meters of Antec Superflex 1.6/7.3 ![]() | Where do you find the 6 patches your talking about?I first downloaded a patch from digitalsattv.de that worked wery well and it was no problem to overwrite,but you could not change the keys.(maybe you can do that in a hex-view program and then upload to the reciever)Then i downloaded the "problem patch" at Slovak Download Center,but I can't find the letters E and F when I try to enter the keys so for me it is not working at all with the pay channels. It's the same size as the other patch and the same size as the Coship original firmware(2Mb). There are about 350 downloads at "Slovak" so many users will have this problem,let's stay in touch in this forum and try to solve this together! Cheers | ||
| | #5 | ||
| Regular Member Join Date: 07-04-2004
| thanks for your response steffan i found the 6 files at Slovak upload center date 30.03.04 hour between 11h57 and 12h46 you say you try to change the key : can you explain me EXACTLY the process to do that ... because on my receiver i try this MENU i go to "receiver info" and click on 1-2 or 3 and then the led change from 111111 to 222222......till 9999999 then i push on 3 and i have a window with 14 A then with 3 you forward and with 1 back (from a A to the next) and you see some code below this A but i dont know what it is please give me more information | ||
| | #6 | ||
My System: Giberini 100,Cut Interstar GI-201,CD-80 feedhorn,Humax 8100 PVR,Coship 2300a,18 meters of Antec Superflex 1.6/7.3 ![]() | Hi Oxoid! you are not suppossed to change your keys that way if you have the same patch as me.You should press the green button on your remote and then you get an additional key menu. It was not six different patches on Slovak,the first five zip:s were broken(only the last one working). Steffan | ||
| | #7 | ||
| dont throw it away send it to me (kidding) but u may ask from support team of ur dvb-box and they know how to solve it i got a prob 2 i need strong4400 patch to open scrambled and i neeeed any patches for any dvb-box models but strong4400 is nost urgent f7love@usa.com | ||
| | #8 | ||
| hi steffan i suppose i don't have the same patch then you i buy my receiver patched. When i put it ON i have a screen with "STRONG Technology" and when i look in "information" it give me Strong srt 3680 SW Version : Patch 1.0 Jan 18 2004 HW Version : Strong V 2.6 M02A i don't have access to new menu with the green key | ||
| | #9 | ||
My System: Giberini 100,Cut Interstar GI-201,CD-80 feedhorn,Humax 8100 PVR,Coship 2300a,18 meters of Antec Superflex 1.6/7.3 ![]() | AHA! That means your patch was meant for another reciever,there is one called Strong srt 3680.Maybe it has the same chip (sti 5518) as the Coship. I suspect I might have a similar problem with my patch because some of the keys on the remote don't work the way they should and the flash and ram memory seems to be too small because reciever tends to freeze on channel search. (memory size differs from different brands and models) Keep working | ||
| | #10 | ||
My System: Giberini 100,Cut Interstar GI-201,CD-80 feedhorn,Humax 8100 PVR,Coship 2300a,18 meters of Antec Superflex 1.6/7.3 ![]() | Why don't you contact your dealer and complain since you bought your reciever patched? | ||
| | #11 | ||
| hello steffan in fact my reciever works..but i only worry for the time keys change but i think it's what i'm going to do about the key and some letter you don't find...i read on some sites that 2300a has "matrix software" ??? and on a site i find a log to convert HEX to DECIMAL for entring the key on a matrix reloaded cam... perhaps it's the same for coship i have a txt file that i can send you by mail with conversion done | ||
| | #12 | |||
Have a pleasant Easter! | |||
| | #13 | ||
| For the Strong patch 1.0 jan 18 2004 enter 8282 when the receveir is ON, and you see the Key editor. I have see that in Belgium. It's not the original soft of the SRT 3680. I look for this strong patch, but i have not chance!! best regards | ||
| | #14 | ||
| Regular Member Join Date: 14-02-2003 Location: home
| steffan_st try this it may work It happened to me and within minutes i fixed it. 1. Make sure you shut the back on/off switch to off. 2. Plug the serial cable to it and start the uploader tool. 3. Hit the Upgrade software button on uploader tool and start to reload the file. 4. Now turn the back switch on 5. Let it load all the way and just wait till your receiver says good. Disregard if the computer says transfer complete. Once it says good I shut the back button off and back on and it booted fine. This is just to get the reciever back up and running. Maybe soon the real thing will come out. good luck This happened with the 2300B/5300B. | ||
| | #15 | ||
| Merci legrandchauve ça marche in fact for the coship with Strong patch 1.0 jan 18 2004 there is 2 codes : 6969 and 8282 with 6969 you enable the emulation (you must reintroduce this code each time you take off the plug) with 8282 (thanks a lot legrandchauve) you can change rhe key....and it works very very FINE for ex there were some T*P*S channels and all swiss channels that didn't work for me and when i see in 8282 i find that some codes were missing or out of date ....2 minutes later all was OKKKKKKKK it's a very good receiver ..... and i only buy it 80€...very good deal | ||
| | #17 | |||
This worked for me too!The thing is to have the "upgrade software" running while you switch on the back main switch of the reciever. | |||
| | #18 | ||
| | #20 | |||
| Member Join Date: 25-03-2004
Question ; is there a method of converting a PAL file to NTSC ? You europeans are so far ahead of us americans that it's a shame we can't tap into some of your knowledge. | |||
| | #21 | ||
Hi! Has anyone found the PAL Strong patch for the Coship cdvb 2300 a on the net? I've been searching like hell but no results! | ||
| | #23 | ||
Blog Entries: 5 My System: Sky+, DB 7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Spectrum analyser. | No, don't PM it, put the link on the thread, then at least everyone can benefit. 20 or so requests for a file by PM and the resulting 20 "Sent it mate" posts, with their answerring "Cheers M8" posts does not make helpful nor interesting reading. | ||
| | #24 | ||
My System: Giberini 100,Cut Interstar GI-201,CD-80 feedhorn,Humax 8100 PVR,Coship 2300a,18 meters of Antec Superflex 1.6/7.3 ![]() | GeorgiePie! Let's sort this out: 1. There is a patch at Slovak-download that doesn't work,it's meant for a Logix reciever,don't install it! 2. There is a patch at digitalsat-tv.de that works wery well but you can't change the keys.(you have to register to download) 3. There is a patch installed in a French-sold 2300 that apparently works very well and you can change the keys.It is meant for a Strong 3680 but it works in the 2300 as well.I have been searching like a maniac but apparently I'ts not available in the Internet! | ||
| 2300, coship, patch, warning |
Similar Threads | ||||
| coship 2300 : new patch seca2 fixed | 59krimo | Receiver software, international Section | 6 | 21-04-2008 12:09 AM |
| ne patch | megabit800 | Receiver software, international Section | 2 | 13-12-2006 08:54 PM |
| where can i find sofftwere edit for Coship 2300 | ufo77 | Receiver software, international Section | 1 | 06-09-2005 08:27 PM |
| Coship 5300 patch ??? | Nagraeblanco | Receiver software, international Section | 10 | 30-12-2004 08:53 PM |
| WARNING!!! Novarg is spreading fast | net1 | Computer Discussion | 8 | 30-01-2004 07:04 PM |
