Upgrading Please Read ThisInformation exchange on receiver software, including updates, problems and fine tuning. | |
| Member Join Date: 10-09-2007 Location: Ireland
My System: Comag SL35 Reciever |
I have a comag sl 35 and bought a serial(rs232) to usb cable with a gender changer because i dont have a serial port in my laptop . i plug in the cable to my recevier and the usb cable to my laptop then i checked which com port i had and it was com 4 so i opened winupload and changed to com 4 and tried to upload the patch... i get this error : error(-4) Problem : No Response from target Solution: Make sure target loader is running properly Connect your serial cable properly port settings are not correct resetting the target just wondering do i need to do something with the reciever because i have it on sky news which is a fta channel .. am i missing something? please respond | ||
| Member Join Date: 03-02-2008 Location: Cairo, Egypt
My System: astra 6000 | Hi Videogamingtown , I just wondering if you solved your problem yet. If so plz tell me how, since I ve the same problem but I didnt buy the adapter yet. Thanks in advance Videogamingtown Best Regards | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Not 100% sure, as I haven't owned one of these, but in most cases, you need to start with the receiver switched off at the mains, start the program and then switch the receiver on at the mains. | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | The receivers with the RS232 port normally require the use of a null-modem cable, rather than a gender bender. The RX and TX wires (amongst others) get swapped over. Robbo | ||
| read, upgrading |
