metabox not warkig only on no warkig
Information exchange on receiver software, including updates, problems and fine tuning.
Old 06-04-2004   #1
hiii
nhf11sa is offline   Reply With Quote
Old 09-04-2004   #2
den_baguse_fendi's Avatar
suggest
http://www.megaone.com/emetabox/guide.htm
den_baguse_fendi is offline   Reply With Quote
Old 09-04-2004   #3
do u know where i ca download patch for meta box 2?
kasra_eminem is offline   Reply With Quote
Old 12-04-2004   #4
Go to :
http://www.metaware.com.kr/customer/download.asp
http://www.megaone.com/emetabox/index.htm
http://qalonia.com/download.htm
http://www.megaone.com/titus/
Old 12-04-2004   #5
Smile metabox display problum always on
Originally Posted by nhf11sa
hiii
hello ser
how are you
your metabox is display is always on
no problum
Trick
remove the cover and remove the 2 pcb power suplliy and resold the flash
after 5 minet you can on the metabox i hope its working fine
Adnan265340000 is offline   Reply With Quote
Old 12-04-2004   #6
Thumbs up ok dont forget
ok janoo ojaskfj
Old 14-04-2004   #7
Dear friend..
***** not working..??
2 kind..
-->1. i guess that ur receiver has copied from the original H/W..
-->2. another problem..
xfile is offline   Reply With Quote
Old 16-04-2004   #8
You have to Reset the flash....there is no way any more
agar ham bacheye tehrooni , bia pishe khodam
metaboxlover is offline   Reply With Quote
Old 06-05-2004   #9
Question
hi
after i download dataloader to my reciever it is showing always on and it,s not working plz help me
mamnon man kharej az keshvar hastam be shoma ham dastrasi nadaram
aghar momkene baram farsi benevisid
garabolud is offline   Reply With Quote
Old 18-05-2004   #10
Unhappy please help me ( Display is always ON )
Please help me .
My Metabox is black color.
I changed software by loadar 5518 but this software was mistake
and flash memory damaged.
Always display is (ON).
I can't use of new loader.
I went to http://www.megaone.com/emetabox/software/jtag.jpg
and made a cable ( parllel pc to receiver ) for flash memory by map.
1- Power off receiver and removed cover and unplug wires of power supply and
front pannel .
2- I connected cable of parllel pc to receiver ( in box ).
3- I used of jkey dave 2.
but jkey didn't know .
Please help me .
aus_tt@yahoo.com
john28_3 is offline   Reply With Quote
Old 05-06-2004   #11
Hi John
1) Where can i find this loader 5518.
2) Is your "always ON" problem resolved or still facing same problem.
How to use Jtag software...Any detailed guide available at internet.
I want to upgrade my receiver (Metabox)
Rgrds
AA
aa_762 is offline   Reply With Quote
Old 08-06-2004   #12
nko
Once you have make the jtag cord,
- Remove the metabox cap
- Plug the LPT1 to the Jtag port (The grounds are near the front side of the metabox)
- Power on the metabox
- Launch Jkeys software
an error message must be appears
because the micro is notin mode bootstrap
=> Press OK
- At this step you must have to see the device ID and the device of the receiver
on jkeys IHM
- Power off the metabox
- push flash programming button
(a window appear)
- now You must connect the Reset pin to the ground (pin 10 of the schema)
- Press OK and unconnect Pin 10 to ground immediatly
- The micro run in bootstrap mode and jkeys initialize the com
(If an error message appear, it's failed. try again)
- choose "4900" in the "IRD Model" combobox (it have the same flash as the metabox)
- To save the flash data you must press "read" button (full)
- To program the flash you must press "program" button (full)
and select the bin file that you want to program
That's all.
notice: For me that was not sufficient. My pb must be other that the flash program.
if somebody can help me...
nko is offline   Reply With Quote
Old 05-01-2005   #13
jtag
please witch pin 10 of the schema idont know it can you explain
thanks
hajar is offline   Reply With Quote
Old 07-01-2005   #14
Unhappy can I get zee channels from asiasat 3S.
Any software for metabox to view zee channels. pls hlp me.
minlwint4 is offline   Reply With Quote
Old 28-03-2005   #15
hi
plz help me for find the Jkey
plz help me I need Jkey last version
bahman_a is offline   Reply With Quote
metabox, warkig
[IMG] code is Off
Similar Threads
Metabox ?? mimas Digital systems 1 20-09-2005 07:24 PM
metabox mehrdad Receiver software, international Section 28 13-04-2005 07:49 AM
E METABOX 1 LOVERS for seca 2 waab Receiver software, international Section 3 09-12-2004 08:03 PM
metabox receiver need multichannel keys plz help andysurg Keys and Key editing 1 09-11-2004 09:53 AM
metabox pejvak Receiver software, international Section 9 05-10-2004 10:56 AM
