Coship 5300 patch ???Information exchange on receiver software, including updates, problems and fine tuning. | |
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | See this thread. http://www.satellites.co.uk/php-bin/...ad.php?t=10407 | ||
| | #5 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | It is the thread entitled "Warning!!! Coship 2300 patch" It doesn't have direct links, but there should be enough information there to find it. | ||
| | #6 | ||
| Regular Member Join Date: 14-02-2003 Location: home
Use at your own Risk There is a company called Atrovox biz. They have a VSR-2500, the file inside says 2300b. I have heard a lot of people say they cannot change the keys. There is also a download for the VSR-3000, inside the VSR-3000 2 ci file there is a 5300B bin file. It is a pal file but can be changed NTSC via the menu (this has to be done while the screen is scrolling in the PAL video. Just remember where the tools menu across the top of the screen is located and also remember the NTSC/PAL settings are in the system settings the first to change and stop screen rolling is 5 down from the top and the next change is down 2 more(7).Keys for providers in NA need to be upgraded. The coship 5300b works for about two hours then goes to black screen, and has to be reloaded with standard 5300b bin. Typeing 7799 at the program menu or 7799 at the ci interface will give you a key edit under the ci interface menu. There is also a file called auto update for the 2500 and 4000 for preloaded receivers. This file is dated 2-25-2004, the other files were created in 2003. The autoupdate file for the 2500 and 4000 have a patch file and an updater for the Astrovox. I Think once these other files are loaded into your receiver you need to patch with the autoupdate patch. I could not get it to work I got a write failure on a 5300B, I do not know about the 2300. The 5300b file is dated 2-24-2004. If you do a hexedit on the patch file it also says inside VSR-3000. So I think maybe the 5300B need to be patched. But Like I said useing the autovox tool on the 5300b I get write error. If the 5300b gives you a blank screen, if you turn the power on the back off and on it will give you a err.0, but you can still load a standard coship bin. | ||
| | #8 | |||
| | #9 | |||
| Member Join Date: 06-04-2004
I tried and ... no chance to access CAS, only in Receiver Info is something when you click 3 on remote. My receiver is a Coship 2300B. | |||
| | #10 | ||
| When you are in receiver info menu, the standard coship 5300B bin file also gives you a screen with a few X's when you press the 3 Key. Key 1 and 3 also move you through the X's. I know if you press certain keys the back ground screen will change colors. I do not think the VSR-2600 will do any good. I will try. | ||
| | #11 | ||
| Member Join Date: 30-12-2004
Hi there, I just got a receiver coship 5300 and been having a hard time finding the flash bin to get it runing, could anyone let me know where can i find it? i will really appreciate any help. Piercito alexpiercer*hotmail.com | ||
| 5300, coship, patch |
Similar Threads | ||||
| patch starsat | NBK64 | Receiver software, international Section | 25 | 13-06-2008 02:48 PM |
| coship 2300 : new patch seca2 fixed | 59krimo | Receiver software, international Section | 6 | 21-04-2008 12:09 AM |
| ne patch | megabit800 | Receiver software, international Section | 2 | 13-12-2006 08:54 PM |
| Dragon Cam and Coship 5300 | Lucky Jackson | X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex | 0 | 04-12-2004 06:54 PM |
| Warning!!! Coship 2300 patch | steffan_st | Receiver software, international Section | 284 | 19-10-2004 01:16 PM |
