emu firmware for KAON 570HInformation exchange on receiver software, including updates, problems and fine tuning. | |
| Regular Member Join Date: 01-01-2000
helppppp!!!!!!!!!! i have a KAON 570H receiver with a PVR hard drive... s/w: 13.05.01 h/w: 13.41.6d loader: 5.1.6 c.a: 2.1.9 pvr: 1.6.0 im trying to get a software EMU in that will sort out the usual 6-in-1 and nagra stuff but no joy. im using a KUP226user and a ksc-570hz_hw13[1].41.6d_sw13.05.03_conv file, both from la-cafetera site..but when i try it says receiver mismatch.... it may be due to my receiver bein 570H and the file is for 570HZ......but the hardware version for both is the same : 13.41.6D so to the question, guys: is there any such file for my particular model??? and where can i get it? or could i jus manipulate some parameters and force the file into the receiver somehow? please point me to the right direction thanks | ||
| Member Join Date: 03-08-2004
| you can tray the www.satbox.nl than file sectie you have file voor kaon.. and if you use cup 216 you must have code the code is zzzup befor you put the reciveron.. suc6 | ||
| heya... look here http://www.sathack.de http://www.digitalsattv.de filename: KSC-511HZ_13.41.6D_040409zc hope it helps | ||
| | #5 | ||
| | #7 | |||
| Regular Member Join Date: 27-07-2004
select the soft , switch receiver off and on to download. if soft is inappropriate(machine doesn't start up again) don't worry ,try another one (bootloader will not be affected) after successful download machine might display "NOCH" (no channels) just press "OK" button on the reveiver and your precious settings will be back. you also may go to "system settings" and set any possible setting to "unlocked" or lock "off" to activate the e*u for key-edit press yellow,blue,green,"menu" cheers dishead | |||
| 570h, emu, firmware, kaon |
Similar Threads | ||||
| Humax BTCI-5900 firmware | DaNileKnight | Receiver software, international Section | 6 | 02-02-2008 04:01 PM |
| How can i backup my receiver firmware or software to PC | wongul | Receiver software, international Section | 6 | 11-02-2007 02:45 PM |
| firmware emu | f1167 | Receiver software, international Section | 0 | 22-09-2004 05:46 PM |
| Software & EMU do I need for.... | ultrAkin | Conax, Cryptoworks, Nagravision, NDS and Others | 1 | 21-02-2004 06:45 PM |
| firmware for my elvis programmer | tipsygent | Cards & Programmers General | 3 | 24-01-2004 08:23 PM |
